5vzfe waterpump (when to replace)
Old Jun 20, 2005 | 11:54 AM
cbrew325's Avatar
My 97 4runner is about to hit 90k. I don't currently have any water pump problems, but I am wondering if I should replace it while I am doing the t-belt. What do you guys recommend? I think my water pump would probably last another 90k, but that might be a gamble.
Old Jun 20, 2005 | 12:01 PM
rimpainter.com's Avatar
It's hit or miss. The only way you will really know it is going out is if it starts to weep.
If I was going to keep the rig for a while I will have it done.
Old Jun 20, 2005 | 12:10 PM
FilthyRich's Avatar
i am a bit anal about service work AND I hate doing the same thing twice. While you are replacing the belts, put in a new water pump. you have noithing to lose (except $$$) and the reassurance that your pump won't fail.
Old Jun 20, 2005 | 12:11 PM
cbrew325's Avatar
On my 22RE, I can losen the crank pulley bolt by bracng my breaker bar against the frame and hitting the starter. Would there be any reason I can't do this on the 4runner?
Old Jun 20, 2005 | 12:18 PM
terryjmatthew's Avatar
I decided to replace my timing belt at 80K and found a leaking water pump when it was torn down (No prior indication of a leak).
Do yourself a favor and replace the pump before it fails.
Old Jun 20, 2005 | 12:20 PM
On the flip side of that, I just sold a 97 4Runner with 197K miles that never had the WP replaced.
Risky, but possible.
Old Jun 20, 2005 | 02:48 PM
eric-the-red's Avatar
No reason at all, that's how I loosened mine when I did the timing belt.
Old Jun 20, 2005 | 04:51 PM
MTL_4runner's Avatar
Mine is at 135k and after 2 timing belts it still doesn't weep.
Next timing belt I will do it anyway just for good measure (will probably jinx myself).
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
jon.r
Jul 11, 2015 03:34 PM
Cplmike
Jul 8, 2015 08:47 PM
