265/75 r16
Old Oct 2, 2007 | 02:59 PM
LJ_24's Avatar
265/75 r16
will these fit in a '97 4runner 4wd?
Old Oct 2, 2007 | 03:05 PM
wormhole's Avatar
That's what i'm running on my 96, with no problmes.
Old Oct 2, 2007 | 05:36 PM
LJ_24's Avatar
96 is a 3rd gen right? jus to clear up confusion...
Old Oct 2, 2007 | 05:37 PM
jjrgr21's Avatar
some rub some don't, at the most you may half to work on the pinch weld
Old Oct 2, 2007 | 06:01 PM
trd_4runnin11's Avatar
Sorry for the stupid noob question and for the thread hijack, but what the hell is a pinch weld??
I'm going to be going with a 3" lift on my 98 4Runner and some 285/75's in the spring and from what I've been hearing im going to need to do something with this pinch weld. Pictures would be wonderful.... Thanks!!
Old Oct 2, 2007 | 06:21 PM
skjos's Avatar
The pinch weld is basically the seam between the underbody and the outerbody. Its where the inner and outer bodies are pinched together, it runs along the underside of the body between the two wheel wells. If you have running boards it is not visable from the outside, you have to be under the truck to see it (I think - I never had running boards).
Old Oct 2, 2007 | 06:32 PM
wormhole's Avatar
Here's a picture or two for reference. And yes a 96 is a 3 gen (it was the first year of the 3rd gens)
Parking lot shot:
Flex/stuff shot, no problems with clearance:
You should be fine but before you leave the tire shop make sure all is well and if any changes to the pinch weld or if you have rubbing issues get them address (like the others have said).
Old Oct 2, 2007 | 06:49 PM
jjrgr21's Avatar
skjos nailed it, go to pirate or ttora or here for that matter, plenty of info on pounding them down..
Old Oct 2, 2007 | 07:12 PM
LJ_24's Avatar
Parking lot shot:
thnx...nice 4 runner!!!
chadbobb
39
Dec 6, 2006 03:57 AM
briang
Aug 18, 2006 11:06 AM
mtbikejeremy
Mar 10, 2005 01:39 AM
sdh1019
Jan 13, 2005 10:50 PM
