- PIAA 5251's
- truck or 4runner?
- Gear setup in washington
- Advice on sagging rearend on gen1 4runner
- Swaybars?
- thunk when turning off ignition in 4WD
- 1st Gen
- If you had $5000 for only your truck, what would you do?
- Help needed with my axle code
- misaligned wheel
- Making a 2WD into a 4WD
- My Suspension?
- Which IFS is stronger??
- 3.0L is out, what to replace before going back in?
- No $1200 Tacoma
- what brand gears to get
- Quad in the back of a 88-4runner?
- Is it 270 or 282?
- Know anything about these guys?
- is my timing[belt] right on?
- Air filter oil
- ----------window problem-----------
- 3RD Gen Rear hatch/door won't open..
- SC it?
- Universal O2 sensor
- Need Help Asap Pleaseeee!!!!!
- Penzzoil full synthetic oil?
- Harbor Freight driving lights
- So I finally got the time to inspect the front end..
- Stainless or ceramic headers?
- 84-88 sheet metal and grey interior parts and more items
- 4 runner tranny question
- 22r/re questionh
- A funny thing!
- 96' up rims on a 2nd Gen.
- foam filters besides amsoil?
- Snow
- Realistically, How many tires could I fill?
- best looking wheel on 1st gen 4runner
- official 4runner thread
- Tint?
- Fipk
- ? for people who tinted their 3rd gens front windows
- block heater
- Radio Wiring Diagram
- I need a new rim for my Tacoma
- New to me Magnaflow
- brake upgrades
- cowl hood fot 89-95 pickups
- Need some help guys... SC guys needed
- Not another supercharger question...
- Shimmy
- **HELP** Flat tire---can't get the flat off
- Tips on replacing rear leaves?
- 1st gen fender question
- rough idle after crash
- Brake Job Write-Up on 2nd Gen??
- Storage compartment
- Ring & Pinion help
- I saw this show..
- blown EFI fuse
- Rebuilt engine problems
- Another Lift ? - 87 Runner
- Simple spark plug wire
- Passed!
- What are your pending mods?
- Diff drop...easiest mod ever!
- Throttle Position Sensor
- Snorkel?
- Deckplate mod...?
- 3.0L automatic / over drive problem
- Rear driver side leak
- It was the alternator
- Gas Tank Cap...Whoosh or no whoosh on opening?
- Fuse for Rear Defrost
- 2nd Gen 4Runner Front Frame Damage
- Oil Preasure
- All 3vz owners?
- How many miles have you gone with fuel light on ?
- 22R California carburetor differences
- possible temp overshoot problem?
- Neutral starter switch???
- 2X4 worth fixing for offroading?
- speed sensor (VSS)
- 4x4 swapmeet
- 1989 Toyota 4x4 Clutch??? Button
- exhaust leak?
- Inside cab filter
- Thinking of selling my Lightforce 240's
- Snow coming through air vents?
- Shackle lift
- New poster sharing very bad weekend!
- small plow for the 4runner?
- Long uhaul trip with the 4Runner
- newbie w/ Tacoma questions
- Sold my Runner
- What should I buy?
- I got the Bilsteins installed but....
- First post, couple questions, best forums Ive found so far
- rear bumper ideas for 85 4runner...
- Lucas oil products, THEY ARE AWSOME~
- Tires chirping in 2nd!
- aux lights wiring help needed
- PO420 code, damaging reasons, possible fix??
- will i be able to get $2500 for this...
- Windshield washer pump - anybody dealt with it?
- Exhuast leaks and the 2.4
- any one deal w/ these guys for body parts?
- 2.4 Exhaust HELP
- integration relay
- Driving Lights
- I looked around....
- front bumper
- Rom editing (wheres the programers at?)
- 22RTE Engine Tech needed
- What oil filter?
- Running board question
- Is it worth my time to cut open my fuel filter?
- Air flow sensor bypass
- Highlander in the snow...
- reuse lower fuel injector seals?
- Need ideas of V8 swap into my '90 4Runner...
- new rear shocks with lift?
- 22re compatability?
- bad experience today with lockers
- Motive Power Brake Bleeder 0251 Worth its weight in GOLD!
- Front Inner Oil Seal - How deep?
- Auto or manual, which is best?
- shocks to lift a 4runner?
- Old Gasket removal....AHHHHHHHHHHH!!!
- I got a problem
- rear license plate frame question
- Anyone have these wheels on their 3rd gen. and have pics?
- Ever had a relay "go bad"?
- I have no oil presure.
- Pre-Runner
- Mesh grill 2nd Gen 4r
- Flywheels?
- keeping soft top from being stolen?
- Coolant Leak Question 3.4L Engine
- 16"rims with off-road pkg VS. 17" rims with limt'd diff - WHATDAYOUTHINK?
- 2 1/16" altimeter?
- Any fiberglass gurus?
- Your opinon on 2nd. gen coils
- Recomendations on lift ?
- rear output flange leak
- Aftermarket hoods
- Lowered Reserve on 400RWHP NW4Runner
- alarm instal
- How to remove humidity inside?
- Tranny problem
- ect problem
- truck tool boxes
- Mandrel bent tailpipes
- Iradict Shifting
- Which type of gas?
- Anyone heard of these shocks?
- need quick advice...
- Fuel Upgrades and Tuning?
- I just go so stuck a Blazer had to yank me out :(
- some eletrical probems...
- bedliner in 3rd gen rear vent questions
- NEO oil
- spark gap .50 instead of .30 what damage?
- Identifying 4Runners by their Grille's
- Where is the ECU?
- Is My Head Gasket Going! Help!
- Hello Everyone! {New pics, 994runner lifted}
- Tranny Question
- factory service manual
- Goofy question regarding 1997 4Runner....
- Tire size question... its a good one !
- Will this push bar fit my 4runner
- PCV location/Seafoam treatment on a Lexus?
- Costco gas and ping?
- Confused about heater hoses
- Remember my wierdo thing happening?
- Back in the 4Runner Family
- Looking for L.E.D. marker lights
- where would you buy a brake fluid level sensor?
- Engine Swaps: 3VZE -> 3VZFE
- New to Yotaland.. w/questions..
- Upper nut for L rear shock tower
- installed flex-a-lite, have questions
- I'm taking the plunge on new Tires & Wheels
- Dash removal techniques?
- Need a new motor!
- Automatic Tran. Problem
- bike-rack options for '90 4Runner?
- Panhard and Starting problems
- Pro comp drop bracket
- Fuses - Clock, Cig, Radio
- Timing belt replacement
- Fuses
- Rear Pinion Noise
- Here's my new to me ride
- startup whoas
- Taillight Blackouts and a new clutch!
- Would you buy a 3/4ton tundra in with a cat underhood?
- DIY tranny flush.
- Good place to buy new interior carpet??
- what the...
- Mt/r or stock
- grinding noise
- is it ok to revert back to dino oil from synthetic blend?
- window "clunk"
- 04 4runner W/ A Real Lift Kit!!!!
- backup lights
- Wierd Stalling problem....WTF???
- need frnt. bumper advice any links?
- Wierd things happening
- Damaged Paint
- Code 42, vehicle speed sensor?
- Help '97 3.4L 4runner wont start
- Anyone know a place to buy stock tailpipes?
- Problem after tune up
- Gears ?????
- headlights
- Newcomers
- 2000 tacoma cold start knock
- 3.4 swap
- I finally did the Maglite mod.
- painting chrome bumpers......
- 93 4Runner Timing Baffle
- Heater Core Flush
- Cold air comin through the door handle
- Pickup Body Lift Kit
- Just tried Seafoam
- I'm callin' you out Yoter!!!
- Wet Okole Pics
- front brake? problem
- Struggling with 2005 Tacoma options decision...
- need some help in Connecticut
- light help
- Help Me find these Sites!!!
- Question about Amsoil air filter.
- Lift kits !
- New guy with 92 4runner
- '94 4Runner Projector Headlights
- May be time to hang up the "4Runner" hat...
- 22r EGR removal
- Front Brakes on 88 Pick up
- Electrical?
- You gotta see this!
- Quickie 3rd Gen idle speed ? after cleaning
- Exhaust sound Comparison
- show me your shift knob!
- Supercharger...?
- back after about a year.
- is this bad?
