99 Tacoma Prerunner Valve + Coolant = Blown Head Gasket?
Old 04-10-2010, 09:30 PM
de1905's Avatar
So I decided to take a part my air intake plenum and give it a good cleaning... Noticed when I did that there was a good amount of engine oil coating all six intakes as well as around all the valves. There is also a small amount of coolant noticeable around one of the intake valves in the #3 cylinder...
What do you guys think? Blown head gasket? I'm not getting the typical overheating or milkshake oil but I realize that's not always the symptoms of a blown head gasket. I just recently replaced the valve cover gasket on the same side of the engine as cylinder #3 due to a leak.
Any thoughts would be helpful, thanks guys!
Old 04-11-2010, 05:28 AM
eddieleephd's Avatar
my thought would be that the valve stem seals need replaced and coolant could be from the intake some how...
Old 04-11-2010, 07:55 AM
de1905's Avatar
Thanks, I've been trying to find some other reason for that coolant to be there (besides the head gasket or a cracked block) but no success.
Anybody else have any good suggestions / experience?
Old 04-11-2010, 02:32 PM
look the throttle body over real good and was or is there a k&n filter??
Old 04-11-2010, 03:03 PM
de1905's Avatar
I believe at one point there was a k&n filter (the air box has been patched up with tape).
Also the throttle bottle and the entire intake was coated with oil... Appears to me the heaviest amount came from cylinder #3 and was sucked/blown around from there to all the other cylinders. I might be wrong on that...
Old 04-11-2010, 09:00 PM
Well then you probably do not have engine oil on the valves but rather filter oil! the thing you need to do is see if there is a coolant leak and fix that>>>
The next thing I would recommend is seafoaming the intake via the PCV valve.
once you have done this then you will be able to see if there is really engine oil and coolant or if it was intake filter oil.
There is a coolant line that goes to the IAC on the throttle body that may be able to leak so be sure all of it is sealed correctly and reassemble and seafoam it. look at in a couple of days to be sure...
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: 99 Tacoma Prerunner Valve + Coolant = Blown Head Gasket?
