PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Strange engine squeak
  2. P0401 Insufficient EGR Flow
  3. A/C Recharge Problem
  4. Exhaust Manifold servicing
  5. rs3200 security system unistall
  6. Very strange trans issue
  7. Trouble Shifting new to Me Manual Tranny
  8. '98 4Runner Diesel 4x4
  9. what would happen to my suspension if I added a Savage Offroad bumper to stock
  10. Cheaper fix for down travel. MAYBE
  11. Gray (blue/red) wire mod and ECU
  12. Rear coil spring question.
  13. Transmission cooler mounting - thoughts and interesting discovery
  14. Bed Length on '99 Ext. Cab vs. '89
  15. noob locker install
  16. 4Runner Radiator
  17. Disc brake dust shield replacement
  18. Manik Grille Guard Question
  19. Hitch Install
  20. All at once failure, keyless remote, rear window, rear wiper
  21. Missing hose ??
  22. Tacoma Front Coil lift
  23. Rear window motor/ wiper motor relay
  24. Rear window makes pop noise when going down
  25. high rpm
  26. temperature gauge in 02 tacoma v6 maxing out
  27. kevin444's projector retro done!
  28. P0171 After O Gasket Upgrade
  29. Spark Plug and Wires Question
  30. Check Engine Light
  31. 3.4 Starts but won't run. What could it be
  32. Adding Radio Under Stereo
  33. 3rd Gen JL Stealth Box Question ?
  34. Throw Out Bearing
  35. 185,000 mile question?
  36. cylinder two missin
  37. 4Runner + Riding Lawn Mower = BAD
  38. Darn rear axle outer oil seal...
  39. Skid Plate? Alternatives? What do i do?
  40. Bucket Seat Frame
  41. 3rd gen tow package?
  42. Headgasket? Smoke and stumbling on warm start-up. Advice?
  43. Stronger/Beefier Inner Tie Rods?
  44. AC diagnosis help
  45. leaky rad fitting, any fixes??
  46. 01 t4r sr5 pre-purchase issues
  47. Just Turned 280,000
  48. where is the engine to chassis ground? 2002 tacoma truck?
  49. re-gear question
  50. just got offered a 98 taco ext cab 5sp trd. what to look out for
  51. California Catalytic Converter for 2000 4Runner v6
  52. Write up for S/C nose cone rebuild?
  53. Programming transponder key 1999 4runner
  54. new u joints and im still vibrating in the rear end!
  55. Overheating Problems
  56. Rain / Car Wash rear Window & Power Lock Issues !!!!
  57. What size puller for CV replacement?
  58. back into 4runner territory!
  59. Crank Key
  60. Upgrading Alternator Wiring?
  61. Loose wheel bearing?
  62. Salvaged vs remanufactured Tundra Calipers
  63. "Jerk" when letting go of gas pedal quickly
  64. Post Milkshake Tranny Problems
  65. which aux lights to buy?
  66. a/c trouble
  67. Fabtech 3.5'' lift coils (1998 2wd Taco)
  68. 99 4runner exhaust install?
  69. Are these front end parts bent?
  70. Who likes ball joint failures?
  71. '99 4Runner Radiator blockage
  72. knocking/rattle noise
  73. Odd oil Leak
  74. What is this? Rear cargo plate. 3rd Gen 4Runner
  75. Sonoran Steel System 3 coil question
  76. Wrong 02 Sensor?
  77. 3rd Gen 4runner frame rot
  78. Time-Serts? I dont want a new head.
  79. 98 4runner OME 881's up F & R 890's: off road worthy?
  80. alignment specs 1997 surf
  81. Extending the panhard bar
  82. 3.4L 5VZ FE Blown Head gasket....
  83. Another A/T temp light question
  84. 04 taco clutch adjustment
  85. High temp AT light
  86. Shrockworks sliders (3rd gen 4Runner)
  87. 3rd gen 4Runner fogs electronics corroded,is there a save?
  88. No speedo!!! Please help
  89. New Taco
  90. Power inverter wiring
  91. 98-200 bumper swap?
  92. Ignition power tap under hood
  93. Torque Converter - End of the life?
  94. Differences in auto transmission between years?
  95. Seat Belt Replacement
  96. First time posting: intro/question
  97. Idle seems to be stuck
  98. 5VZ FE high idle
  99. Bad 4x4 vibration
  100. Rig is destroying batteries!
  101. 3RZ What is this sound?
  102. power steering pressure line leak
  103. Just put on a new T belt. Can I check it before putting the truck back together?
  104. Replace/Fix Fuel Line on 2000 4Runner V6?
  105. A/C blowing fuses? What could it be?
  106. Brake Caliper Hardware--4runner vs Tundra
  107. Low/rough idle sitting at a light (worse with AC on)
  108. Limited Bumper Makeover
  109. 3.4l with 3 misfires
  110. Worthwhile Tip for those changing CV shafts on 3rd Gen'S
  111. Transmission whine after new engine
  112. Hatch Door Help?!?
  113. AT Fluid Leak?
  114. Hesitation/Stutter at 2k-2.25k RPM ?!?!
  115. So fresh and so clean clean!!!
  116. Engine noise after new head gasket
  117. Clutch Issues...Not What You Think
  118. HID Kit and DRL
  119. Sheared 2 of 3 thermo housing bolts
  120. rear view mirror and radio antennae
  121. GROUP BUY--T-case Brake for 3rd gen
  122. Replace Climate Control lights...on sr5
  123. AC Compressor/Clutch Intermittently Seizes
  124. Turning 100k today
  125. 98 Tacoma Power Outlets melted wires
  126. Help please need pics of 2.7 vacc lines
  127. 97 Tacoma transfer case
  128. 4runner updates - BajaRack, Line-X on the TMJ, etc
  129. 5vzfe Knock sensor wiring?
  130. E-Locker Won't Lock
  131. HIDs installed!
  132. Gas pedal floored, but low rpm's?
  133. 3rz computer reflash
  134. What is this whining noise? *video*
  135. Help with top plate extended studs
  136. 2000 4runner 2wd front brakes (autozone)
  137. 4r squeaking while in reverse ?
  138. exhaust gasket part number???
  139. Any one working on there rear hatch?
  140. 2000 4Runner - Setting Valves??
  141. Wheel Bearing and CV Replacement
  142. body swap question
  143. 01 Tundra Brake Mod for 3rd gen 4runner...
  144. 99 Cargo door diagram needed
  145. 5vz No Start
  146. Side Mirrors Wobble
  147. Trail Gear Sliders Installed
  148. Fuel tank leak on 96 Tacoma
  149. Daystar to OME w/Pics
  150. Bandit Runner's SS1.2 Lift Installed
  151. seat belt / airbag question
  152. Fabtech suspension lift?
  153. Heater noise
  154. Spark Plug Change MAF/TB Cleaning
  155. tires screeching
  156. Gas tank Skidplate
  157. *Write Up* Installing the Yellow Box Speedo Calibrator
  158. Starter and radiator questions
  159. New Alloys Purchased need colour suggestions
  160. 1999 4Runner - Key won't turn in ignition
  161. supercharger pulley size
  162. Misfire, lost on the problem
  163. Help, TRD discontinued part
  164. RPM's at 70mph for Automatic 2000 4R?
  165. Time for brakes, thoughts on these?
  166. 255/75/17 mud terrains on with no lift
  167. Sunroof retrofit...
  168. Overheating preventing starting?
  169. 3rd & 4th Gen Fender Flares
  170. Swaying at high speeds??
  171. Rear Window/Wiper problem need help
  172. 1999 2.4 tacoma front of engine coolant leak
  173. Electrical Lock Problem on 99 4runner
  174. Rough idle,misfire,long cranks,and whats this?
  175. AC Compressor abnormally loud
  176. 97 4runner power radio antenna help
  177. HELP! Hard shift/high-pitch vibration
  178. air conditioner dripping water
  179. AC Problems
  180. new to me 97 4 runner
  181. 1999 4Runner Post Timing Belt
  182. Transimssion won't go into reverse!!
  183. Having a problem understanding service manual gear lube spec.
  184. Need diagram for wiring in driver's door
  185. still having p0171 issue...
  186. How to attach rubber grommet to hole in firewall - 3rd gen tranny cooler install
  187. Spindle Installation Help (Pics Included)
  188. general auto trans question 2002 4wd 4runner sport
  189. 2000 4Runner Tundra brake upgrade
  190. 315/75 General Grabber DOTs are on
  191. what part is this and can I fix it?
  192. Whose 4Runner is this? Syracuse NY area
  193. Exhaust problem
  194. I need a picture of Tacoma body mount floor
  195. shock valving question
  196. How much ATF top-off after flush?
  197. Shock Bushings and Strut Mount
  198. Rear diff whining
  199. Replaced Throttle Position Sensor
  200. gear shift wont move out of park !
  201. oil in intake tube
  202. Trouble code P0302
  203. are 97 & 98 Tacomas the same as 95 & 96 exept for the grille etc?
  204. Pondering gears for 315/75/16...diesel 97 SUrf
  205. 3.4 CA smog-legal header recommendations?
  206. My Homemade (Not really) Tapered Diff Drop Spacers
  207. 1997 Tacoma 2.7 Engine Temp?
  208. Pros/cons of E rated tires on a 3rd gen?
  209. Weird noise coming from front of my 4runner , Wheelbearing?
  210. Possible broken transfer case or transmission HELP
  211. Name that noise
  212. 01 4runner throttle issue
  213. Transmission problem: '01 4runner auto with 120K
  214. New Fuel Filter = more mpg
  215. Right front vibes when I let off the throttle?
  216. 5vzfe IAC?
  217. P0171
  218. Code PO- 125 temp sensor on 3.4 ??
  219. Advice Wanted on Timing Belt Pictures
  220. after-lift alignment
  221. Uneven brake pad wear
  222. A/C low on R134a-does this always mean leak?
  223. fuse for rear heater
  224. Rusted panhard axle mount
  225. Problems After Rebuild (3RZ)
  226. 96 4Runner Trailer Wiring
  227. 97 4Runner Tach works sometimes
  228. Clutch problems
  229. Camshaft Sensor
  230. Crankshaft gear
  231. Fog Light Stalk Pinouts?
  232. Help with RPM's after throttle body cleaning
  233. How many miles are too many to start some mods?
  234. 1997 4runner coolant temp sensor
  235. Starter rebuild: Broken plastic plate on contact
  236. failed smog check in cali also check engine light
  237. 98 tacoma wont go into 1st and 2nd sometimes
  238. Trying to fix air conditioning system leak...
  239. Electrical Problem
  240. in need of the fuse cover diagram: 96 4runner
  241. timing junper??
  242. Rear wheel bearings?? - 4runner
  243. 1999 3RZ-FE 2.7 L 4runner: why no fuel filter?
  244. Rack & Pinion issue - 2001 Taco
  245. new yota: 97 ext cab tacoma 4cyl 5speed running sluggish
  246. transmission problem -3.4, Tacoma, auto, 4x4
  247. Rear Air Deflector Measurement Question
  248. sound of my 4runner
  249. 99 4Runner Oil Seal leak
  250. The "Hidden" GPS Mod
