PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Hatch size
  2. limited slip or auto locker
  3. Odd sound under boost (SC'd 4Runner)
  4. When buying parts online...
  5. Constant High Idle
  6. front end sway when braking
  7. driving on an undersized spare?
  8. Husky floor liners
  9. How much lift?
  10. tranny cooler "burst"
  11. P0773
  12. Strange sound near passenger side floorboard
  13. Clutch Problems
  14. Wide Open Throttle Power Loss???
  15. compressing springs
  16. Pictures of the black 16" alloy that come with the Tacoma Rugged Trail package?
  17. question
  18. Reasonable Price for a used e-locker motor?
  19. Limited Fender Flare Retainer Pin Part No.
  20. My 4Runner has an unusual odor, help!
  21. Wacky gas gauge (really wacky)
  22. wrecked my runner =(
  23. ARB bumper weirdness
  24. Strange noise
  25. Removing Fenders
  26. Trying to find tires...
  27. need torque values for sway bar bits
  28. 285's and 890's.
  29. Rust and Colorado on 3rd Gens
  30. p0135 p0141 heaters on o2 sensors
  31. ?? about lights when towing
  32. Synthetic ATF fluid change over question
  33. Transmission Flush
  34. 1KZ-TE swap for 3rd gens - in Texas
  35. Bilstein Shock B46-2285-H0 question
  36. New 4Runner owner, gas gauge, diff. lock buton and keyless entry questions
  37. Just did steering rack bushings
  38. clutch
  39. Homemade intake system for 3.4L Tacoma, pics
  40. Code P1349 question.?????
  41. heat not working still
  42. 4Runner remote no worky
  43. Speedometer readings?
  44. Tranny Trouble!
  45. Auto dimming mirror/compass/temp in Gen 3 Part II
  46. 2000 Limited Flare Trim Part No.???
  47. 3rd Gen Front Coil install ??
  48. Steering wheel rattle in steering column
  49. I'm about to buy LC rims for my 4 runner and?!?!?
  50. Napa Gold Taurus Filters: RESULTS
  51. Where to find JDM aftermarket parts for a '96 3.4L 4Runner
  52. Vacuum/Coolant/Other Hose Diameters?
  53. "Plug and Play" HID kits
  54. 2uzfe engine in a '97 4 runner??
  55. TRD brake lines
  56. Bad Things Do Come in 3's..
  57. How much for new engine 3.4?
  58. O2 sensor at 75,000 miles
  59. '97 tacoma bumper and snorkel on a '97 4runner?
  60. oil filters
  61. Fabtech AAL for 95-04 Tacomas
  62. What size wheel?
  63. brake rotors!?!?
  64. Loose rear shock...rattle
  65. 4Runner T-Case Breather Extension
  66. Lights
  67. for anyone who has the crappy cup holders..
  68. tail gate problems
  69. transmission woes?
  70. 2.7L Exhaust/Header/Cat/Test Pipe
  71. Sas?
  72. Does ANYONE have skyjacker coilovers?
  73. New Meats: 285's are on!
  74. Engine SLUDGE TESTER.......man, am I good!
  75. Making MT's fit.
  76. rear 3" spacer lift 96 runner
  77. Smallest Lift Around??
  78. Anyone have documentation on TJM mount modifications
  79. Help! 3.4 camshaft pulley removal
  80. Offset needed question
  81. Sway 20" coilovers
  82. Maybe a stupid question?
  83. the runner is spitting oil...
  84. 1999 - 2002 Toyota 4Runner headlights!!!
  85. Fj cruiser wheels on 3rd gen 4runner
  86. Low Profile Cargo Box 3rd Gen
  87. Bad 3.4 liter motors 99-01
  88. 2001 Taco TRD Coils Side Specific????
  89. tires
  90. 255/85/R16 on a Stock '97 4Runner
  91. Anyone towing a trailer?
  92. hood vibration at hiway speeds
  93. Slow Windows
  94. Removing the dash on a 02
  95. Clearing limited flares with 285's: 1 or 1.5" body lift
  96. LED bulb and flasher question
  97. Guy just offered me $30,000 for my 4Runner
  98. 3.4 timing tensioner question
  99. Looking to buy shocks, any suggestions?
  100. Spent $550 at the dealership
  101. Aftermarket Big Brake Kits 4 97 Taco
  102. Warn Front Receiver Hitch
  103. 01 Tacoma Transmission Whining problem
  104. 265/75 r16
  105. quick Question about Coil packs
  106. Longer wheel studs.. WHERE?
  107. Comparing RPMs & MPH based on Gear Choice
  108. 1500 Wat inverter. How/where to install in 01 Taco?
  109. 4Wheel Shops / Parts places near Gainesville?
  110. Spring Height 3rd gen 4runner
  111. Air Intake Control Valve Install
  112. 4runner Sold!
  113. 2.7 Stripped Manifold Bolt
  114. URD 7th Injector tunning ?
  115. New Shoes - Pro Comp Mud Terrains
  116. Rim upgrades
  117. Finding a Factory elocked Vehicle
  118. Factory Deck: 97 tacoma
  119. Redoing my exhaust
  120. Free factory tweeters-from 99 Runner
  121. Parting Out 2001 Sport
  122. Crashes my Taco...
  123. should stealership do the work?
  124. Supercharger + Fuel upgrades gas milage.
  125. Griot's Garage Products Major PITA
  126. 3rd Gen CLEAR 3rd Brake Light
  127. 3rd Gen [B]CLEAR[/B] 3rd Brake Light
  128. Painted my grill
  129. New Wheels & Tires are On! *PICS*
  130. mud problems got me grounded.
  131. Need to get stuck sunroof shut before winter!
  132. FINALLY! new gears and rear locker!
  133. 3rd gen rear bumper ?
  134. UNBREAKABLE FAB strikes again! TACOMA build, STILL IN PROGRESS
  135. battery light on after mudding?! everything looks fine tho...
  136. 285's...LETS CLEAR THIS UP PLEASE!
  137. hammerrite paint on 4runner
  138. miles out of 3rd gen 4runner?
  139. I need a 3rd gen snorkel
  140. from 16's to 15's?
  141. Where is the o2 sensor plug located on a 99, dammit???
  142. Where to buy MAF?
  143. 2000 4WD For Dummies
  144. Sticky Throttle
  145. Check out my new Tag
  146. PLease Help 99 4runner In need Of Help
  147. No muffler
  148. Power Antenna
  149. fabtech 4" suspension?
  150. From Rolled 3rd Gen to 4th Gen : Mods, Wheels, Tires, lift PICS
  151. Please decide whats best for me cause im tired of searching.
  152. New rims on...but it wasn't easy.
  153. Battery/Starting Problems after 2inBL
  154. 2002 4Runner w/99 springs
  155. New Mods!
  156. Doors dont stay open? (99' 4r)
  157. Leaf spring Dilema!!??
  158. fj springs and landcruiser rims
  159. Found some LC's.
  160. Nagging problems with Tacoma
  161. Just got a 98 3.4 5spd SR5 4runner - what to look for, repair-wise?
  162. Cut Off???
  163. Towing ALOT what do I do??
  164. FPR Vacuum line?
  165. 99 4Runner Highlander For Sale
  166. Supercharger on High Mile engine
  167. Why does it seem like the power door lock button is wired backwards?
  168. If you had 500 bucks...
  169. Good price for a 2000 Tacoma with 200K miles?
  170. ARB install
  171. Power Windows don't Work
  172. MAF question
  173. Need some TACO info- towing, 2.7, ect
  174. 285's Ordered! (Wild Country TXR)
  175. Is this one of the "good" '99's?
  176. Another lift question
  177. Do OME881s have specific sides? Driver/Passenger colors?
  178. how could i get rid of....
  179. 01 Taco has no power
  180. one last note on 3rd gen alignment woes
  181. Very Confused... 1/2" lift from OME881?
  182. Locked, Blocked and Ready to Rock (almost)
  183. 285's vs 255's
  184. start up and idle problems
  185. 15 inch rims on a 1886 r4unner
  186. Driveshaft place to order or buy?
  187. Low Beams out
  188. Climate control issues '2000 Limited Runner
  189. Performance systems for 3rd gen 4runner?
  190. Are all '99 Coil Springs 1" taller?
  191. Which year LC's are Double Purple + Grey + White?
  192. Silverstars
  193. Roor's big build up
  194. HID Conversion
  195. Check out this Tacoma
  196. skid plate taco
  197. where is the a/c intake? 01 tacoma v6
  198. Need advice on towing tires and lift...
  199. Lift options......
  200. Tacoma's 190hp vs. 4runner's 183hp 5VZFE?
  201. Diagnostics problem
  202. ARB-go with 68 or 72 inch
  203. Front Drivers Side Rattle Found
  204. wrecked 3rd gen?
  205. diff drop
  206. I know what I'm saving my pennies for now!!!
  207. anti-rattle springs - how many per caliper?
  208. 2.7L question?
  209. Tundra Brake Upgrade part/advise needed.
  210. Front Differential Breather Hose
  211. Stock 3.4L AFR on the dyno?
  212. Final prep for my Tundra lift and a few questions.
  213. Found this 1989 4runner on craigslist, what you guys think?
  214. Where to wire a 12v outlet? Battery only?
  215. New wheels: konig countersteer offroad, whatcha think
  216. Tuning issues...still
  217. Narrowest Tires on '03 DC Taco, 4WD , V6, auto
  218. Brake Light Question
  219. Another one bites the dust
  220. Reverse Lights quit working ?????
  221. TOYOTA 78 SERIES-Diesel-
  222. Name my drivetrain problems
  223. battery warning light after rough play.
  224. cat removal/ cutout install
  225. CV Axle problem
  226. Should i buy this 4-runner?
  227. 3rd Gen 4runner Base Model Bumpers
  228. Manual Hub Conversion Kit & Tcase Question
  229. Has anyone here changed their O2 sensors?
  230. 96 taco skyjacker lift
  231. Tundra Lift Questions
  232. KZ TE upgrades
  233. Are the cat converter on the 6 cyl. the same as 4 cyl.?
  234. Taco Owners: Post pix of your fabbed bumpers!
  235. Bolt on sliders for 3rd. generation 4runners?
  236. White Grill
  237. Scared to Lift.
  238. E-Locker Identification
  239. CV axle boot issue
  240. catalytic converter stolen
  241. What are some good quality clear corners?
  242. Pics with 265/75 needed please!
  243. New to me 04 Tacoma couple problems..
  244. Bed Mounted Light Bar on a Tacoma
  245. fire!!
  246. '98 Grill Removal
  247. Climate Control screen lights
  248. Toyota FJ Cruiser OEM Coilovers
  249. Auto Dimming Mirror Install Project
  250. Black tail light covers?
