knock sensor blues
Old Feb 28, 2017 | 02:29 PM
knocknightmare's Avatar
knock sensor blues
knock sensor code , passenger knock sensor. replaced both sensors. light came back on , replaced sub harness. light came back on. what next
Old Feb 28, 2017 | 03:25 PM
habanero's Avatar
What brand sensor did you use? What year/make/model/engine are you working on?
Old Mar 1, 2017 | 04:29 PM
3.4 , and not sure what brand. but identical codes every time , my mechanic is going to try splicing the wire from the sensor throwing the code to the other one , at the ecu to see if it is the main harness
Old Mar 1, 2017 | 04:32 PM
99 sr5
Old Mar 1, 2017 | 09:27 PM
mdh's Avatar
mdh
I just went through the knock sensor ordeal. Typical code 0330 means your sub harness is bad but it could still be a bad sensor. Check with your mechanic and ask if they replaced your sensors with the correct model. It seems that the 4runner was equipped with either denso or matsu˟˟˟˟a sensors and the engine will still throw a code if the wrong one is used.
I tried parts store sensors and I had to pull everything apart again after I finally tracked down the correct sensors for my engine.
Old Mar 2, 2017 | 02:52 PM
any other ideas?
casey225
Mar 4, 2006 09:48 AM
