How Much Play is normal in front CV Shafts?
Old Jun 26, 2008 | 08:49 PM
Mojo_Risin's Avatar
I noticed today that the front passenger side cv shaft will slide back and forth (from diff to wheel) about 1/2 to 3/4 inch when i grab it and move it back and forth (in and out of the diff). Drivers sides seems to only move 1/8 inch. Is this normal?
John
Old Jun 27, 2008 | 03:57 AM
AppleJack's Avatar
I'm thinking, that's too much play. Mine doesn't do that.
Old Jun 27, 2008 | 04:17 AM
crews462's Avatar
I seem to have more play in my passenger side as well. That sounds a little extreme though. If it's a recently installed cv, bring it back and even say it's clicking, should replace.
Old Jun 27, 2008 | 05:09 AM
Vermejo's Avatar
Don't worry, that's normal. Mine are both new and move at the CV/Diff a bit. You will know when it breaks.
Old Jun 27, 2008 | 01:05 PM
Mojo_Risin's Avatar
yeah - this just seems wierd - the entire shaft moves in and out about 1/2 inch...like inside the boots. Went wheeling last weekend and got on it a little hard in one spot when my locker switch wasn't working. This is an aftermarket CV. Hmmm. Gonna take it into the shop - the suy who hsa replaced both my cv shafts said that's not normal at all...
Old Jun 27, 2008 | 02:33 PM
Vermejo's Avatar
If you are talking 1/2 not 1/8th, then you have a problem. Locker problem in most cases should not relate to the CV. Aftermarket CV or not, they all die young.
Old Jun 27, 2008 | 03:02 PM
Mojo_Risin's Avatar
Well, I'm saying i was in a tough spot and since my locker wasn't working, I had to use a little more throttle than i would have needed if i was locked - so therfore i think i spun the wheels and heard a lound bang - but didn't think it was a CV as it wasn't ripped open and spewing grease like I've seen others.
But it was a lifetime warranty axle so - it's free replacement.
John
Old Jun 27, 2008 | 03:17 PM
Goin's Avatar
Mine did that brand new never installed
Old Jun 27, 2008 | 05:13 PM
Mojo_Risin's Avatar
What do you mean? They slid back and forth like that????
Old Jun 28, 2008 | 04:44 AM
Vermejo's Avatar
John
Clarification understood. I also thought we were talking about play at the inner CV flange where it overlaps the axle: movement here is normal. If you grab the shaft between the boots it should not move. If it’s lifetime, replace it and get peace of mind.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
A2theK
Jan 10, 2016 10:18 AM
Hamonacracker
Jul 17, 2015 08:33 AM
andrewtexas123
Jul 14, 2015 04:29 AM
