Oil Leak Help
Old Mar 11, 2006 | 10:11 AM
GreenTRD's Avatar
Oil Leak Help
I was doing an oil change today and noticed I had a little oil leak. Towards the rear of the oil pan there is oil seeping out. The rear end plate had oil all over it but when I took it off and exposed the drive plate there was no oil on the back of the rear end plate or on the drive plate which leads me to believe that it's not the main. Also, the foam strip that is on top of the rear end plate is ripped apart. I want to replace the oil pan gasket and the foam strip. Is there any way to find the part numbers for these parts? (the dealer where I live is not helpful) Thanks
Automatic, V6, 2000 Tacoma Prerunner.
Old Mar 11, 2006 | 10:20 AM
EWAYota's Avatar
if you have a shucks, checkers or whatnot, heres the oil pan gasket,
http://www.partsamerica.com/ProductL...Gasket&ptset=A
not sure about the foam strip.
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
