Got my new bumper, What to do with my exposed turn signals
2001 4Runner SR5
So I installed my new Savage Off-road bumper and overlooked one major thing. What am I going to do with my turn signals that came out of the stock bumper? Here is a picture of what I was thinking, but couldn't quite find the correct application of a fully enclosed sleek turn signal.
http://www.flickr.com/photos/57092665@N03/6006153593/
Any idea where I can get a two wire fully enclosed LED turn signal with a "L" bracket? I looked on autolumination but they had ones with 3 wires "dim" "bright" and "ground" which is not what I need, or can I just not hook up the "dim" wire and let it go?
http://www.trail-gear.com/bumpers the led turn signals on here might work for you
I like that idea, thanks for the link. Not that mounting a turn signal to the bumper is bad or even looks bad but the less breakable stuff that I have on there the better. Thanks guys.
if you convert to dual element bulb (1157A) like I did, you don't loose anything. Or you can just make another hole for the original bulb and run two bulbs. IMO running an 1157 is a cleaner solution.
Im assuming I will have to get the 1157 base to convert from the 7440 for the turn signal. Then retrofit the dual element for the marker light and the turn signal making them one connection? That is how this is playing out in my head.
Jumper - Like this for the corner markers. You keep your original wiring and bulb, just drill a 1 - 1.5 inch hole just underneath the one that is there now, place your bulb in, you will have to secure it in place (I used 2 zap-straps) but to keep water out, you could use silicon.
Excellent!! Can do. Thanks for the pics
Just finished. Happy with the result. Here is a video with the hazards
http://www.flickr.com/photos/57092665@N03/6012851994/
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
