Radio Wiring Diagram
Old Jan 24, 2005 | 05:00 PM
bryontro's Avatar
Question Radio Wiring Diagram
Can someone with a shop manual provide me with the wire colors for the rear speakers on the stock stereo system? Where is the best place to get at them? I need to put in a lineout converter so I can run a small amp and sub.
Also, I realize that I haven't been on the site lately but has there been talk about the rear drive line binding that I intermittently feel when coming to a stop on my 03? Dealer says it's normal and I realize that it doesn't hurt anything but I would like to know the fix if someone has figured it out. I greased the rear drive shaft but it didn't help. Thanks.
Old Jan 25, 2005 | 01:33 PM
nunsa's Avatar
These are for '89 and up!
pin what it is toy in dash wire color new radio wire color
A RIGHT FRNT SPEAKER (+) GREEN GRAY
B LEFT FRNT SPEAKER (+) PINK WHITE
C +12 VOLT IGN. WIRE GRAY RED
D +12 VOLT BATT WIRE BLUE W/YELLOW STRIPE YELLOW
E RIGHT FRNT SPEAKER ( - ) BLUE GRAY W/BLACK STRIPE
F LEFT FRNT SPEAKER ( - ) PURPLE WHITE W/BLACK STRIPE
G GROUND WIRE BLACK BLACK
H PWR ANT. WIRE 1 BLUE JOIN WIRES 1 & 2
I PWR ANT. WIRE 2 TOGETHER TO THIS BLUE WIRE
J DO NOT USE
K RT REAR SPKR (+) RED PURPLE
L LFT REAR SPEAKER (+) BLACK GREEN
M RIGHT REAR SPEAKER ( - ) WHITE PURPLE W/BLACK STRIPE
N DO NOT USE
O DO NOT USE
P LFT REAR SPEAKER ( - ) YELLOW GREEN W/BLACK STRIPE
Old Jan 31, 2005 | 10:43 PM
Poopy's Avatar
Do you know what the 85's would be?
Old Jan 31, 2005 | 11:34 PM
the_supernerd's Avatar
I think that there is a color standard for stereo wires. If the wires are the same colors as listed above, then the connections are probably the same. I believe that Toyota changed the stereo harness in 1987, so it might be different for a 1985.
Old Oct 16, 2009 | 11:05 PM
The California Kid's Avatar
About that power antenna...
It says H is wire 1 and is a blue wire, and that I'm supposed to join this with wire 2 and connect them. What color is wire 2?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
theking11863
Mar 19, 2016 09:36 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
TDonkey
Jul 26, 2015 10:14 AM
88yodabasket
Jul 13, 2015 01:32 PM
