S/C oil question
Old Oct 1, 2005 | 07:31 PM
TooEZgoin's Avatar
S/C oil question
How do you check if the oil level is low in your 2nd gen. supercharger?
Old Oct 1, 2005 | 07:41 PM
WATRD's Avatar
You don't. The nose is designed for a 100,000 mile service life before it requires a rebuild or service.
If you MUST muck around with it, you can follow the oil change procedure documented in this manual on the TRD site; http://www.trdusa.com/installMan.asp...-17620-228.PDF
Keep in mind that it requires you remove the supercharger to removed the nose...
Old Oct 1, 2005 | 08:04 PM
TooEZgoin's Avatar
What is the hex bolt for that has the painted seal on it in the front nose area?
Old Oct 1, 2005 | 08:09 PM
WATRD's Avatar
Take a look at the pdf sheet. That is where you fill the nose, but the supercharger has to be off the rig with the hex bolt pointing up. If you remove it with the charger on the rig, oil is going to flow out and you will be screwed.
Old Oct 1, 2005 | 08:39 PM
TooEZgoin's Avatar
Believe it or not I just went out and unscrewed the hex and no oil came out, and I could not see any pool of oil inside the gears.
The reason for my post is because 3 days ago my s/c started sounding like a coffee can full of marbles being spun around.
I have 200,000 miles on this s/c, most of it earned by towing a 2000LB+ construction trailer. I have never preformed any maintenance on the s/c.
Old Oct 1, 2005 | 09:20 PM
WATRD's Avatar
It sounds like you are due for a rebuild then TRD offers rebuilt nose assemblies on a core trade in basis. Take a look at; http://www.trdusa.com/installMan.asp...-17620-226.PDF
Old Oct 2, 2005 | 06:56 AM
TooEZgoin's Avatar
WATRD once again gets you the correct info that helps out. I have been off the board for almost 2 years now and am just getting back into taking care of my 97 Runner. Thanks!
Old Oct 2, 2005 | 07:09 AM
WATRD's Avatar
I am glad I could be of assistance.
Old Oct 2, 2005 | 08:15 AM
Localmotion's Avatar
I also believe people went here to do a rebuild http://www.magnusonproducts.com/
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
thefishguy77
Jul 30, 2015 10:59 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
