PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Need auto tranny help
  2. Where is my oil pressure sender located
  3. Foglight install help
  4. More on Optima batteries / Panasonic
  5. All Pro Wheel SPacers or Sonoran Steel Shaved upper A arms
  6. Replacing wood trim??
  7. Who owns a heavily modded green 3rd gen in Littleton, CO with a custom rear bumper?
  8. Installing OEM lift on 3/18
  9. ISR parts list thread?
  10. Show Me Pics of Your Rear
  11. Tires and shocks ordered!
  12. Transmission issue on 1997 Tacoma 4x4, just bought it!
  13. Another “Deck Plate” mod done.
  14. Whats top speed have you hit?
  15. 4.10 front, 3.9 rear... oops
  16. Replacing Suspension
  17. What to do with sway bars+lift?
  18. Hood Scoop Mod + 99-02 Style Headlights (Long but Informative w/ Pix!)
  19. Malfunctioning Locker Caused Wreck?
  20. improper backlash sound?
  21. which headlight bulb to use
  22. Ebay supercharger
  23. Tacoma lift on 99 4runner
  24. error code came and went..is this good?
  25. 2001+ 5VZ-FE tubular exhaust manifolds
  26. Thoughts about Thule MOAB rack
  27. How much oil and what weight?
  28. Writeup/Direction for using an air paint sprayer...
  29. MAF differences?
  30. inner tie rod wrench size needed on 3rd gen
  31. O2 sensor - change both if one goes bad
  32. Where do I get a new tranny?
  33. OME/SAW lift on a 2000
  34. Removing small dents ?
  35. What part is this?
  36. *update* pictures of broken front diff
  37. Hood release cable
  38. New Scoop Hood + 99 coils
  39. were the tacomas equipped with the 2.4 engine?
  40. The URD AFR Calibrator Question
  41. 3rd Member Locked and Loaded but where to buy?
  42. wheelers steel wheels 15x8 on 4runner pics?
  43. '01 tacoma door pannel
  44. OME=lift?
  45. Options for 98 4Runner SR5 Keyless Entry
  46. 2003 Tacoma- Squeek in rear suspension
  47. Tranny Flush
  48. 98 4Runner Turn Signal Causes Headlights to Go Off
  49. time to get LOCKED!
  50. FTC Vehicle Specific Installation Guide
  51. 97 4runner 3.4ltr mpg??
  52. Is it sabotage?
  53. Whos using dash mounts for cell phones and other devices? Pics?
  54. 3rd Gen 4runner or Land Cruiser FZJ80? For a DD with 2 under 18 months?
  55. Fluids leaking from my 98 4cyl!
  56. LIFT Q's ETC...
  57. WHOS WHITE 3RD GEN is this?
  58. pro comp series 97 wheel?
  59. In-Cabin Rear Door Latch?
  60. Who runs the dunes in their 4runner?
  61. Does anyone have these wheels?
  62. Tacoma CV axle fit 4Runner??
  63. Color to paint Limited Fender flares?
  64. pic of parking brake pivots
  65. Door Jam Sticker reads 15in
  66. Adjusting air direction doesn't do much?
  67. Tacoma Springs and top plate
  68. tacoma corner lights
  69. old man emu coils and shocks
  70. Squeaky Belt Fix
  71. 02 4Runner Radio Antenna Stuck Up
  72. plastic fuelcell
  73. Bilstein shock and tundta coil??
  74. Pics of orange corner lights!!
  75. Finally!!! I am a 4Runner owner!
  76. TRD Tranny Cooler Install Manual
  77. 4.30 rear r/p and 4.10 front r/p?
  78. 3rd gen 4Runner Fog Lamp Switch - Part number?
  79. Looking to get a tacoma few q's
  80. Lost too much? Is this too much for a bandaid?
  81. Leaky CV's after lift on 99 4Rnr IFS
  82. Timing Belt
  83. bad smell
  84. Cold morning troubles: battery and transmission related
  85. Oil Leak Help
  86. Homebrew belly skid?
  87. Fuel Pump/FP Relay locations...
  88. Help with front diff removal on 97 4R, **SEARCHED**
  89. 3rd gen upper ball joint install q's
  90. pic request please. post 1.5" BL 3rd gen 4R
  91. Grease??
  92. couple pics for you guys...
  93. URD Install Finished and Results!
  94. Oil filter relocation warning!
  95. TRD Off-Road Package?
  96. 2000 toyota tacoma ECT button?
  97. Barely Passed Smog - Bad EGR?
  98. Overheaing (need big help here)
  99. Off-roading in a 2.7 4cyl 2wd?
  100. 98 4R Rear Axle/eLocker Swap
  101. looking for a little more power from my 3.4
  102. 01-02 tails on a 99 4Runner
  103. New scratches need to be rubbed out...which Porter cable?
  104. 1" BL installed, Mod'd TJM, No Gap!
  105. 1996 4Runner Straight Axle Conversion Web Cam - March 15, 2006
  106. Lo Jack. I need to get one. Can you install it yourself?
  107. Engine swap 2.7 to 3.0 or 3.4?
  108. JARDINE EXHAUST *installed*
  109. sand blasting wheels
  110. I'm commiting suicide ... :( (sway bar problems)
  111. Need Help ASAP-Speed Sensor Location?
  112. Just bought all of my stereo stuff
  113. Lower link bolt size?
  114. Starting Issue
  115. Anyone have 96-98 cloth interior w/ woodgrain?
  116. 95 Tacoma Squealing Noise
  117. ARB Air Lockers w/ center diff...
  118. valve adjustment
  119. Deckplate modification + stock air filter, weird result
  120. 4Runner vs Tacoma valve body
  121. Cheap bastards idiot guide for fixing fast blinkers after LED swap
  122. 3rz "flutter" while cranking over to start
  123. Question about removing steering rack
  124. Daystar Coil Spacers
  125. Used 3.4 Supercharger Pricing and take-off
  126. Wierd Noise From 4lo
  127. Tacoma lift question
  128. over heating with new radiator
  129. Vibration inside front diff carrier questions
  130. blown diff in 97 Runner
  131. R+P interchangeable between models?
  132. HID pics finally
  133. Check engine light - P0340 (Camshaft position Sensor "A")
  134. Wynn's transmission flush: is it ok?
  135. Please help settle a locking diff dispute
  136. Replacement bumper
  137. 3rd gen grill on ebay ready for satoshi:
  138. Suggestions for mods??
  139. 2000 4runner electrical/lights problem
  140. 2001/2002 Full Time 4wd, and 4wd systems
  141. Did my 97 Limited come with taller coils?
  142. Powder Coating Cost Question
  143. No 5-speed double cabs?!?!?
  144. Fuel return lines?
  145. SMT6 Users...remove your maf "Upgrade" soon
  146. NEW PICS -waxed, shiny wheels, headlights, nerf bars, mud guards *PICS*
  147. What plugs/wires do you have on your 3rd Gen T4R V6?
  148. 01 SR5 T4R ck engine and vsc off/trac lights - resolved/warranty
  149. Anyone Heard from the URD Guys?
  150. MPG Getting Worse!
  151. Will a SCed engine run if the SC belt breaks?
  152. Stalling at Lights
  153. Satoshi is ON!!
  154. P0171 Code and its not the MAF!
  155. 3rd gen wheels on 2nd gen 4runner
  156. calling all tjm15 winch owners
  157. Rear lift for 4Runner
  158. Stalling every time I let off the gas..
  159. buying from rental companys
  160. Strange Grinding noise (bad pilot bearing?)
  161. Replacement Headlight Bulbs
  162. OME 881s Installed on 2001 4Runner
  163. Does front drive shaft turn at all with 2wd and ADD?
  164. 3 words Squires Turbo System
  165. Post 3in Lift on 99 4Rnnr + seized rear lug = broke
  166. 3rd gen 4Runner CV boot replacement - which procedure to follow?
  167. Rims, what year are these? value? vibration issue?
  168. loose crankshaft pully
  169. taco 2wd non trd rear axle(5lug)
  170. Timing belt tensioner problems
  171. Not-So-Lifetime 3rd Gen Fuel Filter
  172. Oil filter access
  173. 04 Tacoma, can't fill up with gas?
  174. Tundra/TRD lift question
  175. antenna, timing belt and running board questions
  176. lug nuts
  177. Bad alternator?
  178. rear spring conversion
  179. cylinder 5 misfiring
  180. Looking for '97 4runner lower ball joint
  181. FJ80 Shocks and Sonoran Steel Lower Control Arm Flex Pics
  182. Which coil pack to which spark plug?!?!
  183. Hub pop
  184. Gas Guage Problem
  185. Need Smittybilt grill guard instructions
  186. Which manual hub swap?
  187. Manifold Exhaust Leak?
  188. New Rear axle vs gear work: Opinions
  189. Lift And Tires Vs Mpg
  190. Rear Axle Leak Clarification
  191. 98 surf lift/tyre size noob
  192. Adjusting the rear brakes
  193. Any advice for trac bar install?
  194. sticky caliper?
  195. should i buy this taco?
  196. Brake Issues
  197. How much does the hood weigh?
  198. 1997 runner gas tank only holds 15 gallons???
  199. URD Install - Issue with S/C
  200. 99 4runner tire size
  201. tundra coils on my 96 4runner
  202. CRITICAL LAND USE MEETING: Prescott, AZ. - BLM comment meeting
  203. So if 99s and 2000s have taller springs then...
  204. 97 4-RNR Horsepower, where did it go?
  205. Problems with shaky acceleration
  206. fuel injectors on 2.7L
  207. Replacing engine/tranny/ecu - 2000 Taco
  208. Door/alarm remote
  209. W59 tranny question
  210. Replacing dash back lights
  211. 3rd gen spring size
  212. Clutch pedal/clutch problem: help needed
  213. Prerunner 4x4 conversion
  214. My Next Mod?
  215. Differential for '99 V6 4Runner Limited
  216. 4runner advice needed: upgrading wheels size
  217. Is a 32 11.50 15 BFG MT/KM too small???
  218. need help on tire selection
  219. A340F Transmission Filter Gaskets
  220. Professional Camera Phone Pics NEW BREED of Runner.
  221. front diff seals keep blowing, mechanic stumped
  222. Re-Torquing Drive Shaft Flange Bolts
  223. just ordered toytec lift, is 3" too high???
  224. trouble with the diff breather mod
  225. Pro Comp 4" lift on a 3rd gen 4Runner
  226. Maint. on a 2.7 L Engine
  227. PIC REQUEST**3rd GEN BAJA STYLE front bumpers
  228. Hood Float
  229. hard shifting...but really only in 2nd gear?
  230. "Popping" Sound at Idle
  231. Coil Swap write up
  232. Differential oil leaking from the breather. How much is too much?
  233. 4runner coils
  234. Fitting GX470 wheels?
  235. Opinion on suspension set up
  236. Low Throttling part 2
  237. 63" chevy rear springs on 98 taco?
  238. rear chevy springs
  239. 295's on stock suspension.
  240. Sway bar disco comparison
  241. Front Breather Leaking oil
  242. Trailer Wiring Converter
  243. glass headlights for 1998 taco.
  244. Questions on installing PP 1" lift springs
  245. Please help with bulb part #'s
  246. WAAG FrontRunner
  247. Wiring for a "free backing solenoid"
  248. Body lift installed!
  249. Toytec lift question/ Vibration/RE: Drop Diff needed?
  250. work truck with box, suggestions?
