Cant figure out this noise!
Old Feb 9, 2016 | 04:31 PM
tek23's Avatar
Hey crew,
This is my first post, but not my last. I’m hoping you guys can help me out. I’ve searched intensively but come up short.
My truck started randomly making this weird noise last week when giving it gas. Never when revving neutral or park. Like i mentioned, it randomly does it. Last time was Saturday, but hasn’t returned since.
I’ve threw it on a lift on Monday but neither my buddy or I could recreate the noise or determine where it may be coming from. Driveshaft/ U joints seemed ok. New diff from toyota was put in last year.
1999 4runner w/ factory locker
Sonoran Steel 1.2 installed couple weeks ago.
Thank you!!
Video
Old Feb 10, 2016 | 05:34 AM
Malcolm99's Avatar
Pretty hard to tell by that video, is it the rumble you are referring to?, do you have a aftermarket cat, I had the internal baffles fall apart on a cat that made a intermittent rumble around 2000rpms when under load, sometimes the baffle would jam up and would be fine. Just a guess.
Old Feb 10, 2016 | 08:57 AM
tek23's Avatar
forgot to mention the noise starts around 8 seconds in the video. stock cat, but ive read stories about cats making similar noises.
Old Feb 10, 2016 | 02:00 PM
ThorInc's Avatar
Might even be the heat shield.....but I really can't tell from the quality of the video.
Old Feb 10, 2016 | 02:52 PM
tek23's Avatar
Im hoping the noise never comes back again but if it does, ill try to get a better video.
Old Feb 10, 2016 | 08:38 PM
vital22re's Avatar
totally a bro
can you get a general idea of where its coming from? Front or back? left or right? does it increase with speed? does it increase with RPM? In 4wd?
Old Feb 11, 2016 | 03:21 PM
tek23's Avatar
I thought it was the front, but when i had a passenger in the backseat, they said it sounded like it was coming from the rear, so i honestly dont know. The sound stays the same as i increase speed, but goes away when i take my foot off the gas. Same sound in all functions2wd, 4wd, with and without locker.
Old Feb 13, 2016 | 11:47 AM
tek23's Avatar
had it on a lift this morning. greased up all the fittings on the driveshaft/u joints.
hoping the noise disappeared since it hasnt come back since last week but my luck, it came back on the way home from the shop.
Old Feb 14, 2016 | 07:30 AM
ZUK's Avatar
ZUK
Low diff fluid level or bad rear wheel bearings? Check wheel bearings by placing back on lift and shaking tires.....unusual slop or vertical movement?
Old Feb 16, 2016 | 01:15 PM
tek23's Avatar
The noise has become an on going issue here to stay. Threw the rear up with a floor jack and recorded this. Buddy of mine thinks its the front U joint in the rear shaft.
Old Feb 17, 2016 | 03:48 PM
tek23's Avatar
Bump for ideas
Old Feb 19, 2016 | 07:48 AM
The Ruckus's Avatar
Didn't notice any industrial zip ties attached to your drive shaft, did you? It's a dick move, but it's hilarious.
Old Feb 19, 2016 | 04:16 PM
tantacoma's Avatar
I remember a case where the drive-shaft came into contact with the gas tank skid. A long-shot, but check for it
Old Feb 23, 2016 | 02:17 PM
tek23's Avatar
lol no, pretty sure there arent any zip ties
Ive checked that as well. Took the driveshaft off and tested it. No noise. Ive also shown this video to a driveshaft specialist as well. We both come to the conclusion that its the double cardan joint that is causing the noise. I ordered a new driveshaft through toyota yesterday. Hopefully that solves the problem.
Old Feb 24, 2016 | 09:59 AM
Malcolm99's Avatar
Did the drive shaft guy offer to rebuild it, not easy but doable, it is very common for people to over look greasing the double Cardan joint in the middle and just lube the 2 ujoints, good catch.
Old Feb 27, 2016 | 06:34 AM
tek23's Avatar
Talk to a couple of people about rebuilding. Some said hell no lol others charge as much as a new shaft. Ended up ordering a custom shaft from tom woods
Spectre
23
Jan 9, 2004 10:50 AM
pfbmgd
Dec 5, 2003 03:54 AM
AznSky
11
Oct 15, 2003 04:12 PM
