- Sick of drowning. Went and built myself a snorkel!
- ome run3/1.5" adapters 33s still rub
- Your sunroof expertise, please.
- PCV catch can; ? 4 Mt. Goat...
- darn motor swap
- Trying to remove spindles
- 1989 thirds in a 1998 Tacoma?
- Steering/Brake Click in Reverse
- Straight Pipes?
- best to buy oem paint and clear coat
- Winch Bumper
- Rusted Frame 00 lmtd.
- ECT switch stopped working
- What are the 3rd gen front and rear axles called?
- purchased 2001 Runner with 64K miles
- high idle caused by grooved out TB?? need help asap!
- Please Help! 4runner makes 2 beeps while driving
- Stuck in 4wd
- Internet Supercharger
- inch worm cross member
- Calling all IFS 4WD guru's
- Suspension Recommendations
- 99 4 Runner. Wind knocks it well into the next lane.
- Tundra brake compatible with manual hub conversion
- Bumpstop choices w/ upgrade to OME 906
- Lift Kits and Proper Height w/o Looking Stupid
- Replacing upper ball joint. What else should I replace while under there?
- Banging the tailgate on your head!!!
- problems with alignment
- OME 881/890 front level problem
- Rear seat belt replacement
- Bandit Runner gets 35" Tires
- Clicking noise from glovebox??
- Oxygen Sensor Difference
- fuel pressure not maintained after shut off
- "teen with a dream" new rims
- 4runner manual hub conversion question
- Someone please Help cant get over 50mph
- 99 Supercharged 4Runner Issue
- Seat Brackets
- Does anyone have a driveshaft grease diagrahm?
- 3rd gen with OBDII code 0420
- New Toytec lift now have vibration
- 1997 Tacoma Knocking Noise Under Bed On Acceleration
- tacoma rear end sag... will new leaf springs fix it
- Solutions for reducing rear-end sag
- OME 880 / 906 Upgrade!
- how to remove antenna in 2002 sport?
- 5VZ-FE Valve Tick
- late model suspension to 2nd gen taco
- Daystar spacers from a dodge ram?
- 2003 3RZFE Power steering leak.
- When to throw in the towel: '96 4Runner Ltd. w/ 260K miles in need of repairs
- 2003 S/C Tacoma up to Crater Lake Rim
- 1996 2WD Runner Brake Job
- 99 4runner DIY rear axle bearing removal help
- 98 4runner 3.4l slow to accelerate and missing
- My "new" 96 Tacoma
- OBA system
- Why don't we have 3rd gen 4Runner tube door.
- Questions & help with ECT sensor replacement
- New ECT sensor made noticeable difference
- M/T Classic II photo request
- evap vsv ticking
- Trailer hitch bolt-up
- strut replacement
- Front strut top plate stud removal
- Theives stole my Converter!
- So who else has trouble with rear diff ring and pinion gears?
- '99 front coil color question
- Grinding/vibrations after Lift
- transmission question
- Sonoran Steel System 3 Lift -- Info for y'all
- rear spring spacers
- Building a 98 4Runner advice
- Long granny 1-2 shift, wut's up with that?
- Toytech 3" Spacer Lift Kit????
- Blown strut replacement, do both sides?
- Torque converter won't unlock
- Tundra brake upgrade done with problems
- Those of you with LC coils...
- 4WD Lights on Dash Blinking ALL THE TIME??????
- Bed size
- 98 2.7 headers ?
- Limited fender flare Install
- 96 taco suspension refresh
- 3rz fe engine vibration
- My experience with rear axle oil seal +
- 96-02 4Runner rear end question!
- Driveline whine any ideas?
- Turbo Diesel Overhaul Question
- help diagnosing start-up issue
- Have to say goodbye
- What to do and how to drive to get the best MPG...
- IPF 968 wiring help
- Mud flap help...
- Help Diagnose Drive Belt Noise Area 2001 Tacoma 3RZ-FE 2.7 L
- 01 4runner moonroof (sunroof) opens automatically, won't close. Help!
- 98 4Runner- Engine Shuddering
- Tacoma fender flare restoration.
- HELP!!! need a 2.7 question answered fast!!
- 4wd wont engage
- fail-safe code chart - need help!
- Rack & Pinion problems?
- Front end noise over big bumps w/SS 1.2 Lift... Your thoughts please?
- new suspension stuff!
- 97 4Runner SR5 (5VZE) Magnaflow 18"-11256
- BruceTs Bumper Plans for 3rd gen 4runner needed
- '97 - Master key will not turn rear lock.
- Engine Checks When Out of Car?
- Drivetrain shudder
- Fixing my turn signals...
- Highway transmission issue
- o2's and coil packs
- Stabilizer Bar Bushings/Energy Suspension
- Prerunner and 4runner tranny swap (just hear me out)
- License plate trim color
- Considering lifting my truck, have questions!
- Help! Looks like tranfer leak
- 2000 4Runner running sluggish
- Recommendations for rear springs/shocks
- Pinion bearing failure
- 02 3.4 dual cat delete
- Can I tow with a 3RZ?
- 2002 4Runner transmission whine noise
- Fiberglass Fenders and intake
- 2.7 5spd trans behind a 3.4?
- Help with fender flare...
- 285/75-16 MT/Rs on Stock 5 spoke rims
- Stock radio cd/tape locked up help
- My Setup
- AC/Heat Diagnostic check codes, where to go from here??
- Another "What does this plug go to?" question.
- Soft peddle after Tundra Brake upgrade
- Upper Control Arms
- Rear wiper blades
- Starter issue
- Info on my 3.4l supercharger
- vibration on deceleration at speeds over 60mph
- 2wd drive into 4wd
- Rear Brake Parts
- coil packs
- no front brakes
- Bumper question
- Quick Short Video From Saturday
- Standard 8000K H4 9003 HB2 Xenon HID Xenon Conversion Kit
- Vibration while stopped and in Drive
- 2000 4Runner stuck in higher gear after stopping
- 5VZ-FE head gaskets???
- Frame warranty?
- 98 4runner vibration fix!
- Repair cost: Front end crash
- Hard/Long Start When Cold
- Ball Joint Failure - My Turn
- 1999 Tacoma 2.7L oil leak from timing chain cover
- 97 Tacoma 3RZ running very rough...
- 97 rear window wont go down
- 02 Sport- front suspension noise issue (clicking)
- Wet headliner in '03 Tacoma - blocked drains?
- The Grey Wire Mod- Redux
- Tacoma frame rust - How many people cashed in?
- 98 2WD 3.4 engine replacement. What years fit?
- Aligment issues after Toytech 3" spacer lift?
- Front End Vibration Troubleshooting Guide
- 99 4runner color code
- 1999 4runner: will a OBDII scanner read my O2 sensors?
- 300,000 miles
- Transfer Case Questions
- 2000 4Runner Air Filter Housing
- Rear Cargo Hatch Won't Open!!
- found solution to rear howling problem...
- 1996 4runner Limited, burnt valve
- Catalytic Converter/California Computers/Clarification Please!
- Changing Clutch /Shortcuts/Tips 2000 Tacoma
- 2001 4runner SR5 with 178,000 miles
- 99 SC 4Runner Strange Lean/Rich problem
- Corner lamp and gear selector lamp inoperable
- 2002 tacoma regular cab
- broken bolts help
- Valve cover replacement 2002 Tacoma
- Wheels siezed to hubs and stripped lug bolts
- Strange Intermittent Parking Brake Light
- LT or P rated tires from the factory?
- 99 Multi Mode troubleshooting
- Hydrogen Enhance Injection
- RPM range expected with 4.88 Gears?
- Rough Country Easy Lift
- 5VZfe and 3VZe valves ?
- Burnt Valve or bad gas?
- 99? Tacoma Motor Identification Question
- CV boots ripped after lift, how to fix?
- Wiring - scratching my head and going bald
- massive oil consumption 3.4L
- Front Springs Going on My 2001 Runner
- No throttle registered until last 1/3rd of pedal travel?!
- Brake light works, tail doesn't
- Taco lean fix, Help!
- No axle seal leak but noise at drivers rear axle
- Loose all power- Alternator?
- Piston slap( carbon knock) or Rod? After Seafoam..any thoughts
- Mirror Finish Anyone? (Head Surface Problem)
- 4x4 problem
- Anyone ever seen one of these before?
- alignment issue on the front after lift on 3gen 4runner
- my 2" toytec BL arrived today
- Back Seats Mod
- 1999 4x4 Highlander items
- fabbed cat
- Air Filter Housing Options??
- Door swap=electrical problems
- What size tubing for brake bleeder valve 1999 4runner & notes on Motive Power Bleeder
- '99 tall coil lift on a 2001 4runner
- 97 4R SR5 Alternator fix questions
- replaced thermostat - leaky bolt
- 2000 4runner CEL Code P0773?
- How do i turn off traction control??
- 97 Tacoma Front end went BANG now no 4wd?
- Trouble Starting
- Clutch burned no chatter
- Vibrations from rear when braking
- Can cold weather cause a CEL
- rocker rust on a 97
- P0171 and Chugging Idle
- Tacoma Cluster (mech. dial vs. digi dial) and Transmission options
- How to tell if my center diff lock is engaged?
- 2002 4runner 4wd intermittenly loosing power no specifac times..
- 3.4 Rough Idle Solution
- Hood Scoop Insert!!
- Yakima LoadWarrior "Build" Thread
- 98 4Runner EGR remove/clean/install help
- Help with Wheel Spacers
- Roof mounted driving lights question
- Tacoma hesitation...oxygen - knock sensor codes
- 15"Wheels & Wheel Spacers
- 98 4runner-no 4wd- halfway diagnosed but need advice!
- EFI relay burns out when truck is cranked
- teflon on thermostat housing bolts?
- Need ETC, Rear Window, Shifter & HVAC Lights Replaced, Please Help!
- changing antifreeze
- Proof that you can fit 255/85 with 1 1/2" of lift and still function
- Engine Sluggish, Hard to start
- HVAC Control Unit Bulb Socket Not Working
- cb antenna and mount
- MPGs after DP and ISR
- Need help with P0125 & P0135 codes
- catalytic converter
- Engine swap or rebuild for a '99 V6?
- Broke front diff.
- 98 4Runner Rear Suspension (need photos)
- Mysterious Wire........
