- Oil drain plug is in relation to transmission drain plug? 1992 Toyota pickup Manual
- Power Steering Leak 1995 (with photo)
- 1998 3.4 engine sheared cam gear bolt
- Need brake line advise.
- 01 4runner rear window not working/defrost working
- A340 Transmission propblems only when WARM
- Gear Shift Help
- Overheating Intermittently- Tried Everything
- 99 Tacoma, 5vz-fe 146k miles Knock. Video
- '02 Wheel Size Question
- 3rd Gen Radiator options WITHOUT trans cooler
- Major Oil Leak 98 Tacoma SRS 3.4l V6
- Catalytic Converter size help
- Adjustable 5100 bilsteins
- Powerstop Pads
- Front diff compatibility
- Looking for a cruise control wiring diagram for a 3RZ 4runner
- 99 4 Runner Limited HELP
- Weird rear diff noise. Axle, pinion, carrier, or?
- Rear wheel bearing? Same parts all years?
- camber bolts
- 97 Taco need some help
- 97 tacoma cranks but doesn't start
- First buy for a New toyota guy.
- 5VZ Supercharger install help needed
- Cranks but doesn't start
- Ack! my new to me 3rd gen has a wet and rusty rear axle, should I start shopping?
- Speedy's Water Meth Injection Install (with video)
- Anyone here put a wrap on their 3rd gen runner?
- LCA removal tricks?
- Now what ?
- My $60 budget head unit upgrade
- Question regarding buying a used 99 4runner
- Looking to purchase high mileage 4x4 4runner
- '04 2.4L cracking intake tube/box. Common?
- 2.7 idle issue. Please help!
- Misfire Mystery Making Me Mad
- Going for 2" Lift using Toytec/Bilstein Coilovers
- Anyone using "new" CV shafts from Autozone?
- knock sensor blues
- Gen 3 steering wobble... fix prior to lift?
- 98 Tacoma 2WD 2.4L Can you replace valve lifters without removing head?
- First gen taco bed bolt size
- Not going in reverse
- Sick of DRL
- Anyone in Sacramento area?
- Help with bypass hose part number
- Need Help On 2K 4Runner W/96 3.4 Swap
- Running / ECU programming difference between Manual and Auto 5vz 3.4L?
- '01 4runner Transmission Sound? - Vid Inside
- Got into an accident with my 2000 4Runner
- 99 4Runner won't start. Dash lights up-no sound.
- Throttle Body Part Number
- Idler arm & Pitman -IFS 4 Runner
- 3.4 V6 Rear Cam Plugs
- Guage cluster lights will not work
- What is this hose/breather/vacuum leak thing?
- 4x4 Issue
- Putting in new seat covers
- 1UZ swap in a 3rd gen 4Runner
- Mysterious Plugged hose
- Auto trans dipstick - can someone sanity check me?
- E Locker & Heated Seats Questions
- 1998 Toyota Tacoma: Transmission or Drivetrain Issue or Neither
- Front Differential Axle Seal Replacment
- Blown head gasket symptoms ?
- A/C Idler/Tension Pulley Nut Stuck/Stripped
- transfer cases
- '96 Taco Battery Light
- new front struts- steering wheel off center
- Let me see your dipstick!
- Location of oil return holes in head
- ToyTec Boss Complete Suspension Lift
- HELP!!! 2000 4runner Stalls Intermittently
- Another radiator thread
- Lift troubles
- 2010 Taco rims on my 3rd Gen 4Runner?
- 3rd gen 4runner auto trans replacement
- ~99 4runner Cat/o2 sensor exhaust distances?
- How much for '99 2wd sr5
- '97 Runner w/ 250k, what am I getting into?
- Crazy idle problem on 5VZ-FE - surging from 1500-2500rpm every second.
- F! Seat nut fell through!
- Suspension Lift Characteristics Under Tube Bumper Load
- 4WD not engaging
- 4WD not engaging
- Old video of my truck....
- Rear Spoiler
- 3.4 5vzfe Misfiring help
- 3rd Gen DIY Videos
- 3RZ ticking & stumble at idle
- 02 Runner Hitch Receiver to 94 Hilux?
- Installing W/M Injection
- Difference in 99 and 04 2.7 motors!!
- '99 3.4l - dying and stalling (details in post)
- Pin out of cig lighter?
- Need help with Addicted Off road bumper
- Rear chrome bumper from 2000 SR5 fit on 97 limited?
- Gen3 runner driver shaft lubricant type?
- 1996 Tacoma heater blows cold passenger side
- Gear help
- Help..over self adjusting rear brakes!!!!
- Brake jammed in 4WD--please help
- 2000 4Runner Dies Randomly
- Fan always on
- Lift rear only 3"?
- Lift Help
- automatic shift lever button wont push lock down far enough
- missing parts?
- Taco shifting thump (manual)
- Looking for help replacing all rear diff seals & brake shoes AND diagnosing issue
- 97 Tacoma 2.7L chirp
- 99 4runner New Front Shocks - Difficulty Installing
- What switch, controller, or device fits here?
- 2000 4runner under dash wiring
- Took Throttle Body off and now symptoms of a bad head gasket
- shifter exchange 4cyl 6cyl
- Merry Christmas
- '02 Tacoma and 4Runner door windows??
- 2002 4Runner Drivetrain Upgrade with Factory E-Locker
- 01 4runner heater core change now the radio and clock won't turn off
- Transmission jerk/hard shift
- new member
- OME 880/906 with Std. Bilstein 5100's
- Source for wiring harness parts (connectors)?
- Automatic transmission solinoid identification??
- 3.4 Oil pump screaming
- AC Evaporator Freezing Up
- 99 3.4 Idle Issues
- 2000 4runner 4wd Limited No Power to VSV
- What is this vacuum hose for? Need help ASAP
- quality seat covers
- Neutral safety switch install
- 99 Runner 4wd need advice on upper control arm bushings
- soggy ass
- Transmission oil issue
- 98 4Runner Rear End Noise
- Tacomas with 8.4" rear diffs ...cool elocker option
- Help! I can't change my #6 spark plug (can't get to it)
- Intermittent starting and stalling issues
- Need help with Trailer wiring.
- 4bt in a 3rd gen runner?
- Brand new car window sticker from 1999, SR5 cost $47,326
- Smog Test Numbers
- O2 sensor wire routing?
- Very loose steering
- 1998 4Runner SR5 3rd Gen - List of Fluids
- 1998 4runner 3rd Gen - Complete Fluids
- 3.4 Knock only at Idle
- Yotalockers.com - Elockers for Tyota Tacomas & 4RUnners
- I'm doing a run of Panhard Lift Brackets for 3rd Gen 4runners.
- Tach signal at ecu?
- 2004 Taco to 2000 4 Runner Brush Guard Swap
- Harrop ELockers for 4th gen pickups and 3rd gen 4Runners
- What happens when I put negative line to positive terminal(+) battery terminal?
- 96 4runner no start.. scan tool link error..has spark and fuel
- Are there any winch bumpers for a 96 tacoma??
- 95 6Cyl Exhaust Leak
- Lifted 97, but now plagued with problems
- axle talk
- Inconsistent Steering Vibration While Braking
- Vibration in cab and rear axle noise.
- Hellfire of Electrical Problems
- Fixing o2 plug 2000 4runner 2.7
- 01 4Runner PO325 Nightmare
- 2.7 rebuild, idling fast and little rough?
- HELP! 99 4runner(3.4): rear parking and instrument panel light doesn't work
- 2001 3.4 Throttle Hesitation Maybe Elec?
- Fixing my 4WD
- Scissor gear not aligned
- Installed new head gasket, now motor sounds horrible. Valve lashing?
- RustBucket Grew Up and Got a 3rd Gen
- Need some help with meth/h2o kit choices.
- 1999 Tacoma Headlight Swap
- 5VZ-FE unsettling engine squeal
- 2000 4Runner rear shocks replacement
- 96 4Runner White Smoke/Check Engine
- New to me '99 Taco
- 3RZ low compression in 2 cylinders. Need advice
- My 2002 4Runner SR5
- first gen rotor replacement 4x4 locking hubs
- Trade Tacoma 4.10 E-lock diff for 4.30
- Show Your 95-04 Regular Cabs!
- 99 SR5 with 190k
- Check engine light
- Transmission junk?????
- Hi Everyone! 1995 Tacoma Restoration
- Storing and Preserving a Spare Engine
- head on collision
- 2003 Tacoma engine swap with 2JZGTE motor
- 98 Tacoma 2RZ-FE 2.4l Timing Set R&R
- 3.4 Idle issue - P0171 lean condition...
- Front sunroof drain dumps in rocker?
- Toyota 5vz-fe 3.4 Liter V6 Weight
- 3rz engine install
- Pulling a 3.4L (Special Conditions) 2000 4Runner
- hot manual transmission
- 3 day sale on Gibson Exhaust! Get it while you can.
- 4runner Front Clip on a Tacoma
- Field Testing a 3.4L in Salvage Truck
- Needing Some Seat Parts 2002 4Runner SR5
- What to look for?
- Amsoil Motor Oil
- Problem with starter after using it to break crank bolt loose
- new 3rd gen owner
- Yoda Jim's
- Surface Rust?
- Tire Recommendation
- 2000 Tacoma front end swap
- a/c blows out defrost
- 2002 4Runner Problems
- Rough idle after EGR delete and O2 fake
- Rear Control Arms - Upper & Lower
- 99 tacoma p0300 misfire ??
- 4runner 2.7 clutch
- '96 rear leaf u-bolts
- Any Car Alarm Guru's out there?
- Charcoal Canister Replacement Causes Issues
- Wire Harness
- Well .... The Milkshake actually happened to me!
- 96 Toyota vibration
- 2001 Tacoma brake light adjustment
- 4X4 Pick Ups, 3rd Generation vs. 4th?
- Front Brake Pad & Rotor Upgrade
- rear brake drum adjustment
- Part Number Confusion for Lower Ball Joints
- 3.4L valve adjust or not (rolled engine)
- Strut problems with SS 1.2
- 96 4runner I4 no combustion
- Throttle Body/Cable issues
- 3gen 4runner 5 speed 4wd 2.7 diff swap
- Complete 3rd Gen A/C replacement
- Transmission pan seal?
- Documenting my 2002 4runner issues...
- Fair sale price for my Tacoma?
- 98 4runner no power help ?!
- Help find a home for this wayward vacuum hose
- Replacement fuel tank for 03 Tacoma
- brakeline help
- Frame crush zones
- 2000 4Runner LTD- Broken frame
- 99 Silver Tinted California pics?
- 99 4X2 Door ajar light
- 02 sensor
- 3rd Gen Pass Drop SAS Owners: Question on Exhaust/Link Set Up
- 130 amp alternator
- 02 Runner 240K - what now?
- Newbie
- coolant leaking from radiator trans lines, 98 4runner
- 97 4runner wobble
