3.4 L swap...help lpease
Old Mar 15, 2005 | 04:55 AM
wheelerz's Avatar
Hi,
I'm looking to get this swap done (not by me)... I have to see how much it will cost me. What are the parts that I will need to buy. Reading some info on it it seem that people have different opinions.
I have found a 96 3.4L at a low price for me 93 Truck (manual).
I know I'll need :
Engine
ECU
Wiring Harness
What else should I add...
I have read ...
Flywheel
Clutch
__________________
Toyota PickUp 93
V6 3L
3 inch BL
BF GR ATKO
Old Mar 17, 2005 | 08:42 AM
wheelerz's Avatar
I guess nobody did that swap
Old Mar 17, 2005 | 09:34 AM
SEAN_at_TLT's Avatar
Have you tried the search function? I personally have posted a lot of info on this exact swap as have many others. There is a lot of great info ut there you just have to look. Also try the 4x4wire.com forums a few guys over there pioneered this swap. Off-Road Solutions in Colorado makes a great selection of kits for this swap ranging from just a wiring harness to everything you need so call Mike and pick his brain and at least get their wiring harness kit because that is the hardest part to do on your own.
Good Luck!
Old Mar 17, 2005 | 09:46 AM
MTL_4runner's Avatar
Good Luck!
Ditto.....there is tons of info and links on here already on this same subject.
Search...
https://www.yotatech.com/search.php?...7&pp=25&page=1
.....then you find threads like this.
https://www.yotatech.com/forums/show...ight=3.4l+swap
and there are tons more....time for some more reading.
Old Mar 18, 2005 | 08:30 AM
wheelerz's Avatar
Yeah I have read those posts. the only thing is some say you need to buy one thing like exemple flywheel and in another post they say they used the same flywheel. Anyways I'Lll have to do it to see what will happen.
thanks for taking some time for me.
Old Mar 18, 2005 | 09:04 AM
wheelerz's Avatar
From what I've read alot of people didn't use ORS kits.
What are the differences between years of the 3.4L. Will it be easier to convert if I get an older model (ex: 1996) ??
Old Mar 18, 2005 | 09:51 AM
You are right, quite a few people did their own wiring.
The major changes happened in 99, so 96-98 are basically the same motor and 99-02 slightly different.
Not sure either would be easier to convert but the older motors might be cheaper with more parts available.
Old Mar 18, 2005 | 12:28 PM
UKMyers's Avatar
There's gobs of info out there on that swap. The ORS webpage tells you pretty much everything you need to know. If your a wiring genius you can mabye do your own harness. I know I would'nt want to do it though.
Old Mar 22, 2005 | 08:57 AM
wheelerz's Avatar
I got the 96 motor !! but now no ecu and harness... for ecu do i have to get more then a 96 manual ECU... ? the guy from toyota told me theres alot of options.
Old Mar 22, 2005 | 09:47 AM
I would suggest to pick up an ECU from the same model year if at all possible (at least 96-98).
If you have a 96 manual ECU, you should be just fine.
Old Mar 22, 2005 | 11:31 AM
You need an ECU that matches the motor. So yes ideally you would use an ECU from another 96 manual but like Jaime said, you might be able to get away with an ECU from a 97-98 also.
Old Mar 22, 2005 | 02:10 PM
wheelerz's Avatar
thanks for the answer.. the guy from toyota said i needed alot more then just that.
Old Mar 23, 2005 | 12:38 AM
koyota93's Avatar
I might have an extra wire harness I can get rid of. Its out off a 1997 Limited 4Runner. I got the engine, but the harness is different from mine cuz of 4wd, so i should have a complete extra harness, let me know if you want it.
Old Mar 23, 2005 | 12:13 PM
wheelerz's Avatar
I have a 96 engine. I don't know if it will be ok.
Old May 4, 2005 | 12:14 PM
wheelerz's Avatar
where can I find a diagram of the wiring ?
Old May 4, 2005 | 12:16 PM
In the Toyota factory service manuals is your best bet. You will need both manuals for the donor and your truck.
Old May 4, 2005 | 12:19 PM
wheelerz's Avatar
yeah I know but I think toyota sells it for 300$. Someone (I can,t remember where) said he paid ona website and got it from there...(download).
I can't remember the site
Old May 4, 2005 | 12:22 PM
wheelerz's Avatar
http://techinfo.toyota.com/
Steven.m.paulk
Jun 7, 2020 10:45 AM
primordialbeast117
Dec 19, 2015 12:23 PM
White Stripe
Oct 6, 2015 10:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
83
18
Sep 21, 2015 06:15 PM
