Fuel Pump/FP Relay locations...
Old Mar 11, 2006 | 07:08 AM
wjwerdna's Avatar
Question Fuel Pump/FP Relay locations...
I guess this kinda kills the whole idea behind it, but I am planning on putting a manual fuel pump relay cut-off, the idea behind this is to be able to simply throw a switch/relay, to prevent theft... This works well from what I've seen/heard on other cars, if broken into and successfully stolen it makes it froma couple feet to maybe a block before it stalls out, at this point the theif cant really afford to try to fix it.
If anyone can point out an easy (does that ever exist) way to get to the fuel pump, or if there is a fuel pump relay, any help would be greatly appreciated
Old Mar 11, 2006 | 07:34 AM
BruceTS's Avatar
On the driverside, there's a harness underneath the plastic floor panel running along the door opening, just put a switch in to turn off the pump. I forget exactly which wire it is, I'd have to look it up.
Old Mar 11, 2006 | 09:19 AM
Gadget's Avatar
On the 4Runners that wire is usually larger then the rest and usually blue with an orange stripe.
Gadget
Old Mar 11, 2006 | 11:32 AM
wjwerdna's Avatar
all right, thanks guys, that should lead me in the right direction....
Old Mar 11, 2006 | 11:33 AM
wjwerdna's Avatar
ill try looking for the larger, and will check and rule out the rest
okamikai
Apr 30, 2018 10:19 PM
Doug4320
Mar 24, 2018 10:11 PM
mussy01
Dec 13, 2016 08:20 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
