- Installed Sliders and 1st Gen Roll Bar *PICS*
- overheating / coolant line routing ?
- small lift on my new rig
- Need Help...Where is the ABS computer and speed sensor located?
- Front cv shaft seal
- Axel codes
- Vibration when stepping on Accelerator
- 4 wheel drive
- Making a u-turn in 4 high?
- When to use overdrive
- body lift and insurance issues
- Can you install a new steering wheel for a 2000 4Runner?
- Dual Exhaust questions for 2000 4Runner?
- Help: Removing xfer case output nut!
- toyota wheels center cap manual hubs hub modify modification 16 17
- Water temp gauge help needed
- Been busy with my 3rd gen...
- Proper Backspacing For 305-70-16 (98-4rnr)
- complex overheating problem, any ideas?
- Skidplate bolts
- 3rd Gen Rear Bumper & Tire Carrier
- very good chance Im picking up 00 4 runner, 5 speed, etc. tomorrow morning!
- injector difference 5vz-fe 5vzfe 3.4 camry tacoma 4runner 4-runner tundra t-100 t100
- Another step towards dechroming...
- Please Help, Repair Ripoff????
- Electrical Guys...Noise Reduction...
- Can't believe the fuel mileage!
- Runner has RPM problems!
- Power Loss?
- Replacing transfer case front output seal?
- Wheels: What does JJ mean?
- Engine changeout 5vz-fe
- 95.5 Tacoma check engine light/probs
- Teeter-Totter
- Sway bar link - broken - impressions...
- Wheel clunk
- Transfer case leaking via shifter (02')
- High Flow cats on 3rd gens
- Over heating issue! Please HELP
- Right or wrong muffler?
- A.C. Trouble
- fitting a 255/85/r16
- CV Boot (Need measurement)
- Tuning URD A/F Ratio Calibrator?
- My friend just bought this
- Running Bars
- Am I getting a bad alignment?
- Leaking rear axle seals!!?
- 170 Thermostat ?
- Maybe Selling...
- Painted grille/bumpers?
- has anybody used hidretro.com before??
- worn tie rods????
- Tundra Sequoia Wheels on a 3rd gen 4Runner
- temp control knob clicking?!
- Snap-On Timing Belt Tensioner available in CO?
- Help me find the correct shocks.
- Aquamist high-speed valve question
- Tranny cooler?
- Alarm toggle switch near light dimmer switch on '00 Sr5?
- Towing with 3.4 4runner?
- couple of pictures of my Runner
- antenna ???
- cooler plugs?
- v6 in 96-01 trucks...
- 24" Magnaflow muffler installed on 98..
- New exhaust...O2 sensor location after cat? Need help ASAP
- Clicking Radio-revived
- Need OEM part #'s
- Hesitation sluggish missing ? @ wide open throttle acceleration tacoma 1995 3.4 5vzfe
- where to buy stock coil cprings
- TJM Bumper Question
- LTD. wheels with wheel spacers?
- Tundra/OME w/spacer front: What for rear?
- Looking into a new mod, need some PhotoCHOPING ASSISTANCE?
- 00 OEM Floor Mats
- AC box condensation?
- Can you believe this happened to my TJM? *pics*
- my new toy
- Pics!!!! are these rims 2 bling bling? with 285's
- Fixed wobble in center console.
- land cruiser wheels and 285 BFG MT's
- Help with an OBD code. 99' 4Runner.
- New Brake Shoes = Really hot drum?
- considering 3rd gen
- Any uses for used suspension bits?
- Is this the actuator for 4WD? (my 4WD won't engage)
- Windshield washer fluid tank leak?
- Rear latch in lock position, can't close door.. Help
- Adding Rear Differential
- RB 2" Body Lift question with pics
- Quick pipe question for ISR mod.
- Supercharger Installed (Well Mostly!) Pictures
- 3.0L V6 vs. 2.4L I4
- starter rebuild, '98 PreRunner V6?
- Rear OME 891s setup with cornfed spacers.. cornfed guy quoted me on height issue
- Should I sell my '95 and buy '98 4Runner?
- Anyone replace silicone in fan clutch 3gen
- Where does the transfercase disconnect 4wd?
- yet again another lc coils question
- Who is it here that modded a TJM/ARB to mount front fogs.
- Which model Lockright for my 97 4Runner
- where can i buy a rear diff?
- Uniball adapter separating from spindle?
- should i pounce on this??
- Driver side seat belt indicator
- New V6 SR5 w/dealer installed supercharger Questions
- its about time i get to those fuel mods
- 2000 tacoma 2wd to 4x4 conversion
- Identify this paint!
- Brake help
- 2001 Taco Prerunner Strut Question
- Other than Bob, who uses their TJM for shackle mounts ?
- Started truck (been sitting for 6 hours) it wouldnt automatically shift to 1st gear?
- Need help diagnosing whining noise after overheating the engine
- Borla Cat-Back Exhaust, how is it?
- 3.4 liter v6 tacoma spark plug gap sparkplug question
- Starting woes?
- Body Lift Install Help Please!
- 4runner Tire Jack is useless
- 35 inch tires gearing speedo
- Wheeler's Off Road Wheels backspacing?
- 97 4Runner "clunks" at constant 50 MPH
- 96 4x4 rear end sag - replacing springs which shocks?
- I need some engine bay pics please
- 2001 SAS'd 4runner
- Is an alignment necisary right after a lift install?
- 3rd Gen 4Runner Tranny Cooler Dimensions
- Running diff size tires and other spare tire issues
- 4runner tranny cooler 3rd gen (with tow package)
- weight comparisons between brushguard and stock bumper to a tjm or arb
- Turn signal help?
- Help with CV shafts
- Intake mods vs. Aftermarket Intake
- 02 Aftermarket stereo install
- need an air/fuel ratio sensor- where to buy??
- 4Runner 4wd system help (3rd gen)
- My trailer light update..again!
- DIY temporary allignment ?
- 4runner/Tacoma Bumper Change?
- Auto tranny won't shift out of park
- Lifted, refinished LC wheels, REVOS - big pics
- Tacoma Rear is sagging a bit w/topper installed
- Decoding transmission dates on 99 4runner
- 96 3.4 stalling at redlight...transmission?
- Bad O2 sensor after 600 miles??
- Help! reattaching fender flares
- got muddy water into the cab a bit....any tips on how to clean it?
- Need help, my runner won't start
- anyone know an altenator that will bolt in to 3.4?
- spare tire winch - 4runner vs tacoma
- URD Kit conservative tuning, impossible without EGT?
- Curious about Toytec 3 inch lift
- Advice needed for potential 4runner
- ebay sliders
- What will my 4Runner run in the 1/4 mile?
- Diff drop with stock skid plate...
- URGENT : What size is front d/s hub retaining nut ?
- Where to get OME springs?
- carbon fiber interior setup.. pics (not your usual grey/black, this is silver/silver)
- Where to buy LC coils for the rear?
- Tire siping?
- Supercharged 4Runner at Altitude
- MSD DIGITAL IGNITION 3rd Gen Anyone want to see pics? write up?
- 12volt wire routing to rear of 3rd gen
- 2.2" pulley folks w/ 7th injector?
- Pulleyboys or URD 2.2" pulley?
- 96 4 runner lift/tires/shocks setup questions
- FWIW my thoughts on brands of tires I've had on my 4R
- Ok, think i found the $$$'s, now which bumper
- Piece above running board missing...what is it??
- How to jump the A/c pressure switch
- Front brake setup for 3rd gen - Already searched
- 3rd Gen OEM Fogs from PP On Sale
- Got the cutting wheel out, trimmed the fenders
- About to purchase 3rd Gen
- Replaced Spark plugs, now a question
- Door Lock Help!!
- Where can I get a Wheel Center Cap for 2001 4Runner?
- are there any FSM in pdf floating around?
- advice for a 180K tacoma?
- OEM looking momentary switch
- "Bad" muffler on 2002 4Runner?
- Is it me, or is the A/C in the 3rd Gen not so strong??
- At 220,000 miles, it's time to get some new shocks!
- Time for new plug wires?
- Just bought a 96 limited need an extra key fob
- Coil on plug spark plug boots. Does anyone make just the boots?!
- 2000 front wheel bearing replacement. How hard?
- Silencer Remote/Alarm questions
- Question about my 4 runner rear window problems / security
- Hayden tranny cooler
- will 97 4runner struts fit 01 tacoma??
- Starting Mystery
- 3rd Gen. suspension. which do I have?
- O2 sensor
- Aux Back up/work lamps ..rack mounted ??
- 4cyl 3rd gen same rear end as 6cyl?
- Pro Comp Traction bars
- is my 99 4runner a sport edition!??
- Odd noises coming from my engine when AC is on
- want to level my lift
- anyone have trail gear sliders?
- fuel gage frozen at way over full
- How many miles on your 3rd gen 4runner?
- Smog Check Passed Today...
- Door Upholstery Questions?? 4Runner Comparison/My 1000th Post!!
- Brake Pad FSM?
- Flowmaster 52557 and high flow cat with 2.5 inch exhaust on 3rd Gen
- Supercharger questions
- what shocks for LC/Tundra lift?
- Rear Brakes turns into rear axle replacement?
- front diff drain plug / complete fluid change
- 2001 Tacoma disable FWD?
- best or cheapest place buy cv joint axles half shafts 95+ tacoma
- New Aux. lighting
- best year of 4th gen tac?
- A/C recharging question.
- VSC Questions
- Clutch Sticking
- New here and need help with upper ball joint
- Help! Extreme Truck Vibration
- Who's runnin 255/85's with 4cyl and stock gears??
- newbie questions 95.5 tacoma tires supercharger general differences
- gas light
- Alternator going bad...
- Another 3.4L Cam/valvetrain Option
- ALternator Swap Questions
- Needle adapters for grease guns. Good enough?
- Supercharger at 7500ft- leaner than sea level?
- 98 Auto Transmission refill
- Great Covers custom seat covers installed (pics)
- 2000 tacoma trouble code problems
- Odd front end noise
- tmc 1.1 and 7th injector
- Front end squeak/chirp noise...
- Pics of Painted Roof Rails...
- Broken Passanger Stabilizer bar link in IFS?
- Front end making creeking noises?
- leak in my axel seal
- Baja Fenders for 3rd gens..??
- do FZJ80 center caps fit the LX450 wheels?
- Injector Cleaning: what method?
- Low charge, but no amp light on dash?
- Taco TRD axle q's....ASAP
- Engaging an E-locker manually
- Transmission Cooler 2004 Pre-Runner?
- SnapTint products
- Did the 97 4r limited come with keyless entry?
