- not going in to gear?
- Brake Bleeding?
- suspension recommendations on 3rd gen 1999 4runner
- 22r and 22re differences
- truck won't start
- ps pump info
- Tight/hard e-brake lever
- 4wd operation
- standard options 92 vs 93
- 99+ 3rd gen HL swap
- Cannot go over 2500 RPMs?!
- Rough Ride Fix
- Blower Switch
- 1st gen 4runner cab headliner removal Q
- Fuel filter replacement
- Drilling a perfectly good roof .....
- how off is my speedo?
- How to apply touch up paint?
- just got a new 4runner, and I need help diagnosing it's problems
- 60K or 90K timing belt? for a '94 4Runner
- Check out the headlights on the new Hi-Lux
- where to purchase tjm
- FYI: Hella 500's on sale for $59 at Advance Auto Zone
- HELP!! Lots of threads, but no answers? Cat Problem
- To buy or not to buy? That is the Question!
- Sway bar end link length and how it effects the suspension for on and off road???
- downturn to turnout
- Heat works fine in back, but cold up front.
- 99 4runner - Using factory fog wiring for aftermarket fogs
- bumper question
- burning oil
- How much to rebuild manual trans
- Rear axle seal leaking.
- Your experience running OME HD coils w/ Bilsteins HD shocks
- tacoma ?
- Indicator issues
- Anyone ever use an Oil Extractor?
- local toyota dealer gift checks($425)
- Front axle help!!
- Can I add power steering
- Hitch rating INFO
- Good oil pressure at idle but drops when rev'd or driving. WHY???
- Any diff btw OEM and aftermarket fuel filters ?
- 99 4Runner Antenna Motor
- Using Mobil 1, got some smoke!
- New shocks on 01 Tacoma ???
- 3rd gen. - rust around windshield - need pic of gasket around glass
- What is the most gallon's you've put in your 3rd gen?
- First time Oil change
- 02 sensor rip off....
- Uh.. Brake fluid on my paint.
- Oppinons on painting rear bumper
- Question about E-4WD
- So Much For The Factory Alarm....
- Deckplate & ISR completed yesterday
- Just bought a 99 3rd Gen SR5 4runner with 99K mi, rr diff locker, auto...
- over bore pistons...where to find rings?
- Bolt on fender flare/trim for Tacos
- Stupid Runner has a mind of its own.
- White Face Gauges Not Glow
- Starter removal on '97 LTD
- Tranny cooler under truck?
- Pics from my car fire, and my new ride!
- removing '4x4' from mudflap
- another rough idle problem
- Question about steering gearbox
- New Trick learned when replacing Starter
- Any others have Addco swaybars on their 3rd gens?
- Brake Upgrade Complete - A Few More Questions
- Best place to get switched power for gauges?
- P0420 and then loping idle
- air bag tool
- Are CAPA certified body parts worth it?
- Quesions about air-box-lid mod
- crappy pics of my new paint
- broken stud on top of Donahoe coil over
- sway bar options?
- Clutch Components
- High Flow Cat Converter?
- Replacing rear shocks..any pitfalls?
- '94 3.0
- Running hot without heater
- Timig belt replacement.
- Need Help Now...Can't get Balancer off !
- 22re No Fire at Coil
- Too close for comfort to wrecking 3 slow head....
- EBAY Chips? Good or Bad
- seafoam in through TB?
- Looking For New Calipers [|]-----[|]
- Update on CV issues
- Can u disable traction control!
- cannot set timing
- Toyota Keyless Entry Remotes & Programming Instructions
- Opinions needed.. and an explination needed
- Another +99 headlight mod question......
- New pics!
- Best Place to buy a Radiator
- How to wire up back up lights???
- Build Up help/info needed
- 3zve fast idle problem
- 22re help (just did the timing chain)
- Cool toyota rig on ebay
- Less than a week old, ALREADY IN THE SHOP!
- Transmission question
- Patch Panels
- E-Brake light barely on, but there...
- TRD Supercharger for 2000 4Runner
- 2nd Gen electric (pusher) fan question
- Can't put back lateral control rod ... Help
- warn winch control box wiring diagram help!
- Ignition key sensor
- Turbo 94 3.0
- buying lifted vehicles
- 4runner is sold, now i have to find something...
- Cruise Control issue
- Badly warped rotors--Which rotors should I get?
- Removing grille on 2nd gen (93) runner
- Looks like I won't be selling my trucks after all...
- Got Alignment - Now Bad Vibrations
- How to bring the new 4runner home? QUICK!
- finally pics of the color matched grey stuff
- Need info on 3.4 Power Steering Pump PSI
- 4runner transfer case replacement cost
- Regular maintenance, what does that include.
- Need help with alarm... Lost transmitter ...cant start
- New Recall for 1990 4runners
- What do you think of this bumper?
- Is this really what a cat costs?
- rough idle at start 3.0
- 2wd tranny on a 4wd truck???
- Anyone know where I can find this part?
- 2 problems.. w/Pic... First where does this pipe connect on a SC install? 3.4L 99
- Rear disc break conversion for 3rd gen?
- any one know the weight of a 3.0 3vze v6 toyota 4runner engine ?
- Temporary exhaust mod problem
- Drag Link failure
- Dang The Devil
- Anyone know the nut size to sway bar link?
- tranny tranmission question
- Grinding on front driver tire after replacing the CV Axles
- Stolen Truck-denver Colorado
- 22re longevity
- TRD Headers and Exhaust
- New cheaper lift option.
- 2nd Gen Stainless exhaust option - JBA(K&N)
- idling low
- 1988 3.0 headgasket recall
- brake problems....
- 3.0 Valve adjustment
- 3rd gen MSRP
- 1988 v6 4runner tranny
- Install brake controller looking for cold brake wire..94 4Runner
- Combo of FIPK and Magnaflow - My Results
- rims
- Fan Clutch
- fast ticking sound in a 1988 sr5 v6 4runner
- Rev Limiters
- Help!? 22R Question
- clear lense pix?
- Need help with 96 LC...its really quiet on the LC board
- 32X11.50R15 MTRs
- Do you run high RPM?
- Meet'n' Greet in VA...
- hill climb....oops engine dies
- oli filter relocation bracket
- Distributor Problem
- Any changes between years on the 3.0?? PS pump question
- Advice for a smoother ride
- 2nd gen won't crank
- O2 sensor
- another wheel question
- Dexron II = ATF+3 ???
- Are there any 2nd gen aftermarket rear bumpers that work with fender flares?
- UGH! Why are people such idiots?!
- 1988 4runner, v6 vs 22re
- a couple questions about fj80 coil users...
- Thief broke into my 90 4runner-broken passenger side glass
- Oil Filter 90915-YZZD3?
- no more coasting?!?
- Rattleing sound from S/C, Took off nose cone and..
- Making a mold for the 2nd Gen Rear Cargo Area
- Head gasket warranty
- How easy is it to break into a 2nd gen 4runner?
- Strange overheating problem on 97 4Rnr
- SPINDLE QUESTION!! (parts interchange)
- Anybody seen these Cross Landers yet?
- Straight Piping
- NWOR SWAY BARS - what vehicle?
- What's your door sticker say?
- Rim to fender lip distance with 2nd gen OME HD springs
- Places to get a rebuilt transmission?
- Windshield Wiper Arms -- need replacing?
- Is this a symptom of shot/bad shocks?
- T-belt idler pulley/tensioner question
- Hit And Run
- Stock to Street Queen in 3 Months (Pics)
- hard to get into gear, tranny fluid?
- fuel capacity question...
- 2WD Question
- 22RE intake valve
- holy flying bolts batman!!!!!
- Transfer Case Compatable?
- 4x4 Vids
- Where is my anti-freeze going???
- Front-end vibration while braking
- new headlight bulbs
- Recall Still Valid? Any Help?
- new to site...just saying hi and asking a couple questions
- 4cyl parts, V6 truck?
- manual hubs
- How to affix a swing-away tire carrier to 4Runner?
- New Optima 34R Not Holding Charge
- Need wire diagram
- Clutch Cancel problems
- driveshaft length
- how to seal doors in a Taco
- Whats this clicking sound
- Fog Lights & replacement interior bulbs
- Wierd Lights... suggestions anyone???
- Need Advice! Transmission related
- 22re wont start help..
- leaking rear main seal
- K&N Airfilter Stolen!!!
- lubricant leak - lower A-arm of 3rd gen
- Interior Question
- inner CV leak... Heard a clink while driving...
- 5 speed. clunking noise in reverse.
- was rear-ended in my 1989 toyota truck today
- Fast and slow... my 3.0
- My 2nd gen is haunted...
- Why would the rear wheel turn when gear is in neutral?
- S/C oil question
- Spare tire Carrier for 3rd gen?
- noob's warranty question
- Tacoma TRD bilsteins
- 3rd gen overdrive q
- toyota warrant seatbelts?
- New Bridgestone Revos, finally.
- Any way to tell if a 4Runner has a rear locker by the VIN?
- Clutch pedal question
- Finally getting the 4runner I bought
- 22re problems
- Everyone loves cool toyota pics.
- Deckplate Mod and Rain?
- Backspacing question
- Where is the fuel filter on my 3rd gen?
- Does 3.4L V-6 have timing gears, or chain?
- Transfer case replacement in Toronto?
- Service manual CD
- ebay, clear turn signals
