over heating with new radiator
Old Mar 8, 2006 | 11:16 AM
TX-BLKRUNNER's Avatar
over heating with new radiator, but not when thermostat in? water pump is good, and does not look like head gaskets are leaking, has anyone had this same problem? oh yeah the engine is the 5vz-fe
Old Mar 8, 2006 | 11:18 AM
wjwerdna's Avatar
new radiator cap too? sometimes an old one will not seal right with new radiator, keepign system from pressurizing correctly...
Old Mar 8, 2006 | 11:45 AM
yeah all new. took the water pump off and there is no blokage in the block.
Old Mar 8, 2006 | 12:31 PM
89macrunner's Avatar
i know this is a stupid question but do you have any air in the lines?
Old Mar 8, 2006 | 04:09 PM
Mr. Bob's Avatar
If its not a Toyota OEM theromstat I would start there.....
Old Mar 8, 2006 | 05:11 PM
Gerdo's Avatar
I would agree: Air in the system, Bad Rad Cap, Bad Thermostat.
Could also be a bad/soft lower rad hose that is collapsing.
Old Mar 8, 2006 | 08:14 PM
MTL_4runner's Avatar
Did you buy the new radiator hoping to fix the overheating? or was it some other issue?
You might want to read this thread for help with diagnosis:
https://www.yotatech.com/forums/showthread.php?t=79202
Old Mar 9, 2006 | 11:56 AM
yeah hoping to fix the problem, and it was indeed stoped up, my temps have dropped and now it does not reach opperating temperature as quickly, but i did put the new oem thermostat and then it over heats, i am narrowing it down to a faulty water pump, it made a wierd noise today.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
LotOMiles
Sep 14, 2015 11:45 PM
--Oz--
Sep 6, 2015 01:06 AM
