Overheaing (need big help here)
Old Mar 10, 2006 | 08:55 AM
Citykid's Avatar
I checked other posts and didn't find what's happening here.
Driving home, at a light a look down and see the temp max out in the red. I crank on the heat and it goes down a little. Get on the highway, clear thank god, and it drops down to middle.
I just looked, now that the truck is cool, and the bottom of the radiator is wet in the bottom corners and a pink residue ia all along the bottom grill of the radiator.
Any suggestions?
Old Mar 10, 2006 | 09:17 AM
midiwall's Avatar
The pink stuff at the bottom of the radiator is coolant - nto a good sign.
The first thing to check is if you still have coolant in the system. If not, you found the source of the overheating - get some coolant in there and hope that you didn't do any internal damage.
Past that... Given where there's residue, then I'd guess that you have a crack in the radiator, possibly a seam; or a crack in one of the hoses.
Old Mar 11, 2006 | 08:23 AM
Citykid's Avatar
Had to get a new radiator. The bottom had cracked. Apparently this is common with all toyota radiators, so I was told. I did not go through the stealership.
Old Mar 11, 2006 | 09:31 AM
midiwall's Avatar
"Common"? nah... But, glad that you got it fixed!
Big Little Bear
230
Nov 13, 2023 11:42 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
ToyotaMD
Sep 22, 2015 04:49 AM
83
18
Sep 21, 2015 06:15 PM
sonorn67
Sep 19, 2015 05:39 PM
