Tire rotation question.....
Old Jun 18, 2005 | 10:18 AM
drkgypsy's Avatar
From: Grew up in Santa Clarita/San Fernando Valley's...now in Washington State
It's time to rotate BFG A/T's on my beast but.....both rear tires have two 2oz balance wieghts, and the fronts each have one 2oz balance wieght. Should I just swap the front left w/the front right, and do the rear the same way or.....?
Old Jun 18, 2005 | 10:22 AM
jimbo74's Avatar
jsut rotate front to back or however you normally torate... 4 oz eventhough a 1/4 of a pound is not much weight in regards to a truck tire......
my 31: bfgs were in great condtion and on average required 3 ounces each
Old Jun 18, 2005 | 10:52 AM
drkgypsy's Avatar
Thank you sir......
Old Jun 18, 2005 | 11:09 AM
4RUNR's Avatar
Guest
TONY: You been rotating the tires?
JERRY: Try to.
TONY: You don't try to. You do it! Fifty-one percent of all
turns are right turns. You know that? 'Try to.
What TONY meant is cross the left and right once they are moved to the front.
Old Jun 18, 2005 | 11:17 AM
eric-the-red's Avatar
I use pattern C for 4 tire rotation in this diagram
http://www.tirerack.com/tires/tirete....jsp?techid=43
The weights shouldn't matter, tires aren't usually balanced on the car anyway.
Old Jun 18, 2005 | 11:25 AM
CynicX's Avatar
I'm probably not understanding as usual. But the tire weights are balancing the tires and rim, not where they are on the vehicle. They are all balanced off the vehicle of course when new and installed anywhere really. What I'm saying is the weights have nothing to do with tire rotations at all, just that specific tire and rim.
I rotate both the back tires straight forward. So back driver to front driver, and back passenger to front passenger. Then cross the front two. So front driver goes to back passenger, and front passenger goes to back driver.
This way all the tires work there way around the entire vehicle. Seeing equal amounts on all four corners...
Old Jun 18, 2005 | 02:35 PM
drkgypsy's Avatar
Thank you all, it's been awhile since I got to wrench on my own rig, and I was having a blonde day....no offence.......
I will not admit that I gettin forgetfull in my old age, I'm 30 and it's all striaght down from here
Old Jun 20, 2005 | 10:01 AM
Flamedx4's Avatar
[[forgetfull in my old age, I'm 30 and it's all striaght down from here]]
Oh man. I'm way further down that slope... straight down would at least be a smooth ride, it's the BUMPS that get ya... what were you saying?
Old Jun 20, 2005 | 06:35 PM
Ironmike4x4's Avatar
I have to rotate my tires front to back on the side since my wheels are directional.
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
Scatpac
May 25, 2017 06:47 AM
DirtRoad93
Aug 23, 2015 05:50 AM
Up&Down
Aug 5, 2015 06:20 AM
