PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Dishwashing liquid in coolant
  2. Another Header Question
  3. explain this to me...
  4. Electrical Problem
  5. tires i want to get
  6. Help! Gas leak - can I replace this hose? *pics*
  7. Vortex is on
  8. G52 Vs G54
  9. Downey vs. NWOR 3.0 headers - also Thorley
  10. 3.0 & 3.4 compatability
  11. Power loss in 2k rpm band?
  12. letting the truck sit with tires almost flat
  13. Check out what I stumbled upon...
  14. Crossover pipe install
  15. newbie electrical question on fuses
  16. 3.0 bracket placement help...
  17. E-locker designated in the VIN number?
  18. would this free-flow cat help w/power?
  19. Getting upper ball joint back into the arm? (mod edit): bleeding brakes
  20. 87 yota tranny options. I need tranny, what all will work. Stock is g52
  21. 01 Highlander Repair manual?
  22. Engine cooling question
  23. Rhino lined 4runner,doesn't look bad
  24. Noisy Transfer Case!!
  25. Chevy swap starting tonight - Have a few last questions
  26. Header question
  27. 22RE Tech Question - Lengthy Warm-up Idle
  28. beach buggy?
  29. New User just bought a pickup
  30. I know the 4Runner is not a race car...
  31. torn balljoint boot. where can i get one.
  32. Looking for mating ECU connectors
  33. Got Motor Mounts???
  34. A few Tire Questions
  35. Batteries???
  36. 32X11.5 R15 tires
  37. Did 1985 4Runner have IFS as option?
  38. Hooking up fog lights and turning on w/o turning on headlights
  39. 05 Tacoma mods
  40. Adjusting the mass airflow sensor
  41. would you complain?
  42. Just bought a '97 4Runner!
  43. Rear Main Seal Replacement
  44. Salvage Yard Location
  45. This is an 89 toy that would make Mama proud!
  46. New member with 85 Pickup
  47. Deck Plate vs. ISR?
  48. just ordered "Auto Back Pack"
  49. Resolution for missing 22RE?
  50. Superjoe's EFI conversion thread
  51. 3.0-engine loping
  52. Calling those with Orient Engines
  53. New Bed
  54. PreRunner
  55. cold start injector
  56. dampening compressor vibration
  57. Observations on the Deckplate mod....
  58. Ne4roc.org
  59. Just ordered my Magnaflow 18" for $59, free shipping.
  60. 2nd Gen Air Box
  61. 22re low RPM problems
  62. which driveshaft will work?
  63. squealing belts on 92
  64. 88 4runner tranny swap???
  65. Fog lights /fuse box
  66. Hello. First post: Should I buy this '87 4Runner for $1000/OBO
  67. Just bought my 2000 SR5
  68. OD not engaging???
  69. Headgasket Puzzler
  70. Power Antena Problem
  71. 1990 4runner O/D Light Flashing????
  72. Conferr Roof Rack Hilift Bracket Pictures
  73. Truck broken into
  74. Strange/loud noise since new lift/tyres
  75. Bumper got bumped
  76. 22r truck engine into a 20r 77 celica body?
  77. Help- grinding Noise?
  78. What adapter do i need for an aftermarket oil pressure guage
  79. 3rd Gen factory foglight wattage
  80. Bumper Guard/Light Bar for '96 4Runner
  81. Injector cleaning
  82. AC Refrigerent Question
  83. Looking for a good mechanic in Denver
  84. fender flares
  85. My runner was in a Hit and Run....
  86. pulsing brake problem
  87. Help with cam
  88. Freaking paint code
  89. URD selling three 3.4 Superchargers on EBay.
  90. Too much grease in the driveshaft???
  91. 3rd gen dual HID setup?
  92. 1995 sr5 engine question
  93. painting the top of a 1st gen runner?
  94. idling and suspension??
  95. need pics of drawtite hitch on 3rd generation 4Runner
  96. ARB is on the Taco!
  97. Pics of my new 99 4Runner Limited
  98. Timing chain!
  99. 2nd gen disc brakes
  100. cornfed
  101. Spark plugs stuck.
  102. Weight - How Much is Too Much?
  103. Engine Oil Cooler question
  104. Htich light, anyone have one?
  105. opinions on exterior 12v outlet
  106. Got new hella 550's
  107. Rear bumper question
  108. New Spark Plug Wires...
  109. 3vze Motor Mount Frustrations!!!
  110. newb question: will this bolt pattern work for me?
  111. my runner is having trouble starting
  112. OME lift
  113. Rear window woes.... reloaded...
  114. air conditioning compressor whine
  115. Which fuel additive is worthy
  116. funny noise
  117. AC "high and low" connectors
  118. Cluster lights
  119. stealership tune up outcome
  120. tacoma skid on 3rd gen.
  121. Highway Carnage
  122. removing rear panels
  123. How to pull a T-Case:
  124. spray painting
  125. $23,900 for a '99?
  126. June/ July '05- the summer of mods!
  127. Radiator
  128. Loud exhaust
  129. No more soccer mom tires!
  130. 3vz-e coolant temp poll
  131. 22RE Tech Question - Timing Chain
  132. Shocks big dicision
  133. New Tires: 33's on stock 1st Gen
  134. Wheel and Alignment Question
  135. Meet my new girlfriend Cali
  136. Siphoning Gas
  137. bad day...baaaaaaad day
  138. Questions on 1st Gen 3.0 V6 aftermarket cat and exhaust
  139. Arb Flush?
  140. Quick Favor regarding A/C.
  141. Daystar Bushings for Panhard Bar?
  142. Buying Used Rim's 3.75 BS or 4.25 ? QUICK HELP PLEASE
  143. Retrofitting AC R12-R134
  144. Plugs for foglight holes on a 3rd Gen
  145. Awesome Domelight Replacement - LED
  146. Which Tranny Fluid?
  147. Best fog lights/under $50.00 ?
  148. Fabric Protection 3M... Any recommendations?
  149. clutch pedal squeek????
  150. Antenna nut and grommet....
  151. 2002 4Runner chrome package?
  152. Mod bug done already bit me ... Backspacing question
  153. Replacing Mis-matched tires
  154. Pass side window motor intermittent problem
  155. Glove compartment light?
  156. 97 4Runner SR5 fuel capacity
  157. Limited Cladding
  158. Which rotors for me?
  159. new wheels and tires installed today...
  160. 3rd Gen overhead map light replacement ?
  161. 22r to 22re?
  162. 2nd gen. Bumpers
  163. Well Boys Here's My New 05 Tacoma! *Pics!*
  164. diff. in cat back from 93 to 95 4runner
  165. Firecracker Smell and New Shocks
  166. What's your thoughts on this Runner?
  167. Should I get this clutch disc?
  168. 3rd Gen - Free Flow Cat
  169. New here
  170. Rear Bucket Seats?
  171. What type of gear oil do you use?
  172. Chart for different engine codes?
  173. what is this mini rad in front of my rad
  174. new first gen cargo bay panels
  175. a few questions about 22re's.
  176. Normal Labor Charges for Spring Install
  177. offroading lights
  178. TRD Progressive Springs - Left or Right?
  179. Toyota 4Runner > Chevy Blazer
  180. A340F valve body upgrade
  181. New Dyno Numbers & Track Times
  182. New guy... 86 reg cab
  183. Any difference between 96-98 Limited front/rear bumpers vs. SR5?
  184. 94 4runner seats in a 1st gen.
  185. What am I needing to look for in purchasing rims.
  186. Sagging rear Downey Rear Leaf Springs
  187. Clutch pedal, easy question
  188. Front Sway Bar Removal
  189. Rhino, Line-x, linings FAQ
  190. Warranty & Clutch Help/Opinions
  191. How Much In Demand Are The 3rd Gen All Clear Tailights?
  192. 3.0 part, can you identify this hose?
  193. Electrical short or I'm an Idiot?
  194. Name that switch... (help needed)
  195. U Wrench It in VA. Beach
  196. New Clutch at 73k?
  197. 5vzfe waterpump (when to replace)
  198. '98 Taco - bad shake vibration at 45 and 65 MPH
  199. Jinx'd 4runner(sorry about length)
  200. 89 toy 2wd pu
  201. Clutch or Transfer Case?
  202. Magnaflow muffler # 12286 with 2.50 inch pipe
  203. Cig Lighter Mod info needed (this should be an easy one)
  204. Odd sound during acceleration... Clutch?
  205. 98 SR5 runner
  206. cant find roll bar and front gaurd for 89 long bed
  207. Painted my wheels black today
  208. Got the new Geolandar M/T +'s (PICS)
  209. Welder in SOcal...
  210. 3.4 Plugs
  211. Superchargers anyone
  212. Metalic Blue 2door 4cyl 4sale seattle area?
  213. oxygen sensor
  214. 87 4runner Trouble getting to start?!? need help
  215. NWOR mail order only?
  216. Im done...selling my 4runner, but for how much?
  217. 87 4runner engine swap *thinking about it*
  218. What are the side effects of a leaking water pump?
  219. Is this a good price? Getting my Y2k painted all black!
  220. Propane Conversion Questions
  221. How easy would it be to fix these? *DUW*
  222. Inclinometer Install
  223. Intresting Air Filter video
  224. Stock hieght question
  225. Cheap trick by removing an acessory
  226. Can I see your truck lifted/ tire size question
  227. Has anybody done the auto up/down window mod?
  228. 3vze ignition timing experiments w/results
  229. Would 265/75/R16 Fit An 05 Tacoma?
  230. Can someone photoshop my truck?
  231. Will 15" wheels & tires 31 x 10.50 R15 from a 91 4runner fit on a 91 Land Cruiser?
  232. '89 PU speedo question
  233. What is my truck worth?
  234. Tire rotation question.....
  235. 3rd gen SAS
  236. what did you pay for a valve job?
  237. Howling noise while driving
  238. Slip Yoke Revisited
  239. final pics of body work
  240. Gas Mileage
  241. Hmm... electric fan
  242. 4Runner StormProof Car Cover choice.
  243. Taco owners with seats that make your back hurt!!
  244. Truck seats,good deal?
  245. Where to buy a 22R?
  246. Need a picture of Desert Dune painted bumpers
  247. I may be getting my 81 back
  248. Rear Differential breater ????'s
  249. Lowering Spare Tire with Body lift...
  250. Tire Sizing and Suspension Question
