Wierd Noise From 4lo
Old Mar 8, 2006 | 02:50 PM
fireteacher's Avatar
hey i was driving home in the rain and i decided to stop at the fairgrounds on the way home and play in some 4wheel drive to cycle the fluids around. so i am playing around hitting puddles (slow) and making smooth turns across the gravel lot..(wishing i was wheelin, ever happen to you guys?!) i decided to put it in 4lo and see what happened since i had never used it. everything is groovy but when i make a turn it kinda catches and drags a bit (rear end). i also had the diff lock on (also testing that) and i am pretty sure it did it while it was off, could be wrong though..is this normal..tell me to stop whining and go hit some trails or something but it didnt seem right!
Old Mar 8, 2006 | 04:21 PM
bump!
Old Mar 8, 2006 | 05:39 PM
Glenn's Avatar
There was not enough slip on the gravel to allow the wheels to slip enough to relieve drivetrain binding.
Old Mar 8, 2006 | 05:42 PM
Jeffires's Avatar
Avoid using 4LO on hard ground if you can.
Old Mar 8, 2006 | 05:56 PM
ok but is this normal and i was on asphalt when i noticed the drag/slip
Old Mar 8, 2006 | 06:11 PM
amorphous's Avatar
yeah, what happened sounds VERY normal....rear locker on or off your gonna get that sorta stuff going on.
Old Mar 8, 2006 | 06:31 PM
so i should only use 4lo when i ABSOLUTELY need it?
Old Mar 8, 2006 | 06:39 PM
amorphous's Avatar
off road only, soft surfaces where you junk won't bind up. I honestly don't even use 4H on the pavement unless it's snow-covered.
aaron
Old Mar 8, 2006 | 06:41 PM
ok thanks. i was just testing out the gears as i am new to the 4x4 world. thanks for being patient!! i use 4h when i am in the snow fields playing and when im trying to climb rocks around the fair ground.
Old Mar 8, 2006 | 06:43 PM
Jeffires's Avatar
Yeah, you can use 4wd on hard surfaces, but the more you make sharp turns with it engaged, the more stress you put on your U-Joints and CVs. Doing it occassionally is not harmful.
If you have lockers, it makes it even worse, it's called driveline windup.
Old Mar 8, 2006 | 06:53 PM
amorphous's Avatar
Originally Posted by fireteacher
....i use 4h when i am in the snow fields playing and when im trying to climb rocks around the fair ground.
the steeper rocks you'll want 4L...that way you can keep it S L O W
no worries man...i was you a couple years ago!
aaron
Old Mar 8, 2006 | 07:03 PM
thanks jeff
this damn site is the SH@t!!!
Old Mar 8, 2006 | 07:04 PM
marko3xl3's Avatar
Using 4 Low isn't bad at all, use it as much as you want. Just remember it's meant for low speeds and be god darn sure you have a soft surface beneath you (softer than gravel) or else you'll break things easily. Basically, just be smart...
Old Mar 8, 2006 | 07:07 PM
i feel so loved!!
Old Mar 8, 2006 | 07:28 PM
amorphous's Avatar
easy there....the love will turn green and all your cash will be DRAINED! HA HA HA!!!
a
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
