- 87 4runner
- 2006 Toyota HP & TQ ratings
- Fogs on TJM
- Who makes this bumper
- 2nd gen interior colors?...
- Cat converter heat shield question...
- Buying a Taco: Get TRD or add ARB locker?
- relay? for electric fan mod
- I need a part number for a part I dont know the name of!!
- 31/11.50-15 tires Who sell them
- no more on-the-fly?
- 1990 V6 - Engine Sick
- I can't part with my 99 5spd 4runner
- Black smoke on start up
- 22r head bolt torque
- Nerf Bars
- Time to swap engines
- 3.75"backspacing ok??
- CEL Trouble code P120? Edit:Throttle/Pedal Position Sensor
- Runners Rock!
- 1991 4runner hard to start, lots of turning over.
- 3rd Gen Liftgate Problem
- Which flowmaster do I need?
- Auto Transmission Flush question/help
- New Member
- 1998 4Runner won't start sometimes
- Underdrive Pulley? N/A and Supercharged? 7-14HP cheap
- Hella FF50 driving lights
- max speed when in AWD (multi-mode 4WD)
- 2nd Gen. Trans Cooler
- CV Axle questions Boot vs entire axle? Quality?
- A few pics of my 4runner 1990
- 4HI pulling to the left
- Rear disc conversion w/ E-brake
- Has anyone ran 35's with stock gearing?
- 4Runner injector upgrade p/n
- 2 muffler myth
- 3rd Gen Front Mud Flaps
- Headlight Always ON
- Looking for some good all season tires for the gunner...
- Early runner + pickup AC button pin Configuration?
- New intake tube for my 22re
- No. 6 Cyl Mis-fire in 1997 SR5 4Runner
- 89 4runner sitting for 3 years
- What's wrong with my window!?!
- Do 1999 or 2000 Limited 4Runners have heated seats?
- Installing key less entry(valet712t) on 1992 4Runner
- Now wat is wrong with our 4runner?? Temp gauge wacko w/ heater on??
- 2nd gen 4Runner Spare Tire Carrier
- Harder steering on left turns
- TCASE PROBLEM - NO LOW RANGE: 85 4Runner w/ Auto
- Huge Improvement !
- Shocks that dont STAND???
- Exhaust "plan" for my 3.0
- 3.0L: 2.25" Mandrel bend vs. 2.5" Crush bent?
- New Tire Squealed for no reason
- Help me with a problem on my new Runner
- headlights shine outward?
- Battery Question
- Code 420 from the PCV valve?
- The MILKSHAKE problem... Help!
- 3rd gen 4Runner manual FSM ?'s
- Aisin Hub Rebuild
- Seat belt reminder bell disable! Woot!
- good tires ?
- Heads up on Fuel Sender TSB
- Porting and polishing
- Magnaflow exhaust at Summit Racing for 05+ Tacoma
- Manual Locking Hubs
- Hella H4 conversion?
- need help with hitch/wiring
- Centering steering wheel?
- Gotta laugh...wherever I go, I find Corey's truck.
- 2nd gen folks with factory roof rails...quick measurment
- 3rd Gen neutral safety disabling switch, to get truck out of mud etc.
- Removing Blower Motor Fan Assembly
- rim choices!!!
- Back tires break loose on wet roads?
- changing from 15" to 16" wheels. backspacing question..
- 2nd Gen 4Runner?
- Changing belts on 02 runner
- Flat Tow Bar
- Can I use a MSD 6?
- 3rd Gen 4runner auto tranny pan removal????
- Fresh Meat(s)
- New to Yota's... Where to start?
- First mod on the 2000 completed - Yakima rack pics
- Unknown 4runner brake part
- OD Tranny problems after new mods
- 4Runner 97 rear sag (question from Chile!!)
- Question on '06 Tacoma limited slip
- New Guy Saying Hello
- 3rd Gen keyless entry question
- how much for valve replacement?
- Noob tire and rim Q's
- Milling 22RE heads
- Would a new cam help with resale value?
- Rims - quick question
- Energy suspension F+R endlink part number
- 36s on stock IFS??
- Timing Guide Bolt stuck in block
- Had a car fire this morning
- motors bolting up to toy tranny
- Tutorial - PICS how to remove doors on 04 Taco - Sound deadening
- I got the original hubcaps, now I need the wheels. Can you help?
- rear speakers and lights dont work
- Fitting tires under my 87 pickup
- clutch is done for need some advice
- q? for those who have done a 3.4L swap?
- best lights for tjm-15
- Hella Optilux Angel Eyes
- important bolt stripped, need solution
- Air/fuel mix gauge install on 22r
- Replacement Seatbelts?
- Stock axle gears?
- How long do balljoints last?
- 3.4L Cam specs needed.
- IS this YUKON kit indeed a TACOMA kit?
- 3.4L Valve Clearance Adjustment
- Best price for Lightforce lights?
- 19 exrtra hp? Does this seem plausible?
- intake tube for first gen 3.0
- 2001 Taco 3.4 Engine Valve Adjustment
- New Rocker Arm Set For 22R - $111.90 - Shipped!
- Seat Conversion
- New Exhaust
- I took the first big step toward selling the 4runner...
- Dome Light Problem
- another will this fit question, intake for 3.0
- New Here
- man am i excited
- Tips For Better Gas Mileage
- Insurance?
- resonator & ISR mod
- First Gen 4Runner Trim
- How much could I sell my rims/tires for?
- a/c panel. will this fit?
- added a coinholder in console
- 3.4L missfires sometimes???
- checking fuel pressure on 95 3.0 4Runner
- Stock 4Runner wheels are pretty nice...
- Best gears to buy? What brand?
- 95 p/u with new 32's please help!!
- How to test AFM
- Duralast or Bendix rotors?
- How loud is the Airraid M.I.T.?
- the new 4runners
- Faulty rear door latch: 3rd gen 4Runner
- 4 cyl 4x4 3rd gen
- Considerations for removing sun shades?
- Cargo Cover for Third Row Seat Model
- 88 PU's replacement wooden flatbed
- Anyone know about this part?
- Typical 22r oil temp (what guage to get)
- CEL... and questions..
- Going with a Flowmaster, should I go dual?
- Another EBAY auction claiming this and that, does it even work?
- '01 coolant system capacity?
- still getting CEL after O2 sensor replaced
- Camouflage patterns? Where to get?
- New 4runner! (finally!)
- 97 and up toyota truck axle codes
- Please post pictures all years...
- Complex A/C idle-up problem after tranny swap
- Question about 3.4 swap with manual tranny.
- I'm thinking about getting a flowmaster, help
- RS3000 going crazy! Help needed
- Power options HELP!
- leaf spring help
- Removing the fender of a 2nd Gen
- New engine steams and water out tail pipe...PLEASE HELP!
- Transmission leaking into Transfercase?
- Cal State Univ Fullerton, who's lifted Runners?
- removing running boards
- Air Horn installation..
- '90 Check Engine Light?
- May be buying a 1st Gen 4Runner
- Proud new owner of 3rd gen
- 91 4runner wheel base?
- HI and Goodbye!
- Anyone ever take chrome wheels, sandblast , paint black?
- Black steel wheels
- Chrome Exhaust Tip
- Flow rates of 22r intakes, carb, FI and Turbo?
- HELP-Fuse for Gauge Lights??
- Why is there a weight on my transfer case?
- 99 4Runner SR5 for $9K?
- Clicking sound
- 2.7 factory exhaust diameter
- Need some Bed Dimensions
- Looking at 95 - new engine - what to look for?
- High Idle on Start (96 4Runner 3.4L)
- HO 5.0 or 302?
- Piaa 540 xtreme whites...how do you like them
- power lacking
- 16 x 9 steelies...do they exist???
- End Links
- 3rd member backlash setting
- Question about 88 manual hubs to a 95
- what is my liter on 94 4runner?
- Tires for my '99
- Performance 4runner? 10-12K budget 3rd Gen
- How much does my tranny weigh?
- hey i got a new 4runner
- Costa Rica 4Runner help
- Group buy and sale info!!
- Anyone up to helping?
- Toyota Oil Quality?
- Amsoil question
- driving lights
- Oil cooler and light bulbs...
- Need a motor for '92 4runner!
- muffler shop in phx recommendation?
- 3vze motor opinions wanted
- Pics of removing dash to get to Speedo-Cable?
- New Suspension!?!?
- Front Brake Vibration
- 3rd gen front bumper removal
- OME shocks - ride on the road (2nd gen)
- Need to replace my stock Cat converter what...
- How do I take out the rear bench?
- Whats this part for? Need help!
- 3rd gen liftgate
- HUGE 1st Gen in Keller,TX
- Wut tires do i get!?
- Reasembly of power antenna?
- CV Joints/Front axle question
- Where can I buy a new 1st gen tailgate?
- Just saying Hi
- Which starter contacts should I purchase?
- Cost to install gears?
- Brake fluid or Diff fluid?
- spun main bearing
- 2nd gen tie rod part number
- Alot of questions about MAJOR SERVICE
- leaking from rear axle???
- Any unique body repairs as a result of killer body rust
- 2wd 3rd Question...
- adding rear heat and a/c to a 2nd gen 4Runner
- A few 3.4 questions
- Please have a look at my updated 4runner (New 99+ painted bumpers, grill and lights)
- 200,000 mile milestone...took some pics w/ the new wheels:-) (sorry 56k)
- Like "Iceland type" Rigs? Check this out!
- stock cat diameter
- will this bumper fit???
- Question on wheel bearings
- Just had remote start installed on my 4runner
- Yay, Look!
- 92 toyota hilux 22re 2200 miles
- Did my clutch go out?
