PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 3.4 spark plug tube grommets
  2. 99 Runner problems
  3. P0136 - O2 sensor front or rear?
  4. won't start 3 days after cat converter stolen
  5. airbag code b1100
  6. 4WD transfer box actuator replace problem 4R 96
  7. RPMs Hunt (fluctuate)
  8. Gas cap seal/rubber O ring ?
  9. 3500 rpm idle. need help
  10. throttle Lag
  11. 1 of a kind 4R: shock recommendation, very light 3rd gen
  12. fast idle after maintenance
  13. 2002 supercharged tacoma w/URD 7th injector kit
  14. Valve Cover Gaskets
  15. Which oil for a TRD supercharger?
  16. OME lift installed with pics
  17. Goodbye Taco
  18. Safety-wired ball-joint boots?
  19. Mpg:Rpm:any answers?
  20. New motor/supercharger with high temps
  21. 3.4 V-6 engine hoist hooks?
  22. after engine rebuild, clutch problem
  23. Tranny Cooler Install Problem
  24. Keyless entry remote ?
  25. radiator leak 1999 V6
  26. Loses Power, Revs down..electrical??
  27. Installing a B&M 70268 and have a few questions
  28. 01 taco 3.4 tune up
  29. Please help....OME lift problem...
  30. CV joint shake/balance
  31. Automatic Gear Shifter won't come out of park without rocking the car
  32. clutch chatter
  33. 3rd gen 3.4 generator plug
  34. S-10 bumper retrofit???
  35. Expedition backup gear/equipment?
  36. towing a 4wheeler
  37. LCA Bushing Replacement?
  38. P1300 Igniter Issue? Fire then Random Stall
  39. 3rz with auto tranny questions
  40. Best way to drain gas / fuel tank
  41. 97 4Runner rear suspension
  42. Brakes applying without pressing the pedal
  43. Love my ride
  44. '99 4Runner Starting Issue
  45. 1998 4Runner 3.4L alternator swap
  46. 2 Questions about interior of truck
  47. P0304 Please HELP
  48. Scion T1808 head unit install
  49. '98 4runner with bad supercharger
  50. How many feet of how much vacuum hose?
  51. Where does the tachometer signal originate?
  52. Weird clutch problem
  53. 15" rim with Tundra brakes
  54. 99 Tacoma no start after deck plate + throttle clean
  55. Takes a lickin and keeps on Tickin
  56. Wipers turn on when it rains/washer fluid no longer comes out
  57. Passenger Side Power Dock lock not functional-help?
  58. Blue CLOCK conversion: How to (ish)
  59. throttle body sensor #89452-35030
  60. APX Shock/Struts - anyone out there running 'em?
  61. P2118 / etcs
  62. CEL, TRAC/VSC & VSC OFF lights all came on!
  63. seafoam treatment question
  64. I Screwed something up
  65. skidplate bolts
  66. squealing noise when releasing the clutch in 1st gear?
  67. Split second FTC1??
  68. Did Toyota offer clear rear glass for Gen3?
  69. how to test crank sensor and cam sensor?
  70. Calif Trip, 4runner goodies and other finds
  71. Transfercase shifter gasket
  72. fluid coupling?
  73. 2000 4runner transmission prob with video.
  74. Alarm ECU missing!
  75. Transmission flush with pan drop
  76. Fuel pump wiring
  77. Can't get her to start!!
  78. Sheered off tension bolt on idler pullery..
  79. P0306 Misfire Problems
  80. My Radiator
  81. Lower Differential Mount Stopper Part Number
  82. 02 4runner 2wd code p-1135 trac off/vsc trac fixed
  83. New OEM 906 coils 1/2 difference in height?
  84. just stalled and wont start 97 4Runner 3.4
  85. P0505- Idle Control Malfunction
  86. Gas door stuck closed!
  87. '97 4runner SR5 3.4L V-6 v-belts
  88. York on a 3rd gen?
  89. P0171...DESPERATE, PLEASE HELP! Mechanic dont know
  90. Where can I get a few of these?
  91. Anyone replaced transfer case actuator on Tacoma?
  92. manual hub conversion complete
  93. Tundra Brake Upgrade FAQ
  94. Aftermarket tachometer
  95. check engine light issues
  96. 1996 tacoma 5vzfe to 2002 4runner 5vzfe
  97. 3rd Gen Trans cooler plug came out?
  98. tailgate interchange?
  99. Problems with '99 Limited digital climate control - only display, or compressor?
  100. my 97 4runner needs freshened up a little
  101. Trouble starting from cold start after plug/wire replacement
  102. 97 4runner steering issues
  103. LED tail lights, brake light yes, tail light no
  104. 3rd Gen O2 Sensor Information
  105. P0171 System to lean (Bank 1)
  106. 2.7l Transfer case gears Qs
  107. Throttle cable disassembly
  108. 4th cylinder is at 145psi in my 98 4runner. How screwed am I?
  109. 1996 Tacoma engine replacement - which years will work
  110. 4Runner Frame Rusted Through...Now What?
  111. Replaced fuel injectors, now throwing multiple CELs...
  112. 2002 4Runner dash electrical issue
  113. Replace fuel pump or sending unit? 96 runner
  114. timming belt tool ? 97300
  115. Got my new bumper, What to do with my exposed turn signals
  116. Head Gasket Replacement
  117. Help with URD short shift kit?
  118. 2.7l 3rzfe blow by
  119. Strut assembly problems (aka "How I got my struts assembled for free")
  120. Replacing Seat foam?
  121. Need info advice on where to buy new shocks - Wifes 96 4runner
  122. weather radio options?
  123. Simple Brake Job Gone Wrong
  124. 01rnrgirl's 2001 4Runner Build-Up Thread
  125. 1998 4Runner 3.4L w/TRD Supercharger
  126. Aftermarket UCA and Shocks - Squeek? Noisy?
  127. 3.4L white smoke on start up. Block test negative.
  128. 99 4Runner Brake Booster
  129. Another OME Lift, with pics.
  130. Bumper rust
  131. Buying a 2004 Tacoma & have ?'s
  132. Metal Shavings in oil passage
  133. Code P0304 Misfire Cylinder 4
  134. Timing Belt Replacement Gone Wrong
  135. Removing rear catalytic converter, legal?
  136. quick 4runner rear spring question
  137. Help.... headlights don't shut off
  138. Recall discussion /Frame Tacoma
  139. '99 4runner transfer case vacuum line?
  140. 3rd Gen 4Runner snorkel... Surprise!
  141. Horn and cruise cntrl quit working.
  142. TRD S/C, URD 7th , FTC issues boost hose?
  143. Alternator question.....
  144. need AC tensioner bolt pn
  145. Towing a 4runner behind my RV ?
  146. 150k miles - Getting valve cover gaskets - what else?
  147. Front differential seal replacement; shaft slop
  148. Help Identify this Part
  149. Supercharger /URD pully 3.4L V6
  150. 98 Tacoma Stock Height Question (pics)
  151. coolant leak
  152. H.I.D. Help
  153. Finally back on the road
  154. Tacoma bed load capacity? New Shocks?
  155. How to test MAF 2000 4runner
  156. Calling all 3rd Gen 4runner owners!
  157. complete electrical power loss
  158. New Front Bilstein Strut Noise on 97 4Runner
  159. Excessive Play??
  160. cheap exterior thermometer
  161. plug n play hid kit only works on hi-beam?
  162. Noob ZUK mod on '96 Taco
  163. Supercharger questions
  164. 03 Tacoma, broken axle
  165. simple question bout 4wd engaging/disengaging
  166. Bilstien Shocks and Struts
  167. Climate Control Issues
  168. Engine swap thread, need help
  169. my 4runner before/after pics
  170. Dual Batteries - Factory Bracket Hold-down
  171. A/C will not turn off on 03 V6 5sp Taco
  172. Slow slow slow starting...
  173. Probably an Easy Question..
  174. Need bolt for 2nd generation supercharger
  175. 2001 4Runner Instrument Cluster Light Replacement
  176. Engine Mounts
  177. A/C oil
  178. Marley2984: A rigs mid life crisis - Build thread on a quest for 500,000
  179. Pulling engine on 98 3.4 4Runner
  180. Positive/Negative wires for front speakers
  181. Quick question ? will seats form a 2002 4runner limited fit my 2000 4ruuner SR5 ??
  182. No Reverse
  183. Rear/Back Side Window/Glass Replacement
  184. how do i adjust the master/slave cylinders on my 2000 4runner 5speed?
  185. P0305, replaced plugs/wires and swapped coil packs, but CEL still there...
  186. OME 881/906 installed - pics inside
  187. 5VZE vacuum diagram
  188. Internal head gasket leak, mechanic recommends engine replacement?
  189. 4wd blunders
  190. Trans problem on 98 4runner 4X2
  191. Gforce chip or supercharger booster?
  192. 4Runner Wheel Locks Q
  193. Hot CV axle/joint. Help!
  194. NEED TO REPLACE WOODGRAIN PLASTIC STUFF AROUND RADIO & AIR VENTS etc...HELP!!
  195. really toyota?
  196. Will 2011 20" limited rims fit 2000 4runner?
  197. A little problem with my coil spring job
  198. 5vz coils?
  199. Thanks Penzoil for destroying my oil pan
  200. Just got a 97 4runner for $1200, and im new around here!
  201. Replacing Valve cover gaskets again?
  202. Walbro fuel pump question
  203. Need a quick measurement
  204. Bilstein HD Shock Install- Correct?
  205. 2000 sr5 4runner front end vibration
  206. JBA Headers for 4Runner
  207. 2000tacoma 2.7 4x4 5speed bucking
  208. Doesn't recognize being in Park
  209. Power Window Issues
  210. Front Differential Maintenance Issue
  211. Transfer Case Issue
  212. Need input-4Runner quit on me
  213. 200,000 cooling system replacement items
  214. Mass air flow on a 97 4RNR
  215. 3.4L dilemma.. Kinda long
  216. Power Mirror Swap for 98 Tacoma?
  217. 2nd gen 4runner fuel tank as aux tank on a 3rd gen 4runner
  218. Another rousing game of "Name that sound"...
  219. 3.4 Engine replacement
  220. 02 sensor help just need some quick confirmation
  221. Coil Pack Issue
  222. 99 Tacoma 4x4 3.4L stalls/unresponsive at 3000 rpms
  223. engine dies after WOT
  224. What seats are you running?
  225. A/C Help Please!
  226. Cheap brake parts and paying the price
  227. 2000 4X4 v6 trans problem, have questions, need advice
  228. Third Going Bad - I'm pretty sure
  229. 4.56 vs 4.88 5 speed 3.4 with 33's
  230. 03 Taco overheating with 3.4L
  231. TRD Transmission Cooler P/N
  232. Rough idle 99 tacoma
  233. Transmission drain plug stripped
  234. Interested in Trans cooler
  235. External head gasket leak on 3.4L
  236. New to the forum, few questions
  237. RPM Issues
  238. How do I fix this? (pic)
  239. i want more lift
  240. Replacing Coil Boots part of PM?
  241. Denso Iridium w/40K Miles - '97 4Rnr V6
  242. 03 Tacoma #2cyl low compression.
  243. No 5th or reverse
  244. Opinion Coil Brand?
  245. Occasional grey smoke on startup? 2002 4Runner
  246. Tightening E brake?
  247. Head Gasket issue or?
  248. When its HOT outside.. Power Door Locks Dont Work.. help!
  249. HELP with wheel selection
  250. Way to advance timing on 5VZ-FE?
