installed extended studs for top-out spacers?
Old Mar 14, 2005 | 05:49 PM
ianshoots's Avatar
Hey gang, the OME's finally arrived and I am assembling the bamachem suspension special. My question is, after you pounded the extended studs in and went to re-asseble everything, did you use loc-tite as per the Rev-Tek directions that Andy links too, or not. I have some, but wonder if loc-tite will mess up ny-lock nuts.
Bring the knowledge.
Old Mar 14, 2005 | 05:55 PM
User 051420's Avatar
I didn't use any locktite. It's not necessary, those studs shouldn't spin. Good luck!!!!
Old Mar 14, 2005 | 06:00 PM
ianshoots's Avatar
I take it you didn't use any on the nut that holds the shock assembly together (the single one in the middle, can't think what its called...)
Old Mar 14, 2005 | 06:05 PM
Nope. I've heard of the 3 nuts on the studs coming loose tho, so maybe loc-tite them? I didn't.
Old Mar 14, 2005 | 06:16 PM
ianshoots's Avatar
Yeah, I wasn't gonna put it on the heads of the studs, but on the nuts (I can wait on that since its too cold for install). You didn't put it on the nut that goes on the shock shaft?
Old Mar 14, 2005 | 06:26 PM
waskillywabbit's Avatar
If you use loc-tite, don't use red cause you won't ever get them off if you need to...use the blue...and it now comes in a nice and easy to use "chap stick" type application, which is much less messy than the liquid tube stuff.
Good luck.
Old Mar 14, 2005 | 06:28 PM
ianshoots's Avatar
No red? bummer, looks like I might have to wait until morning to finish assembly.
Do you guys think I can get away without using it, particulary on the nut on the shock shaft?
Old Mar 14, 2005 | 08:39 PM
ianshoots's Avatar
Thanks for the input fellers, they're all together now.
I'd rather ask a lot of dumb questions now than have something go wrong for a dumb reason later.
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
terminator
Jul 27, 2015 07:13 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
