- 2.7L Blown Head Gasket and more - need advice
- problem with braking
- PICS Finally
- '99 (4cyl) Deckplate mod page - step by step directions for deck plate mod
- changing dash lights?
- Diff Lock switch location
- Center Console Cup Holder Mod Retro Fit On Pre "99
- VSC/Trac disable
- Tires/Wheels or Regearing?
- Exhaust Manifold
- minor whirring noise in 4WD
- value of 2000 sport w/ 60,000 miles
- Anybody know of a way to disable ABS on 2wd?
- Brake Qiuestions
- 02 4R - would not move - issues - please help
- will this work...
- More fog light frustration!
- Need help cleaning shift boot for AWD shift lever - 98 SR5 3.4 Auto
- Engine hesitates on takeoff
- HELP -> Repair Steering Wheel Leather?
- routine maintenence
- LED Side Marker Lights
- Issue with rear seat windows...
- who has 265/75/16's on their taco????
- take a licken and keeps on rollin
- Engine light, p0505 error.
- check engine light
- TRD Supercharger questions??
- Checking out a 02 tomarrow
- Looks like the 4Runner will be going on sale soon...
- Hummm/vibration when decellerating
- Houston, Tx Toyota Mechanics!!
- replacing the third brake light bulbs
- Lights, Pliers, and Rally
- Japenese Body Kits - 4Runner
- 60K tuneup at dealer, $525..good lord!
- Interior Noise
- Dash/Interior Decision and Install Help
- Amber gauge/climate control bulbs
- Door Lock Problems 99 Limited
- Removing rear differential
- Rear Wiper and Washer
- clicking noise when idle
- Clutch problems??
- Easiest lift to install on the market??
- anyone have pics of a diff drop
- Prerunner or not?
- How to dyno auto tranny 4Runner?
- isr and wheel and tire questions
- E-Locker and VIN Numbers
- dumb question about 4wd
- Supra LSD Mod for IFS ADD
- Proud new owner! help please
- 96 4runner alternator
- Shocks for lift
- another new wheels and lift thread...lots of pics
- 31x10.5" to 30x9.5" tire switch
- girl choosen mod...JDM Black headlights
- Need Help With What Kind Of Lift Kit
- Please help with my turn signal problem
- how can i turn off my keyless entry chirp?
- Odyssey battery released the PC1400
- exhaust hangers on a 3rd gen 4runner
- My truck got in a little fight with an irrigation ditch. Left with sqeaky front end.
- is there a write up
- New And Improved!!!
- Starter not disengaging
- ABS and Full Floating Axles Set Up
- Re-gear/shops in Phoenix
- electric rear diff locker on 99 runner
- 3rd Gen 4wd rear driveshafts
- nice 2000 manual 4runner on ebay (VA)
- Went wheeling for the first time today. Little snag.
- check engine light and tranny issues
- Used 3rd Gen buying advice
- 2001 4Runner Transmission Leak
- Help needed finding parts.
- Help Needed for Columus, OH alignment.
- Pics of the TJM, and cupholder mod
- Anyone have a flowmaster on their 2.7 ?
- 2000 Tacoma-bleeding ABS brakes?
- Irregular idle at start up : what could be the cause?
- Question for all the Stick/ 5 Spd/ Manual Drivers?
- Toyota wiring harness, is this right?
- New K&N Kit Installed (Pics & Vid)
- 285's with no regear..thoughts?
- EVAP codes driving me crazy
- 2000 Tacoma w/2.7 - throttle body spacer
- 00 prerunner cruise control?
- dirty rear passenger entrance
- Front Skid plate options
- Braking/Steering Vibration
- Safe way to lift a 01 2wd 4 runner??
- Valvoline Synpower BOGO!!
- Sump capacity for v6 4x4 tranny?
- 4th gen pickup lineup
- Gas Prices...much higher = different truck/car?
- CarQuest Synthetic Oil
- Brake Fluid level tripping ABS VSC TRAC ? (for 01-02 guys only)
- coilover spacer question?
- Maintenance Questions for a 99 4runner
- BlackHousing the Blinkers
- 4th gen to 3rd
- I am pissed!!! ....and now I need help!
- coolant level question
- Blinking ABS light (searched)
- Pinion Differences for Yota Diffs--Need Some HELP
- 12v Outlet on '98 is dead
- Why did my CV break
- K&N FIPK Filter replacement
- Good Toyota Mechanic Near Boston, MA
- High NOx reading during emission test
- Finally have pics of my 4runner
- Anyone done fiberglass??
- Radio Help...
- 2 Problems my 2000 has
- Coil Spacers bad on CV joints?
- Dynamic Tensioner compatible with First Gen (Silver) Supercharger?
- new pics
- Defroster not working...
- Master Craft seats, anyone using?
- adjusting coilovers
- Different Brake Issue
- 2000 4Runner Brake issues
- 3.4 motor sticker "3400 four cam 24"
- cylinder 4 misfire
- anyone open the newer tacoma headlights?
- Joining the club! 2000 4Runner
- Lift on the cheap
- rear bumper
- Is this a good deal for a Timing belt???
- shock mounting
- trade for a ???? Tacoma ????
- Body Leveling?
- Sylvania SilverStar Ultras installed w/Pics
- 1999 4runner liftgate shell
- ignition problems
- 5vzfe help!
- New hood for 97 4runner
- What to do with running boards...
- Wierd idle issue
- cylinder numbering
- Gun Metal Tacoma wheels (PICS!)
- Tundra/ome lift modification question???
- Starter Bit It Now Flex Plate Missing Teeth! How Long Will It Last?
- 3" Revtek lift FUBARing my cv's.
- 1 inch Body Lift Installed *PICS*
- Clicking noise when making U-turn
- got my BruceTS rear bumper
- headlight wire - color?
- Looking for a rear bumper
- A Buzz then a TICK when Braking
- sirius radio
- which fuse blew?
- OEM all weather rubber floor mats?
- what gear do I need?
- old man emu coil question?
- Removing Cylinder Heads - 5vz
- Pulsing Brakes
- Can't line up Torque Converter to bolt on (3.4L V6 AT)
- Front Diff Fill Plug Stripped!!! :(
- Sylvania SilverStar Ultra VS PIAA
- 98 Tacoma Inner Tie Rod End replacement
- Sold the 91 bought a 96
- Charging system alternator question
- 5spd overhaul
- fog light mod help please
- New Sliders Installed
- Problems with CV boot clamp
- Head Gasket Question
- Potential major engine problem advice??
- Buying a 02 4wd Sport Edition
- Newer wheels on taco with locking hubs?
- Getting the Revtek 3" on my Runner today.
- Look what I found online
- Hesitation after giving it gas?
- maybe I am crazy...Adding a Jeep Seat to 3rd gen 4Runner
- New shocks/coils for 2000(mild lift 1-2")???
- Chirping under the hood?
- Water Pump INSTALL HELP ASAP!!
- where are you guys getting your trd stickers?
- Purchasing a truck from out of state - question.
- four wheel drive will not engage
- Easy, effective, Headlight mod - Huge improvement over stock bulbs
- 1kz-te ecu wiring
- Magnifine (sp) tranny fluid filter
- I'll never own another toyota
- Center Console Rattle!
- What type of motor is it?
- Just bought a Tacoma
- Finally took some pics of my 4R!
- Take off shudder
- 2000 4runner Special Edition?
- Natasha's new dance shoes (lot's of pics.)
- TRD4Runner stickers
- 4runner nuisances
- thinking of trading in highmiles for a newer version...
- Is my starter on the way out?
- Do diff drops actualy change CV angles?
- throttle position = 8% at idle, normal?
- Dropping in new motor tips (3.4L V6)
- Truck Bed shaking?
- Don't think I want to post up mods anymore....
- my "crappy, ghetto ass, cheap HID PnPs"
- who sells the cheapest factory yota parts?
- spring colors?
- 4WD light flashing - No 4WD
- Those who have HD Bilsteins and like them are in DENIAL!!!
- fuse location
- Interior Revamp thread, pic heavy
- Got My HID's Installed
- Stock Stereo Dead (accept Radio) in 2000 4Runner
- grill from 01 on 96????
- Largest deckplate for a 3.4L?
- 97 tacoma help CEL on
- Supercharged Emblem?
- 4Runner Transmission Shift Solenoid location???
- Who's dropped their transmission?
- who sells the cheapest O2 sensor
- Hell Creek?
- burning gas
- 3rd Gen Sliders
- Bilstein shocks? worthit? any others?
- sunroof dimension
- Gas Pedal
- 2001-02 4runner tranny prone to planetary disc failure???
- 2.7l intake
- !$^$%!@#!$ O2 sensor
- Intermittent start problem....help!! (long)
- thinkin about this lift
- Shaky, Engine Stalling, Flashing Light
- HELP!! ABS light on after I upgraded tires
- How is this mechanic's pricing on labor only?
- 4x4 Automatic transmission mounts
- TRD supercharger from Toyota
- Shocks for 04 Tacoma 4x2
- Need some Taco dimensions
- wow these OEM shocks are expensive
- Does this exist? A "power strip" for electronics power?
- ABS kicks in on speed bumps, is this normal for you?
- '95 4Runner ? abt 4WD and ? for williemon and for light ?
- Tacoma Gas Mileage
- ARB/TJM Measurements
- Rig Build Progress and 35's
- 96 Tacoma Alternator Problem
- Parting out 02 4Runner LTD
- Can't get spare tire down 99 4runner
- Best cheap, local MT tires??
- 2003 Tacoma V6 auto
