02 sensor
Old Jun 25, 2008 | 06:49 PM
kyle c's Avatar
02 sensor
anybody know how much an o2 sensor costs? and is it easy to replace? have a 98 4runner 4 cylinder. could i buy the part and do it myself?
Old Jun 25, 2008 | 07:26 PM
BigBallsMcFalls's Avatar
about 120 for dealer cost, 2 new nuts, and gasket
ez to replace
need a 12mm box wrench, or small vice grips
may need a small chisel to chip off the old nuts
then you need to scrape the old paper gasket off
so the bung is 100% smooth. again, chisel is great for this
new o2 sensor, new gasket, 2 new dealer stainless steel nuts
just climb under there and crank it off.
use eye protection a lot of crap will fall on you
Old Jun 25, 2008 | 07:54 PM
Ohio4R's Avatar
Check out URDusa.com pretty sure they are cheaper than the dealer.
Old Jun 25, 2008 | 08:01 PM
pauliep13's Avatar
X2 on the eye goggles.
I've used www.1sttoyotaparts.com before and been pleased. They are the online department for a WA dealership. Usually have cheaper prices than your local dealer, and lower prices than your local dealer's online dept, too.
Did a quick check, looks like it'll be about $100, probably add $10 for shipping. Call the local dealership to get th correct part(s) number, then look around online, usually saves some $$$ if you can wait a few days.
Old Jun 26, 2008 | 05:28 AM
Fink's Avatar
URD all the way.
Fink
Old Jun 26, 2008 | 06:47 AM
mkgarrison5's Avatar
Originally Posted by 4x4Fink
URD all the way.
Fink
are those the ones you have to splice??
Old Jun 26, 2008 | 07:57 AM
cackalak han's Avatar
From the link:
These are direct replacement (not the universal cut & splice) sensors.
Read n00b!!!
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
