- So the new Toyota got hit in the rear yesterday
- Finally a pic of my 97
- Reseting computer after new parts?
- Whats the best 3.4L V6 rebuild kit???
- anyone got 4runner schematics?
- Check Engine light after new plugs...
- 4Runner Fender Flare Removal?
- '99 4Runner MPX B fuse
- lights on the roof
- Fender Flares w/o Running Boards
- Super Charged guys and towing?
- Cleaning your engine bay?
- Taurus Electric Fan mod on the Gen 3 4Runner
- Noob Qs
- 1999+ alternator in 1997 4Runner?
- 97 4runner 2.7 trouble ahead
- My first brake job
- Questions about trailer hitch and body lift
- Replacing rear brakes?
- Saying hi and I need a little help
- New lift = longer brake lines?
- Wiring issues
- Lift Kit advice
- Re-routing tailpipe above frame rail?
- Wheel suggestions: 16x8 4.5" backspacing rims and 285 tires.
- Electric Fan Indicators
- Cant find a bull bar
- Suspension Package Help (lowering)
- Overheating issue .........
- CV joint
- CNG Bi-Fuel Kit or Info?
- Holy close call off roading.
- rear air bags?
- need help with spacers
- Extra key = $175, wtf?
- 1.4kw VS. 1.8kw starter info
- Air Conditioning Problems - New Compressor?
- Are my rear axel seals leaking? Pics
- Stiffest shocks for towing availible?
- "Magic Coils" on 99?
- Any "how-tos" on Injector Removal - 01 Taco
- Lift, and New tires Installed
- clutch noise?
- Child Seat Questions and Issues
- 4Runner Starter Problem?
- OK fellas, just joined the fold. . .
- Side view mirror replacement
- Help... Warning lights stay on
- badging/ debadging
- How much lift to run 285/70/17's on 99 Runner?
- HUNTER BULL BAR_ light vibration
- rear diff fill bolt size?
- 255/85/R16 on 16x7 rims- what do you think?
- clunk in rear end
- Rain flow solution for 4runner?
- Dimmer for those sometimes too BRIGHT LIGHT'S we love!
- 15" OEM Alloy wheels on a 2004?
- 96 4runner, over 300K on it, what to look for?
- Think you should know
- Help PO171 code with symptoms
- 99+ Headlights
- A Taste of Heaven...scooped hood for a day
- Water pump gasket
- Wider fender flares
- Tire wear after lift
- Electrical Gremlin
- smoke headlights?
- Toyota Hydraulic Hood Lifts
- Idle down slowly
- Any suggestions for new shocks?...
- pic request of FJ rims on 4r
- Tire suggestions & setup for deep sand?
- New style waterpump gasket
- Shoulder Belt Option for Rear Middle Seat on 4Runner
- Hungry Valley SVRA, CA. PICS!!!
- Brake conversion info needed
- Clutch Problem
- System Rich?
- '98 4Runner Limited misfiring?
- e-Locker, is it the best setup
- What's this part
- stock coils, where can i buy them?
- Got a 4Runner! Pics
- How to prevent fender flares from fading?
- Clicking Starter
- What more could I need to do?
- Good repair Shop in UTAH?
- Limited mud flaps are screwed up
- How Much Play is normal in front CV Shafts?
- Updates to the 4Runner
- Lesson learned - The ground next to a lake isnt as sturdy as it may look.
- New Exhaust and Lighting
- lower coleman rack
- door molding is loose on limited '96
- Can I Convert a Non-ADD front diff to ADD to work on my Truck?
- O2 sensor replacement?
- Build or buy light bar?
- Removing Steering Rack Bushings
- Thinking of buying a 3rd gen 4Runner
- 02 sensor
- Made some new swaybar links
- before and after pics and my new toy
- 200k(+) miles ONLY
- Return of the gas smell on my 99 runner V6 4WD
- Weather Stripping Issue w/ Pics.
- Weird HVAC noise
- 3rd gen fog lights
- whos tried brake light tint
- ISR vaccuum question
- looking at a 2001......
- suggestions on lift up Tacoma prerunner 4x2
- searched still a question on rear axle seal
- Another New Mod for a Gen 3
- Resale Value down for Tacomas/4Runners?
- 906's in rear only
- Performance Products Springs & Bilsteins, Nitto Terra Grapplers
- Changing tire size. Stock 31's to All terrain 32's. Do I need to re-gear???
- New dash kit?
- New 4runner owner seemingly common oil question
- Top bolt front strut issue
- BFG km2's- will they fit??
- tires on 17's
- potential rear axle problem
- New Front Lift: OME 882's Have Arrived
- Tacoma front end conversion, Help pick
- removing plastic lower valence
- tacoma frame buy back
- imeadite help wth horn honking
- Need a New Clutch
- 4R OEM Suspension height change: 98-99-00+?
- Will 2nd gen Tjm-17 mount on 3rd gen 4runner?
- Guys, need some expert A/C advice for 97 3.4
- Non Tech-Help Tellico
- Need Info On Wheel Swap
- 1995 Tacoma should I buy it?
- 2004 tacoma with total chaos
- 15 inch rims on 4runner?
- Fuel Problem
- rear window question
- Throttle Body HELP!
- Lug Nut Torque?
- Differentiating between Left and Right rear Leaf springs.
- IACV throw a code?
- New lift, wheels, and tires installed!!! (PICS!!!)
- '97 4Runner sluggish
- Pulstar spark plugs
- Rear tire carrier, what ya think?
- For all of those with the Power Surging Problem! Interesting Problem Found!
- Need pricing help....
- new tires. one rubs
- Land Cruiser coils and shocks for 4runner
- Wiring for trailer on '99 4Runner
- Kuzeh thermostat ?
- retrofitting seats into a 3rd Gen
- Altitude sucks - need more powa
- thanks guys
- Hesitation accelerating from Idle
- Tranmission Flush procedures for 02 4runner
- Tundra brakes installed....PROBLEM
- fuel pump wiring
- We flipped our truck, but we aren't ready to scrap it.
- Stereo Wiring Harness - Some leftover wires..
- zMax for engine/transmission
- Does toyota dealer sell remanufactured waterpump?
- 4.30s...
- TRD Coil vs Non-TRD Coil Pics
- leaking roof
- 98 runner engine dies at idle
- 3rd gen gear guru's
- wheel question?
- end all the MPG B.S. get this [or similar] or
- Pics of my '02 Sport - Finally
- USED SEQOUIA RIMS for my runner?
- SS 7.2 on it's way!
- a/c not so cold
- Gas Mileage
- Diff question
- 96 - 02 rear wiper motor replacement
- My Running Boards Story
- New Feet for my Tacoma...
- CEL after fuel filter change
- Tire size and pro comp wheels?
- Anything to worry about from driving down a flooded street?
- gas mileage for tacomas
- Got the Factory Hitch.....need hardware to mount
- New wheels/tires, pictures
- Best place for OEM badges
- OEM rims? link to pics
- quick help tranny valve body
- Head Gasket?
- 3.4L Idle issue
- I've decided to sell my 4Runner
- Idle high after installing Poweraid Throttle body spacer???
- Best place to sell 2002 4Runner Sport 4WD
- Pinging! Cheap gas? Fuel Filter? Injectors? What gives?
- Fuel injector yet again....
- 2001 4R V6 4WD SR5 - Birmingham,AL
- 2000 SR5 factory speakers
- tapping map lights into dome light
- which wheels do u like better?
- will 2nd gen aftermarket front bumper fit 3rd gen?
- 5100's
- Changing Light Bulb color
- door chime
- Help ! Sudden Drop In Gas Mileage, no codes
- new 4Runner owner
- Smell radiator fluid through vents....
- ? about ext. length shocks
- TRD exhaust?
- Vibration above 55! Only on the gas!
- New Custom Off Road Bumpers
- Considering 98' 4-Runner - trouble spots to look for?
- She's feelin' a lot better
- starter wires
- a/c not working
- what do you guys think of this tire?
- 15" steelies pro comp question?
- bolt pattern?
- pp springs on,(pic)
- Ticking sound from Driveshaft
- Help with LED Tail install........
- EGR fender flares
- catz
- Chaotic Idle Then Death!
- I need a shift tower spring...
- Spark Plug Gap??
- Cost of OEM Plugs and Wires?
- Replacing my motor
- Squeelin sound from tailpipe
- Looking to buy...Need some opinions! (pics)
- Project completed w/pics
- 6spd manual in a 3rd gen 4runner?
- front diff seals and axles
- gear oil and trans questions
- Pics of the 4runner
- Cost$ for Automatic Transmission Service and Rear Differential fluid change?
- Interior led question...
- Speaker Hum when lights are on
- Ticky Motor
- Farewell 4x4
- A Very Sticky Clutch
- do your shifter lever and 4WD lever get hot?
- What causes this?
- can u scan for codes on a 96 4Runner
- Temperature swith location on a 96 4Runner 4x4
- What to look for when buying a used 00 4Runner?
- Front bumpers
- Water?
- question about trd supercharger 3.4
