old man emu coil question?
Old Feb 18, 2008 | 03:59 AM
ydopen's Avatar
If a 2000 tacoma prerunner already has a 2 inch spacer lift in the front.
Can you also put in the old man emu 881 springs for 2 more inches of lift?
Old Feb 18, 2008 | 06:42 AM
MTL_4runner's Avatar
If it is a 2WD prerunner, then yes, that would be fine.
Old Feb 18, 2008 | 07:38 AM
ydopen's Avatar
Thanks Jamie, yes it is a prerunner I was just wondering if the coil and the spacer would be too much without a drop down crossmember to get it back in alignment Thanks
Old Feb 18, 2008 | 09:00 AM
jjrgr21's Avatar
it will ride like crap
Old Feb 18, 2008 | 10:22 AM
I don't disagree with this statement, I only said it would work.
Old Feb 18, 2008 | 11:26 AM
ydopen's Avatar
So I need to save up and get the suspension lift with the drop down crossmember?
Old Feb 18, 2008 | 03:11 PM
mpavolka's Avatar
You could but you are better off to just stick with a slightly more mild lift, unless you have to that height. A sub-frame style lift is a ton of work money and on top of that in most cases will make your truck more fragile, but just my opinion, if that's how tall you want it go for it.
Old Feb 18, 2008 | 04:47 PM
No, if you want that much lift then get an adjustable coilover setup for the fronts instead of the OME's an a huge topout spacer. You won't have much travel with that setup and what you do have will be stiff as heck.
Old Feb 19, 2008 | 11:36 AM
cox380's Avatar
It depend on what kind of spacers you run up front. Is it a top out spacer or a spring packer type? Or both? I wouldn't run lift springs with a spring packer spacer. The top out type would be fine.
Old Feb 19, 2008 | 11:55 AM
jjrgr21's Avatar
it will work, no doubt.
Old Feb 19, 2008 | 02:48 PM
mpavolka's Avatar
I would say that it will work, but like everyone else said it will ride poorly. The more angle you put on the A-Arms the more force from bumps is transfered to your frame/cross member instead of to the shock where it belongs.
Old Feb 19, 2008 | 02:52 PM
tacoma728's Avatar
Riding on borrowed time my friend for a 4wd, but 2wd yes. Sure, you CAN lift the IFS 14," but will it fall apart in a matter of miles. Probably. Just because you can do something doesn't mean you should.
Old Feb 21, 2008 | 05:08 AM
Jay204's Avatar
Talked to a rep from Old Man Emu, they recently discontinued the medium coil's for the lift I wanted...now I'm wondering what to do next :sigh:
Old Feb 21, 2008 | 05:24 AM
Yota Runner's Avatar
they quit making the 881's???
Old Feb 21, 2008 | 05:26 AM
tacoma728's Avatar
damn it man
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
defrag4
Jul 31, 2015 10:50 AM
Numberonedad6
Jul 30, 2015 07:10 PM
