- 2001 4Runner Pink Milkshake Questions
- Power Windows Not Working
- Pre-runner vs. 4WD front Axle Hub & Steering knuckle
- Those leaky axle seals
- transport stand for tonneau off-truck
- Help with testing fuel pressure
- 2wd front wheel bearing replacement
- 98 rear hatch wont open.
- differences between stock 2wd and 4wd front struts?
- H4 Quick start HID BI-Xenon Bulb lamp Mini Projector
- HID (Low-Beam Xenon/ High-Beam Halogen) -H4 5000k 55w on Projectors
- 3rz High Idle
- Front skid plates - interchangeable 2001-1996?
- Shifts without button / cannot remove key -- Park Neutral Switch?
- No spark on 96 4Runner
- tires / rims for 96 tacoma
- Driveshaft Rattle in 2000 taco, 2.7l
- tranny gear oil
- Question about Detroit true-trac in ADD trucks
- 3RZ Mystery Pipe
- manual transmission question
- Overlanding/Wheeling - Sell 01 To Buy 99/00 w/ Locker?
- O2 sensor threads
- Needing 2 Trim Parts for 2002 4Runner SR5
- 3RZ power steering pump fail
- 3.4 Engine Auto / Manual Trans
- Anyone Running Nitro-Gear Rear Chromoly Axle Shafts?
- Doing a bunch or work, what am I forgetting?
- 5VZ Injectors???
- 96 4runner brake vibration
- Hot summer sale on Gibson Exhaust through July 31st!
- Supercharged Tacoma sluggish
- Power Seat Attack!
- coil spring question
- V lutch
- 2000 4Runners
- IFs skidplates
- Tacoma Bed Sizes
- 2001 Taco, 2.4 Ltr Slight Intermit Stumble At Crusing Speed
- 1996 Tacoma 3.4 Overheating nothings worked so far
- 1996 SR5 135,537 miles Transmission Flush or Drain and Fill
- Blinking vs steady CEL
- MAF part #
- 01 4Runner Misfire no CEL
- P0300 p0301 p0171
- Tacoma 2002
- Flywheel won't go on
- Help with towing
- Need help with misfire
- after cleaning Fuel injectors clicking sound
- 2003 Tacoma FSM
- 1996 SR5 4Runner No Keyless Entry
- Low Power at Start
- Been a while, new truck here
- Question about a wax to revive oxidized paint
- OME 906 and Bilstein 4600
- Cross country trip preventative maintenance
- lower control arm cam removal
- What does this part of the VIN tag mean?
- 2000 4runner coolant leak
- Brake Fluid Replacement
- 97 runner body on 1985 chevy frame?
- Front Axle howl or deep whine Help!
- Tacoma payload capacity
- P0300 p0302 p0303
- P0773 - Transmission Solenoid SL
- 1997 Camry No Dash, Tail Light, License Plate.
- New clutch advice?
- elocker swap
- 4runner Polk Speakers Upgrade
- Noob shock question
- 3rd Gen rear hatch interior opener
- 3rd gen runner: Anyone here change their own rear axle bearings?
- Wireless Tire Pressure Monitoring System. Anyone have?
- Ignition cutting out - 3RZ 2.7L
- (unintentional) Disco tail light mod (help.. no really, help)
- Low idle when starting cold
- P0302
- having issues finding the right water pump
- 3rd gen runner AC system...how long did yours last?
- Multiple problems
- 2000 Manual Clutch Pedal Tight!!!
- Possible Weird Fuel Problem???
- 5vz-fe blow-off sound
- what timing belt lot to buy
- 2000 4Runner Looks Odd New Struts
- Safety Auto Parts +.020" pistons??
- Rear End Swap Ideas
- 1996 t100 tacoma 2.7l Cranks, but no start please help.
- HELP 4runner Mystery Misfire!!
- Gradual Loss of Transmission
- Stumble under load
- Heated side mirror glass replacement part
- 00 Tacoma Misfire
- Has anyone ever replaced a 3rd gen v6 timing belt in the field?
- 95 taco 2.7l pvc valve
- Would you buy? (00' SR5 140k $5,500) - w/Pics
- What is it?
- Check Engine Light and Possible AC Belt Sqeal
- Changing fluids 4runner 3gen
- A/C clutch or compressor
- 99 4runner bag/hesitation when accelereating hard from idle
- Assistance for purchasing exhaust parts
- 2'' Square Rubber piece/flap from under chassis?
- Old Gas Problems Concerns?
- 98 Tacoma 2.7 problems
- Anyone near Littleton, CO area?
- high mileage 4runner rebuild or sell
- Key FOB reprogramming
- Engine Swap Problem
- 98 tacoma help
- My truck runs bad. Help
- 03 Tacoma automatic transmission and differential questions
- New 2003 toyota tacoma bumper build
- Does anyone have any experience with either Walker or Eastern catalytic converters?
- 2000 Toyota 4Runner driver side rear door lock actuator replacement
- 4 runner vs Tacoma doors?
- P0420, converter removal, magnaflow replacement write-up
- Help! 97' Tacoma speedometer/odometer not working at all
- Knock sensor location on 2.7 liter
- Tranny issues P0770 S.O.S
- Speck of spark plug ceramic in cylinder head
- Anyone besides me constantly cleaning their MAF sensor? 3rd gen
- steering knuckle
- HELP!!!! 97 4Runner Auto transmission swap
- Purchasing one of these - what to look for?
- Has anybody noticed decreased power/MPG by going with 235/75/15 tires
- 3rd Member Compatibility Double Check
- Clock, Radio, 12v Adapter Not Working
- Please someone help, '97 Tacoma 2.4
- Dunlop STT PRO
- Should I buy a '98 4Runner with 430k miles?
- 96 tacoma wont start
- Conversion to Toyota E-Locker
- Troubleshooting engine issue...any ideas?
- '99 4Runner sluggish only when warmed up
- Question about replacing sway bar links and sway bar bushings
- Pics of lifts and tires
- brake light stuck on
- How to tell if radiator has been replaced or not
- 2000 Tacoma SR5 OBD2 No Communication
- Frazzled: jump started my 01 taco double cab with my welding machine
- What O2 sensor to buy for Cali truck with only one cat
- 99 4runner rear window and power locks issue
- pressing out front wheel bearings
- Where does this ground wire go? Help?
- Just bought it yesterday
- 96 3.4 failed CA smog again....
- 99 4runner vibration issue...please help
- Rear Door Control Module
- 400,000 Mile Club
- headcheck regarding alignment
- Stalling problem
- VSC/TRAC Question
- No Start - Good battery, ground, alternator, starter. Won't jump start.
- Cadillac 1994 4notes horns
- 22r engine in Tacoma shell
- 97 4runner 2.7 2wd
- Intermittent hard brake pedal after initial application - '00 4runner.
- brake controller installation
- Cam seal replacement
- Grease fitting/Zerk broke on LBJ
- Dumb question regarding easy crank seal replacement
- Service manual
- 99 4Runner questions
- Slight pause after turning key in ignition
- '03 Tacoma won't start... broken timing chain?
- brakes
- Stuck in 4wd only when ADD used.
- Specific: will truck cap from 04 Frontier fit 1996 tacoma
- Pinging
- Tundra Bilstein shocks
- '98 4Runner - All Headlights Stopped Working
- Transfer Case Center Diff Lock Switch
- Tacoma frame rust
- Vent circulation problem
- 3rz running rich
- 96-02 Gibson exhaust last minute sale, ends tonight 3/22
- Overheating
- PO330- malfunction or Knock detection?
- Vacuum 99 4 Runner Transfer Case
- Clutch manufacturers?
- 99 4runner newbie question on lift
- Weird bog-down issue '00 Limited
- 98 tacoma oil leak?
- Sequoia rear springs on a gen3 runner
- 1997 tacoma bilsteins
- Grease path in rear slip joint, trying to understand
- '97 2.4L 2RZ-FE Transmission Question, HELP!
- P0440 code + trouble filling gas
- Towing a Tacoma on a dolly
- 01 4Runner Won't Disengage 4WD
- p0441
- 4WD not engaging
- 1998 4runner smog issues
- Cylinder 3 misfire help
- truck cap topper camper shell install mating material
- What's it worth?
- Supercharged 4runner - FINALLY!
- Anyone installed aftermarket pop up sunroof reg cab?
- Maxi fuse question
- Clicking from left rear axle after bearing/seal job [VIDEO]
- 4wd On Jack Stands
- Rag Joint Opinions
- Need some guidance with sloppy steering.
- Finding a tire tool for 97 4runner
- Pitting on Block surface (5VZ-FE)
- 1994 Toyota pickup starting problem
- Winch bumper
- Total loss of power and overheating... Any ideas?
- Companion Flange Question
- 3RZ 2.7L with 2 dead holes
- Front Brake Conversion
- Turbo setup or LS swap
- Roof Rack
- Terra Grappler size question (yes, another tire thread)
- My catalytic converter was stolen
- Brake Help
- Transfer Case Selector
- Fuel Mileage???
- Vibration goes away with heater or A/C on.Why?
- 1999 4Runner Front Axle Boot Slip
- Possessed temp control knob
- Yaw sensor bad?? ZPCal does not fixe it.
- 2002 Tundra 3.4L V6 - Radiator Blew, wont start, what happened???
- Now 4WD and Don't know where to start [HELP]
- Ats upper control arm bushing needs replacement
- Too much $$$ ???
- 97 "stealthbox" install, 0 cargo space lost, detailed
- Humming noise on deceleration when 4x4 is engaged. Need some help
- What would you pay? 1999 Taco 4wd
- 3.4L swap using 2WD wiring/ECM
- 3rd Gen 4runner Survey (for fun and for Statistics Class)
- 1999 3rd Gen 4Runner Lift & Tires
- Can’t figure out this noise!
- Intermittent P0441
- Dash lights
- Intro - new2me, low mileage/1 owner 2000 T4R SR5, v6-4x4
- My wipers are possessed!!!
- 2000 4Runner manual non-CA emissions A/F Sensor replacement
- Strange 5vzfe noise. Maybe failing harmonic balancer?
- 98 4runner Brake Issues
- 4wd Help
- Electric Fan Install on 03 V-6
- Thermostat engine/radiator flush
- 3rd gen tires- Nitto Terra Grapplers....yea.....or nay?
- uh oh a new misfire thread....
- 2001 4Runner lift question..
- Super Weird Electrical Problem 99 4Runner
- 2002 4WD Manual Tranny and Tfr Case with ADD
