- Who ever designed the front brake lines on a 97 4Runner...
- electric fans for 98 34L
- Here's how i did the rear diff breather...
- Neli, Request
- mech/tuner assistance needed in O.C.
- 4Runner Decals/Stickers?
- OEM Hitch Class?
- Wheel Fitment Help
- Supercharger solution?
- SOS - Defroster - rear window and mirrors ?
- TRD FJ wheels-photoshop
- 2.7 Sooty Exhaust, Poor gas milage
- PCV valve 2.7. Help!
- Denso or Denso Iridium???
- 3rd gen 4Runner> MAF interchangable? (Different housings?)
- Replace OE Front End Links or Upgrade Complete Sway Bar Assembly
- Any White 4Runners been in an Accident?
- What LC springs and tundra springs should I use????????
- Where to get shock bushings/washers
- Exhaust? Yes i searched!
- Gauge Install
- Are the front and rear O2 sensors interchangeable on the 3.4?
- 2nd Gen Bumper mounting points same as a 3rd Gen?
- New Guy, Introduction
- Change the rims?
- Do these springs need touching up...?
- Edelbrock header??
- Buy New Tail Lights?
- 20" Volk TE37's in 6 lug application
- Finally fixed my oil leak
- 1997 Police 4Runner
- 2000 4 Runner rear-end support
- couple pics of my truck
- Lighted switches wont light
- Factory E-LOCKER PROBLEM
- Good reason to go to the dealer
- Let There Be Light!!!
- Wont start!!
- 5VZFE Intake - Stock or Aftermarket?
- 4 questions on your tire setup
- injectors sizes for s/c runner?
- Leaking Front IFS, <pics> Need to know whats wrong!
- What kind of spark plug do you use? Why?
- better mpg's with taking off my bug shield
- 96 Tacoma Cab Swap
- Looking for a used lift......................................
- 295/75/16 Or 285/75/16 Nitto Terra's
- 3rd Gen/Taco Drum Brakes
- What the Heck is Wrong - Really rough idle?
- Just looking for opinions?
- Check out my Cup holders
- Deckplate
- White 3rd Gen Intro...
- Towing with deckplate results.
- So I busted my bumper up a bit.
- trueflow fitment question
- Coolant temp.
- rear diff lock switch
- Yota Newb needs Axle information
- PFC-Autozone brake pads?
- vibration issuses
- Manual Hub Conversion
- Best tire for $100?
- Its Howling Really bad--Need help please
- Some times they do come back...
- Are 3rd Gen 4runners significantly improved over 2nd Gen?
- replaced my ome coils with LC coils, pics inside
- Friend's Mom seriously injuried in 4Runner rollover
- cleaning the alternator on a taco
- noisy belts and pulleys??
- 4Runner broken into.
- Backup lights installed with pics
- New here..quick question
- Removing steering wheel
- gear oil question
- Eagle Alloy 16's, don't fit, is this everyones same problem?
- Who to have install a 2" Body Lift in Denver
- PIC REQUEST: Nerf Bars
- Broken sway bar link
- Transmission problem
- FJ80 Wheels, were to get
- Transfer Case Noise... Does Your Truck Do This? Video Included
- Interior leak, drivers side
- multi mode 4x4?
- Kill Switch...
- LC Coils
- Plugs and wires not hooked up to anything
- 1st spark plug change, questions??
- OME Lift...last questions B4 install.
- WTB: Power Leather Seat For '02 4Runner
- Pic Request: LC Rims with 265/75/16
- Rear end noise, bearings or gears????
- bad experience with 4wheelparts
- Tokico top nut stripped off
- Squeal When I turn the wheel
- Question on 99-4runner windows
- do i have an egr valve??
- MY 89 4Runner was rear-ended :(
- LC wheels back from the powdercoater...pics
- Install LC coils and New Shocks???
- 4runner Sleeping/Storage/Camping Platform - (Pics)
- 1996 LC wheels on a 2001-2004 Taco
- HaHa another photoshop request
- Rear Driveshaft Separation
- 295 Nitto's are on! Thanks Ric!
- disconnecting front sway bar temporarily
- 4runner V6 5speed
- "Wheezing Pig" noise from engine 96' Tacoma..any ideas?
- a new member of my family
- 1st gen roll bar in a 3rd gen
- Pic request: ARB and TJM winch mounting
- New Shocks
- motor oil in my transfer case???
- replace rear diff. or entire rear end?
- Help 99 Or 00 4runner Owners!!!!
- ARB or TJM Quick question?
- Can the sidemarker mod be wired just for the blinker?
- Just Ordered Bilsteins and Bushings
- front light bar for tacoma 2002
- Just thought everyone should see this biodiesel LC
- toytec lift question
- I need a good website for brush guards for 3rdgen
- Winch installed.
- Replacement driver's side mirror
- Anyone around Nashville, TN with a SC 4Runner 3.4L?
- Steering column moves sideways?
- 6-speed for your thoughts
- Had a little fun today...
- getting ready to lift what should i do
- Recirculation fan stuck on?
- Uh oh, what does this noise mean?
- Brake fluids
- Gearing, for my 3rd Gen
- What yr 4runners had the "U" shaped brackets on the cargo cover?
- Control Module
- Toytech lift question
- Headlight options for 97 4Runner
- Anothere Photoshop Request
- New wheels. . . need opinions.
- Rough Idle / Vibration
- now my gas mileage is better-- thats weird
- paint tjm all silver, hoops silver?? ps pic inside (crappy 30sec job)
- Rear Lift Questions
- Some of us are in a 4x4 magazine article
- E-locker??
- Time for a tune up?
- 4x4 lever ??
- Bumper Paint
- Removing Bumper
- Would silver or gunmetal look ok?
- how can you tell if rear axles seals are bad?
- I have spooky steering
- 99 or 00 4runner owners help again!
- '99 coil springs question
- New Marlin Crawler Axle Seals
- tacoma transfer case options
- Quick question for anybody with an FSM
- 4.0L swap?
- Recommended Pads Rotors
- 98 4runner limited 3.4L thrown rod
- '01 - '02 brake bleeding question/concern
- 2000 4runner..Should I sand and paint my flares?
- help asap...factory alarm problem
- help asap
- Looking for Pics of HyperSilver Tundra Wheels on a 3rd Gen
- Leaking roof
- HELP!! Small rust spots developing! AWWWWWW
- totally kidding about the rims!
- Help I Got Pranked!!
- random CEL visits
- Clutch--Done--O2 sensor Done but wait...
- 3rd gen 4runner skid plate
- Son's 98 tacoma wont start, sound like a fuel pump to you guys?
- I'm in the market for some LC Coils
- 4runner problems, car stalls on low RPM
- installing new shocks and springs
- Power window Questions
- OME 881 amount of lift.
- One year update
- New and a few questions
- How Wide Is To Wide?
- Rear window wiper blade replacement
- Taking donations for these rims:
- Dual Batteries in a 3rd Gen with ABS??
- 3rd Gen 4Rnr Push Btm 4WD Reliability
- Oil pan help!
- Fuel tank sending unit question
- low fuel light
- Check engine light on How to pull the code?
- MAFF cleaning on 2002 3.4 v6 tacoma
- Roofgoofs New Lift
- Does this endlink look correct?
- Changing battery in 99 4Runner LImited
- Ridiculously Huge toy PU
- 3rd gen Custom rear bumper guys, question for ya.
- How do I clean the MAF on a '96 4cyl ?
- LC coil questions
- Rattle/wind noise @ 50 mph & up
- HUGE 4runner
- OME lift or OEM lift?
- I HATED the ticking coming from my blower unit!
- regular denso plug question
- CEL after Deckplate.
- 2000 Limited
- WTB: Driving Lights that fit an ARB
- Oil fill cap off..!!
- De- Icer and Aluminum Wheels???
- How to remove factory front sway bar 2002 4Runner?
- Photo Request - Black 3rd Gen 4Runners
- IPF's Installed - pics
- Did my fuel filter and PCV today.
- Summer Service Special!
- 18" 2007 4runner wheels
- Satoshi - Few pics
- Need some advice from some experienced folks on lift.....
- Help!!!!!!!!
- Procomp shocks???
- Shell for 04 Tacoma--which ones fit?
- tacoma black headlights/clear corners
- Main heater out rear works engine temp ok
- Can I temporarily remove this emissions component?
- I got the center caps for my fzj80 wheels, however....
- Lifetime fuel filter......Haha ya right
- Should i get these 2002 4runner rims
- Fuel Filter?
- 4WD Transfer Case Actuator
- First major issue w/ my 3rd gen - AC Clutch
- Thinking of a S/C for the 3.4
- What's behind the other side?
- AimCo Clutches???
- LC Springs Question?
- mr2 alternator swap in 3rd gen?
- Longbed 2wd Tacoma?
- constant shifting of 4wd
- TSB Issue on 98 4runner axles?
- 1998 Tacoma V6 timing problem...help please!
- Deck Plate Warning
- greasing drive shaft
- TRD locker
- Popping noise
- got a little money any ideas?
- Update on suspension install!
- swapping out lamp behind hot/cold dial in '02 4runner
- New look for my Runner
- Formal Intro.
- Simple deckplate question.
- Just finished satoshi grille, pics...
- Thieves Stealing Catalytic Converter, Is This True?
- 99 4RUNNER ON 33s
