Help!!!!!!!!
Old Feb 16, 2007 | 08:42 PM
hopper's Avatar
Help!!!!!!!!
To start off... I have a 1998 4runner limited. I started my brake upgrade to tundra calibers and rotors. I started my brakes earlier today and the driver side was easy...
Then I started on the passenger side and it was a pain is the F*#^ a**. Well finally got the caliber off and the top screw is..........ya my luck....IT IS STRIPPED!!!!! The treads inside the part that the caliber bolts to looks like it may be damaged also!
I need help! What if anything can I do..????
Old Feb 16, 2007 | 08:52 PM
sdstud212001's Avatar
time for a trip to a machine shop or the salvage yard
Old Feb 16, 2007 | 08:54 PM
hopper's Avatar
What would a machine shop do?
Old Feb 16, 2007 | 08:57 PM
CJM's Avatar
CJM
Tap and rethread it.
Old Feb 16, 2007 | 09:01 PM
hopper's Avatar
OK
Correct me if im wrong but you need a bigger bolt after you tap and rethread it right?
Old Feb 16, 2007 | 09:03 PM
CJM's Avatar
CJM
OK
Not really totally, you could possibly salvage the threads if it isnt to bad.
Helicoil would do the trick too..
Old Feb 16, 2007 | 09:05 PM
hopper's Avatar
Whats Helicoil???
Old Feb 16, 2007 | 09:07 PM
CJM's Avatar
CJM
Its a threaded insert you use, you would probably have to chnage the bolt size but they work well..
http://www.emhart.com/products/helicoil.asp
Old Feb 16, 2007 | 09:24 PM
hopper's Avatar
I cant locate on there a price or how to possibly order. Whould you know by any chance?
Old Feb 16, 2007 | 10:17 PM
jct61765's Avatar
Whats Helicoil???
if you dont know you should probably take it to a machine shop.
Old Feb 17, 2007 | 05:53 PM
hopper's Avatar
Thanks for the help...i tapped it out and everything worked out.
Thanks again, Cody
