PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. MAF sensor expected output?
  2. 3.4L timing belt idlers
  3. Just some things i want to know
  4. Check engine light is on. What to do now?
  5. Okay, I did the swap, need fine tuning help
  6. Question about my 3rd gen
  7. Help-White exhaust smoke??
  8. Optima battery life.
  9. Gear Noise?
  10. Went wheelin today, pics
  11. 4Runner Series Chronology.....
  12. pics of my carnage from today
  13. Help- Need Quick Advice With Stripped Head!!!!!!!
  14. Gear question
  15. My camping bed set up thingy
  16. Hurculined my 97 grill and limited flares (pics)
  17. What gears should i do???
  18. Shocks not staying tight ?
  19. 89-95 Front Bumper on a 87 Pickup??
  20. CD Player up and stops working??? Help!
  21. paint grille or bedline it?
  22. T -stat sealant,and or cleaner neccessary?
  23. more knock sensor drama
  24. Before and after (2nd Gen. budget lift)
  25. Engine ticking when cold 2.7L 2000 Tacoma
  26. Redline differences, 22re and 3.0?
  27. 22r head gasket qustion
  28. 22r build question
  29. 3rd Gen Steering wheel vibration (68-70 mph)
  30. Cleaning/timing/head
  31. front diff install/ removal
  32. new motor help?
  33. 1st gen short shifter?
  34. ID these aisin hubs
  35. holey tire !!!!!
  36. Knoxville Bandag - Sidewall Tire Repair!
  37. Am i regeared?
  38. spring break buildup
  39. VERY weird clunking noise coming from rearend.
  40. my seats suck need ideas for replacement
  41. Day time Running Lights
  42. Friend's Tacoma Won't Start
  43. 285's are on, problems encountered!!
  44. '98 Taco Dash Access
  45. Ignition Cylinder removal?
  46. Polyurethane body mount bushings?
  47. Head Bolts
  48. Suspension Upgrade
  49. How to install an 86 4Runner dual stage thermostat and gasket
  50. Hood scoop assembly ??
  51. APEXi SAFC wiring
  52. Help! Got brakes apart but rotor wont seperate from hub/bearing!!
  53. RPM limitations of the 3.4L
  54. How LEAN is too LEAN??
  55. 86 toy transmission & carb question/advice
  56. Downey or OME sag??
  57. Cracking Exhaust Manifold
  58. New 4Runner Lift Question
  59. Need Help Asap
  60. Kinda Urgent.. In middle of radio install, WTF is this?
  61. Rocker switch part number
  62. Complete Suspension Replacement?
  63. A rare fast 3.0?
  64. best place to buy spacers
  65. diff spark plugs on each side?
  66. Gas prices in your area
  67. Which gears to compliment 31-33" tires?
  68. AM SO IL confused, AGL FGR or SVG
  69. Tube size of TRD Catback?
  70. Complete auto trans flush
  71. Another EGR Question
  72. Another Timing Chain......Damn
  73. CEL came on = code 11: Possible Causes?
  74. 3rd Gen rear lift question
  75. 22RE Idle setting
  76. AAL install, need longer brake lines?
  77. how do i disable the pwd attenna (fuse?)
  78. ring pinion 4runner
  79. Searched the tech section: Suspension
  80. 2nd gen 4runner front end question
  81. Best 22r-re donor for motor build project?
  82. 4Runner fender flares options?
  83. 4WD sometimes won't engage
  84. Why was the 3rd Gen never Lexus worthy?
  85. 2nd gen. Runner engine swap
  86. Changing wheels--anyone see a problem with the offset?
  87. What gas should i be using?
  88. Replacement Pedels?
  89. HG's and Bolts what else?
  90. Ball joint replacement
  91. Suspension Q on my 84
  92. Engine questions for the 3.0
  93. Rear window & regulator removal...
  94. Factory e-locker button
  95. If You Want To Wheel In The Future Check This Out
  96. 99 4runner fog lights
  97. Bilstein Price
  98. will a sitch fit here on the dash?
  99. 22r spits and sputter during the rain
  100. E Brake Blues
  101. Axle Codes
  102. Cruising @ 3300......will it hurt?
  103. Lifting, should I document?
  104. 4Runner Dash any different within Gen 2 models
  105. Exhaust Tips? '95 4-Runner
  106. People of Yotatech, I need your help finding a new washer fluid box.
  107. yet another prob..wont start
  108. Poor Man's Bead Locks
  109. How much could I ask for my little pickup?
  110. Rotor problems; Get new or machine??
  111. slight noise when turning wheel and during driving
  112. 4wd not working
  113. Many issues with 97 4runner! HELP!!!
  114. CAGED - 1988 4Runner
  115. 22RE pinging dillema
  116. Front brakes on 93 4runner 2wd...what the heck?? Help
  117. Interior Carpet Dye
  118. WRITEUP- How to install Hella 500 lights
  119. Major repairs - what have you had to replace?
  120. my new sliders
  121. 22R-RE, How many Quarts of Oil?
  122. Low Compression Help (long)
  123. looked under my truck to find....
  124. well, my waterpump took a dump
  125. Shocks compressed when shipped?
  126. Dash Repair (Pros & Cons)
  127. Puddle of 80W-90 - oh joy!!!
  128. Might be Selling the 4Runner (what should I do?)
  129. Interior capability
  130. Turn Signal ?
  131. 17X9 or 17X8 rims???
  132. Look how cute my twins are!
  133. Dana 44 4Runner (99) -VS- Tundra Coil 4Runner (96)
  134. Leaking front differential
  135. Black soot on dash
  136. Driveshaft help
  137. Tires...
  138. another electrical problem
  139. Earl Scheib question
  140. Accord vs 4runner Tint $$
  141. Silver_truck's top head rebuild
  142. New Gauge Cluster-Odometer Adjustment?
  143. 85 22re Engine sputtering?!?!
  144. Anyone installed Dynamat Hoodliner?
  145. good deal on 2001 sr5 sport??
  146. 85 22re fuel filter
  147. ce light
  148. ABS light after collision?
  149. Disconnecting auto transmission
  150. I sold my 3G!
  151. Denver Wrench-a-thon
  152. Bushings
  153. Where to buy stock height front replacement springs?
  154. Torque Converter Lockup
  155. Anybody Interested in an 85 4runner in D.C. Area
  156. 3rd gen budget lift
  157. Chrome vs. black price.
  158. YAY! OME should be here on Friday!!!
  159. 3rd gen Tires VS. Fenders
  160. Coil springs
  161. 200,000 mile club!!
  162. Help with Fog Light Switch
  163. rear wheel bearings
  164. seat covers
  165. keeps on rolling
  166. trouble accessing U-joint zerk
  167. Badlands edition
  168. '05 tacoma trd decals
  169. Funky sounds from the 3.4....normal?
  170. Safe Hi-Lift Contact Point for A 3rd Gen?
  171. Need help with a 84
  172. Safety Recall Campaign: SSC 20A
  173. knock sensor part number??
  174. reupholstering my interior soon.......
  175. rebuilding my 82's front axle
  176. NEED U-bolt bottom plate 85 solid axle!!!!!
  177. 3rd Gen 4Runner - Safest SUV
  178. Is this the correct grease for chasis lube?
  179. Finally uploaded pics
  180. Any A340F experts out there?
  181. Lift Lift Lift
  182. 22re problems
  183. pics of fogs on stock bumpers?
  184. need some rear suspension advice
  185. OME for 2nd Gen. Pickup
  186. Best Way to remove Broke bolt????????
  187. 4.88s are in - my reaction.
  188. Sea Foam Treatment Now Wont Start
  189. Here we go again! ('80 Toy pickup)
  190. Yakima Mega Warrior Users Please Help
  191. leaking rear end
  192. bad camber with bj spacers
  193. Transmission Solenoid problems
  194. Speedometer cable replacement... HOW TO....
  195. 4Runner Value question
  196. What does a good paint job cost?
  197. Used Neutral Safety Switch?
  198. Body parts
  199. Anyone have a simple write-up to remove rear license plate trim?
  200. Milage question for a 87 2.4 EFI?
  201. Should I Paint my Bumpers????
  202. Shift Point(s)
  203. Thinkin about sellin the rig
  204. 3VZE vs. 22RE
  205. New guy!
  206. Fan Clutch Question 3.0 V6
  207. Electronic speedo, what year did they start?
  208. 3.4 L swap...help lpease
  209. Sometimes Revos and locking diff don't matter (pics)
  210. 3.4 Swap: BL or Cowel hood?
  211. Engine issues
  212. 7th injector?
  213. Schools of thought - warming up & the clutch
  214. Wich MAF to use?
  215. 10% OFF RETAIL @ Toyota
  216. New Member
  217. D-ring shackle tow hitch question
  218. 3vz-e head gasket
  219. Another New Guy w/ questions
  220. Weird...??
  221. Swaped CV's, still hearing noise
  222. Got my first 4runner!!!
  223. Too many volts!!
  224. Cleaning a spray gun after use of bedliner
  225. Reverse Shudder
  226. installed extended studs for top-out spacers?
  227. Smog Test Failed - Need Help
  228. 3.4L Acting Strange - Any Ideas?
  229. help me with cat please
  230. Where to buy OME
  231. CEL and O2 sensor
  232. Automatic Shifter Replacement??
  233. Confused on tacoma bed size....
  234. Engine Replacement Questions
  235. Shifter problem...
  236. some info with body lifts for a 1999 4Runner
  237. Odd noise on the freeway today...
  238. Rattle can Desert Dune and/or oak color?
  239. who in Seattle has extended brake hoses
  240. Need your knowledge RE: roof mount CB antenna
  241. 3L to 3.4 SWAP info
  242. Identify The Body
  243. '94 4-Runner Lifespan?
  244. Hays clutch
  245. Pinion Flange Orientation Question
  246. Problem solved
  247. asleep at the wheel
  248. Should I, or shouldn't I???
  249. 30x11.50x15 on a 15x8 rim
  250. OBDII scanner and AFR
