- Transmission install tricks?
- 3rd gen roof leak
- rs3000 install help
- LSPV Rod
- 95 fuel pump problem?
- What to look for in 1999 4Runner?
- Exhaust: need some HUGE help getting through emissions!
- Pto?
- Has anyone done a Chevy small block crate motor swap?
- drag in 4wd
- Electronic/Cable Speedo Questions
- 4Runner VS Tacoma... which to get?
- size of bolts for timing chain cover.
- Which TPS Manufacture is my best bet?
- Need hlp with smog
- oil leaks
- Coolant Temperature Sensor on 98 3.4l
- transmission sound
- Shackle recievers for sale on e-bay
- Tacoma, power steering issue, and lemon laws.
- Semi-new and have questions about 22r-tec.
- Engine Problems
- No Reverse lights after powerwashing...
- Brake swap
- seat qustion?
- Gear Oil Question...
- rust around fender... problem?
- 3rd Generation 4runner ?
- Tundra brake swap compatibility
- Frame repair
- 4Runner Aftermarket Bumpers/Sliders
- 2nd gen exhaust question
- Need help hooking up trailer lights (I.D.ing wires)!!!
- How much show I pay to have 3rd gen bumper painted?
- new mods during spring break
- 88 7MGTE 4Runner going again, now intercooled and more
- sway bars
- 1990 4runner v6 vacumn line routings
- TPS Gurus, I need your help!
- mesh Grille.........??????
- 4 to 5 speed upgrad-I feel the need for speed on the ol' 82
- best 2din aftermarket stereo
- Paint problems on Runner roof... (pics)
- 33's are on...pics
- Do you guys wave/thumbs up?
- Tires picking up & throwing rocks?
- Low beams are dead it's not the HL relay..switch?
- 22RE exhaust studs
- Rear Window question
- Modular Grill Guard
- need help I.D.ing these pro comp parts
- LC eng. 2.7 performance head?
- Rear window problem
- 88' sunroof help
- STOP Fuse?
- Sad Yota Owner
- for those of you who put newer seats in your first gen
- opinion ? comparing 265\70R16 vs 265\75\R16
- Some related accolades & questions re: Toyota 2nd Gen pickups/3vze
- 3sgte swap?
- Tacoma problem
- what does a totally rebuilt engine consist of?
- 3vze injector performance at 258,000 miles.....results!
- Question about gasket and pipe(egr?)
- torque specs
- engine swap question
- Dropped my head off at Engnbldr on Thursday
- What does this sound like?
- New Suspension
- Wiring IPF lights
- The cheapest/easiest way to do the ISR on a 3.slow...
- Just Picked Up New Exhaust!
- 85 pick-up timing belt broke
- How many miles on your 3.4L timing belt?
- Item #1,248 that has broken in the last 3 weeks - master cylinder
- www.tkojeeps.com
- Is there any way I can put these wheels and tires to use?
- 3rd Gen: How Difficult Is To Remove The Rear Bumper?
- 87 Camry door lock
- got her running great now a code 25
- Pinstripe removal
- Timing belt snap?
- Drive around the world!
- Repairing Rusty Doors
- GM 4.3 In my yota?
- stripped 88 4Runner auction Saturday NOON
- Tire Size Question???
- I need advice!!
- How to bleed the fuel system???
- Backspacing on 17" tundra wheels
- Check Engine Light
- grille4u grills
- Air cleaner on a 22r
- head gasket?
- Gas mileage FAQ
- HID's
- installing stock carb to replace shot weber
- Pinched Brake Line
- Guides Replace w/o Chain?
- Where is the Bumper
- a few parts.... need help.
- Front right suspension- sounds like parts are shifting that shouldn't
- 1st Gen runner - Chevys and BJ spacers Need shock lengths
- any way to add rear air to a 4runner
- Will 33" bfg at's fit 1st gen no lift?
- Problems with 1st Gen 22re?
- cheap/good looking rims
- Would you Lo-jack?
- Recommend Timing Chain Replacement?
- Clear turn signals. Where to get them.
- Standard Center Diff Lock?
- OME life
- Locating oxygen sensors on 2nd Gen...
- parking brake handle pulled loose...
- Changing a belt on my sec gen 4runner
- 3rd Gen CV Boot/Joint
- Went wheelin' today, now she's pulling to the left. Pics
- 22rtec
- im getting hid's soon!
- GOOD Fab shops east of the Mississippi
- Chunks of metal in bottom of oil pan
- Leaking Tranny fluid!
- Sway bar shackle repair... help please...
- P0136 Code Question-Which Sensor?
- Here's yet another problem with my infamous rebuilt 22re
- Throttle Body Hose
- Lexus Push-Button Start
- body swap
- Would you guys disown me if...
- Questions on regearing/tires
- Factory Roof Rack
- Warn Hubs in a 2000 4Runner
- Tweet placement in taco
- 3d model
- 01-03 Tacoma Front end on a 1995 Tacoma
- Time to regear
- 285/75/16 vs. 255/85/16??
- Cheaper tire prices @Discount Tire
- 2000+ 4Runner skid plates
- dash lights, marker lights and taillights dont work
- Tech: Variable Speed Temp Controller for a Taurus Fan Swap
- 4Runner - problems in Drive - very slow, smoke
- I Need Someone With A 99-00 4Runner Limited Desert Dune With Silver Cladding!
- wood panel kits
- Does the REAR Bumper From a 99-02 Fit A 96-98 4Runner?
- 99-00 4Runner Limited Flares Same Colour As 96-98 4Runner Limited Flares?
- Crankshaft Pulley Holder for 3.4L
- Brake Pedal To Floor!!!89 Runner
- 82 Trekker Homemade Soft Topper
- wheel shake, please help..
- re-oiling TRD/K&N air filter
- installing 3rd members: OEM paper or silicone gasget
- starter soleinoid contact part #s
- 2000 Runner Wiper Blade Size?
- Clock Stopped Working
- Driveshaft Extensions
- a few quick pics from this weekend
- tacoma problem
- Anyone have a good source for a 6mge swap donor?
- Anyone ever?
- Are all diff drops created equal?
- Totaled or Fixable
- More reverse light questions
- Manual Hub Question - 89 4x4
- gear shifter
- tundra gauges
- Fog Lights
- Ordering Wet Okole's
- Blown CV Boot, now what
- Do you think ISR is worth it when you have Deskplate and S/C??
- need 3vze diagnostic help!
- New to the forum
- HG replacement
- Tint Removal
- Little question about hard starting...
- Wash carpeting
- The 1990 Std.BD 4X4 22RE Truck
- Temp guage issues
- Porting a 22re intake plenum and manifold
- need new shocks
- trembling engine
- m/ts for climbing steep hills + daily driver
- I need some help
- Supra rear end??
- 70 mph rattle noise
- SAWS VS. Doahoe
- All Revo'd Up! *PICS*
- Push Bar and Lights on..Running boards off (pic)
- got poked
- 2nd Gen Lift Measurments
- Reputable Gear Shop in NJ/PA/MD/DE?
- Ping/Ticking sound
- Has anyone done a valve body upgrade/shift kit on their 3.slow auto?
- "Cloudy" plastic on gauge
- type of oil to use after rebuild 22re?
- How much lift from a trim packer?
- IFS diff support bracket cracking!
- Softer shocks?
- Amsoil filter mod # for 99 SR5 4runner???
- Does gearing affect your speedo/odo?
- 4Runner logo TrueType font?
- Help with the front bearings and thrust bush please...
- Threadquestion?
- studder problem
- Pulls to right
- Factory Service Manual- Year Model Crossover Question
- 22re Supra AFM Swap questions
- How to remove Inner Cover
- 2000 Timing Belt Replace - Done it?
- Hood gasket creep on Taco...
- 1989 - 1993 Cv Question
- We all know
- TRD air filter cleaner
- Good place for yota parts
- Advice on 3.0 rebuild or what?
- HELP!!! Fuel system problem on 22RE
- fuel injector cleaning
- Should I rebuild?
- <sigh> Yet another oddball occurance with my tonka..
- New Wheeling Club?
- First CV-axle breakage. My experience in replacing it.
- Ok should I need opinions......
- My '85 can barely get up to speed!
- Third Gen Extra Suspension Mods
- freon capacity
- New digi cam......and a few yoat pics.
- Best Service Man for 99 4runner?
- New superchargers out?
- check engine light
- 22re intake manifold question
- Toyota Trails Mag Mar/Apr
- New Guy 01 SR5 couple ?'s
- Reverse light Relays??
- power window module trouble
- 2nd gen Wow!
- New tires and rims
- ECU Compatability for 4runners
- Went through an enormous puddle, then..dead
- Overheating 3.4L
- Daytime lights/ HID conversion kit
- Guess Who's Getting Revo'd Tomorrow!
- Electrical troubles
- SWEET! I get to have 2 O2 sensors replaced...
- K&N Intake kit on E-bay?
- Leak after off-roading!
- Injector Cleaning Question
- Help deciding tires
- Anyone with a JOAS spoiler, what can I expect to get it painted?
- death of a power window module
- 90 Runner Rear Window Major Money Problem
