Cig Lighter Mod info needed (this should be an easy one)
Old Jun 19, 2005 | 10:35 PM
elnido's Avatar
How can I make my cig. lighter offer power full time. In other words, I'd like to charge my phone, and not have to keep the ignition in the "on" position.
Old Jun 19, 2005 | 10:52 PM
DudeBud's Avatar
run a hot wire from the battery to the cig lighter
Old Jun 20, 2005 | 09:39 AM
kevin444's Avatar
Remove the relay for the +12v outlet designation in the fuse box. Get a wire with taps and bridge it!
Old Jun 20, 2005 | 12:40 PM
95ToyotaPU007's Avatar
If you're gonna do either of the above I would also place a 10 or 15 amp fuse on the line for safety.
Old Jun 20, 2005 | 01:09 PM
Tacoma Dude's Avatar
If you want detailed instructions with photos you can check the write-up section part of the site. You can find it from the main page.
Old Jun 20, 2005 | 01:37 PM
Fink's Avatar
Here is the write-up listed in the Tech section on here, this guy knows what hes doing too...I've used his write-ups before.
http://www.top4runners.com/ja/electr...ml#poweroutlet
Happy modding!
Fink
Old Jun 20, 2005 | 05:45 PM
elnido's Avatar
thanks for the responses, the Bajataco write up on this site and the one 4x4 fink suggested look totally different. I'm sure there is more than one way to do this, is it really necessary to insert an in line fuse? I'll be powering the usual suspects...phone charger, air mattress pump, ipod, etc.
Any more input is appreciated
thanks
Old Jun 20, 2005 | 06:29 PM
DudeBud's Avatar
yes very important
Old Jun 20, 2005 | 06:32 PM
Tofer's Avatar
Sponsor
i added 2 other cig lighters in my runner. one under the drivers slide kick panel and one in the back. both are wired hot all the time. they work great
Old Jun 20, 2005 | 06:47 PM
LittleRedToyota's Avatar
you should definitely use a fuse...and, if you run a wire from the battery (which is the way to go, imho), you should put the fuse as close to the battery as possible.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
HALMAN
Jun 14, 2002 09:02 PM
