P0171 System to lean (Bank 1)
Old Aug 6, 2011 | 03:17 PM
sigley0527's Avatar
Im new to the site...I've done lots of research on this but still dealing with this frustrating problem.
I own a 2000 4runner Limited 3.4. I'm doing my best to learn about my truck to the point where I'm able to do general maintenance repairs on my own.
It all started a couple weeks ago when my check engine light came on. I went to autozone and put in on the computer. P0171 System to lean Bank 1 and P1135 A/F sensor heater circuit.
From what I researched majority of the time P0171 is due to a dirty MAF sensor or possibly a vaccume leak. I also figured it could be a "side-effect" code to P1135. My buddy is a mechanic and he helped me clean the MAF sensor...we also checked for a vaccume leak and found nothing. We reset the computer and about 3 blocks down the road the light came back on...P0171 and P1135.
Time to replace A/F sensor figuring this would be the fix. I went to Toyota and bought one and replaced it. Reset the light again, I thought I was home free. After 20 miles the light came on again. P1135 is gone but its still showing P0171. I have no exhaust leaks, no vaccume leaks, clean MAF sensor, and new A/F sensor. I just want to know if there is any other route I can exhaust before I replace the MAF sensor...Thanks for the help in advance.
Old Aug 6, 2011 | 03:25 PM
cpizzle42's Avatar
How did you clean your MAF sensor?
Do you have stock intake? Is the filter clean?
Old Aug 6, 2011 | 03:26 PM
sigley0527's Avatar
I forgot to mention that my truck runs completely fine with the check engine light on. No idle/acceleration/bogging problems at all.
Old Aug 6, 2011 | 03:27 PM
sigley0527's Avatar
We cleaned it with electrical cleaner. Yes I have a stock intake...and the filter is pretty much brand new. Replaced in less than 2 months ago.
Old Aug 6, 2011 | 03:39 PM
ToyoTech559's Avatar
did you spray and clean down the tube of the maf? not just the tip.
Ktm526
Oct 7, 2015 05:14 AM
Rickstwowheels
Sep 9, 2015 06:12 PM
shalom
Sep 8, 2015 10:02 PM
some drunk guy
Sep 4, 2015 11:55 PM
moparbay
Sep 3, 2015 12:48 PM
