Uneven brake pad wear
Old May 24, 2010 | 04:43 PM
Brend2b's Avatar
Yesterday I noticed a constant sound coming from one of my brakes so I figured i would give it a look today. When I took the wheel off, turned out it was a wear indicator dragging on the rotor. The pad on the other side of the rotor was only worn slightly and had 2-3 more times material left on the pad. I'm under the assumption that there is a problem with the caliper causing this problem.
Would my best bet to eliminate this problem be to replace the whole caliper when I do my brakes?
Old May 24, 2010 | 06:00 PM
zanzabar0's Avatar
this happened to me when i changed my brakes as well. the inside pad is the pad that the pistons push against the rotor, so it gets worn out quicker than the outerside pad. if the rotor is badly warped or warped in any way i would change it out as well as the pads. that way the old rotor wont eat up the new pads if its worn or grooved. Also, what i did was switch the outside pads with the inside pads after a while so they get an even wear. if none of this works then i guess you should just get a new caliper or go to a shop and see what they think. hope this helped.
Old May 24, 2010 | 06:11 PM
Brend2b's Avatar
Its the outside pad that's worn on mine. Also, the pistons push from both sides so they should wear at the same rate.
Old May 24, 2010 | 06:22 PM
HighLux's Avatar
Id say the pads with less wear are maybe hung up and caused the other pad to do the work wearing quicker.
Had it been pulling to one side or the other? Any pulsing of the break pedal when braking?
Make sure there are no poinches in the brake lines too.
Old May 24, 2010 | 07:41 PM
Brend2b's Avatar
The outer pads on one of my calipers are wearing two times faster than the inner pads. The brake lines to it are fine and there has been no pulling when braking. It does shake on hard braking but I think thats due to the rotors warping when they heat up. I guess the pistons are hanging up on one side.
Does anyone know a good source for caliper rebuild kits?
Old May 24, 2010 | 07:52 PM
HighLux's Avatar
Rotors get warped and stay warped.
My diagnosis is the calipers are fine if it
doesnt pull to one side or the other.
Get your rotors turned and do some fresh
pads
jasonty
41
Dec 23, 2018 01:00 PM
trailgoat
Aug 13, 2015 05:54 PM
snap-on
Aug 10, 2015 05:19 PM
ty1er
Aug 1, 2015 11:53 PM
harrisdawg
Jul 26, 2015 09:42 AM
