thunk when turning off ignition in 4WD
Old Jan 25, 2005 | 02:10 PM
Marc's Avatar
I thought I saw something on this but can't find it.
If I leave my truck in 4WD and turn off the igniton key I feel a big
clunk - thump kind of thing happening. Sort of like the driveline releasing energy or unbinding or something like that.
Is this a normal thing? Sorry for the vague clunk - thump description.
Old Jan 26, 2005 | 12:16 AM
bikeguy18974's Avatar
This is not going to help you but I've had that same problem before too. I haven't had it yet this year though, but I haven't driven it as much as i'd like too.
Does it do it all the time? Or only some of the time. My problem was every so often and over a year ago so i forget at what times it happend. If it is intermittent try to figure out when it does it. See if it does it after you've just turned into a tight parking spot. See if it does it after you've driven straight for a while then stopped. I'm wondering if it has anything to with the drivetrain binding on a partially dry surface and then something (not sure what) releasing when you shut off the truck.
Old Jan 26, 2005 | 02:02 AM
Normal for ADD front axles.
ADD will disconnect when ignition is turned off, if there is driveline tension present it will thunk.
Old Jan 26, 2005 | 03:53 AM
CDUFF7's Avatar
My 88 does this too occasionally and it only seems to happen when there is a bind on it. I am assuming it is normal at this point. I use the 4 wheel drive a lot due to the bad weather here.
Old Jan 26, 2005 | 06:32 AM
Marc's Avatar
Mr Pogo I like your answer. It does it everytime I turn it off. I didn't realize the ADD disengaged when the ignition went off. Makes sense now. It's probably the axles "relaxing".
Sleaker
Aug 26, 2020 06:03 AM
luckypig44
Jul 19, 2015 11:25 AM
rushw
Jul 18, 2015 01:46 PM
Hamonacracker
Jul 17, 2015 08:33 AM
94whiterunner
Jul 12, 2015 07:15 PM
