3rd Gen Liftgate Problem
Old Sep 29, 2005 | 09:36 AM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
I have a 99 limited 4x4. My problem is that my rear liftgate has stopped working. I've tried unlocking it with the in car unlock switches, the key fob, and with the key, even when unlocked it still will not open, however the rear window will still roll up and down. It seems that the handle mechanism is not catching or that it is simply not unlocking. I wanted to get suggestions before i go to the stealership to see how much it will cost. Any suggestions or similar problems?
Old Sep 29, 2005 | 09:47 AM
bamachem's Avatar
it sounds like the linkage has popped off the handle mechanism on the inside of the door. you'll need to take it apart to get to it. if you take it to the dealer, expect at LEAST $100 charge to fix it. it would take about 30 minutes for you to take everything apart and possibly fix it yourself and then reassemble it...
Old Sep 29, 2005 | 09:53 AM
MTL_4runner's Avatar
This is pretty common:
https://www.yotatech.com/forums/f2/3rd-gen-rear-latch-58644/
Old Sep 29, 2005 | 10:00 AM
nc994run's Avatar
thanks for the help, i'm gonna take it apart his evening, hopefully its something easy like the nuts becoming loose
Old Sep 29, 2005 | 10:02 AM
I think Andy meant to post that here:
Originally Posted by bamachem
see the white plastic thingy in the pic posted above? that's a rod retainer and if it breaks, then the actuator rod will slip out and you won't have any linkage to the latch mehcanism. replace it (avaialbe at any auto parts store or the dealer) and you'll be good as new.
https://www.yotatech.com/forums/showthread.php?t=58644
Old Sep 30, 2008 | 11:26 AM
JulsTirn's Avatar
same problem, I shall disassemble tonight
Old Sep 30, 2008 | 05:48 PM
nc994run's Avatar
My problem ended up being that one of the nuts that held a linkage arm had worked itself loose, hopefully its that easy for you
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
tpd143
Jul 7, 2015 09:06 AM
coryc85
Jul 6, 2015 04:07 AM
