how to test crank sensor and cam sensor?
Old Aug 17, 2011 | 01:51 PM
Dead_Runner's Avatar
hello everyone, I'm new here to this forum and hoping you guys can help. My girlfriends parents have a 2000 4runner 4cyl. that won't start. One day it would just not start, it would crank and turn over but won't fire. All fuses are good, so I want to check coils, cam, and crank position sensors but havent for the life of me found resistance specs to test them. I know they probably have haynes manuals but I'm trying to save t he m as much money as I can. You guys have any numbers for resistance and which writes to probe? Any help would be greatly appreciated! Thanks in advance.
Old Aug 17, 2011 | 01:58 PM
I'd like to add that I've been looking all day and haven't found much. Perhaps I just didn't look in the right spot. If you guys could point me in that direction, that would be great too! Thanks again
Old Aug 17, 2011 | 04:18 PM
eric924run's Avatar
plug on of the coil out and put a screw driver in the hole where it would go on the plug. hold it by the plastic near some metal maybe 1/8-1/4in gap. have some one crank the motor and look to see if its sparking. problem could be fuel, spark, or compression. Also when cranking does it sound normal.
Old Aug 17, 2011 | 09:20 PM
TheDurk's Avatar
http://www.ncttora.com/fsm/1996/SIL/.../crps/insp.pdf
and http://www.ncttora.com/fsm/1996/SIL/.../ignsy/ovi.pdf
Old Aug 17, 2011 | 10:10 PM
I was going to try that eric. And durk, is that second link you posted for the cam sensor? I downloaded it but it said its corrupted or damaged. possible you posted a bad one our wrong one? The other one for the crank is perfect! Thanks!
Old Aug 17, 2011 | 11:14 PM
TheDurk's Avatar
I just clicked it and it works for me. Yes, it's the cam sensor on page IG-5, plus other good stuff. Go here:http://www.ncttora.com/fsm/1996/SIL/fsm/repair.html and scroll down to Ignition: On-Vehicle Inspection
See if that works.
Old Aug 18, 2011 | 09:52 AM
I went to that website and got the full manual. Thank you so much for your help durk!
Old Aug 18, 2011 | 02:14 PM
TheDurk's Avatar
Yikes. I just noticed you have a 4Banger. I sent you to the 6 cyl FSM. ncttora has other FSM's that should cover your motor.
http://www.ncttora.com/fsm/index.html
The Tacoma FSM they have covers the 3VZ-FE.
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
thefishguy77
Jul 30, 2015 10:59 AM
cgilley
Jul 25, 2015 10:55 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
