- How do I get seat measurements?
- 22re> what rpms?
- how much for your truck??
- smoking new brake pads
- lightbar??
- Auto Meter Electric Oil pressure/Water temp gauge sender install 1988 3.0 1st gen
- Hella horns install
- Waxing fresh paint
- HAs anyone used this on their paint?
- Anyone try this paint?
- Some useless info
- Did My First Mod Today!
- Sport Bumper Trim
- Bumper Exchange?
- Portland Area Engine Rebuilders
- Will Walbro pump help my ping at all?
- New Gears!
- TRD E Locker in stock 8" diff
- OME Rear Shock Question
- Type III Info Help..
- question on rear end disc conv.
- 2nd Gen Rear Discs? Anyone converted?
- 88 IFS ball joint spacer hight HELP! please respond!~
- rear garnish ?
- 1999 Sr5 Fender Flares
- NGK Question
- check engine light and speedo quit
- thumping front end
- has anyone changed the oil in their supercharger??
- Plastic glues, cements, etc.
- Help with cracking clear coat...
- My New Wheels Hit The Calipers!? Wahh
- where to buy 3rd gen rotors?
- new v6 4th gen sulfur smell TSB
- K&N Generation II Performance Kit for a 4cyl.
- Question on undercoating from the factory on Toyota trucks
- Helix Power Tower
- seats
- What does a bad wheel bearing sound like?
- New body panels?
- The Unthinkable Idea
- Do I need the fan pulley(bearing plate)?
- Suspension for Towing/Daily Driving
- Awww my nightmares coming true
- toasted a motor yesterday
- 3.0 burnout?
- What major differances from 4.88's
- replacing a clutch..
- New guy: Nice water pump repair story
- What should my first Mod Be?
- Soldering wholes on radiator
- Hello Yall @ Yotatech
- Front break pins stuck
- Poor Braking...
- Link to Pics: 04 Sport w/Revtek & 18's
- After market oil cooler? HELP!
- Trail Master Helper Springs...???
- 95 4 runner elect sys 'ghost'
- Lifts for 4th gens
- weber 32/36 help
- rear drum brake adjustments
- Best Price On Toyota Parts On The Internet!!!
- Hello Yotatech
- bad coolant leak
- Ever Heard of a Cabin Air Filter?
- Brush Guards
- Code 22
- Even more info on 94 4Runner with loud knock
- starter rebuild = saved $$$
- custom graphics for wet okole
- 3rd Gen. Roof Rack Removal.....trim strips?
- Pictures of my 04 SE!
- theoretical elctrical question
- keyless beep
- Cooling products?
- Airbox Mod
- Anyone know some tricks to soup up the 22r motor?
- good deal on Warn M8000 right now
- DIY CV-Boot Replacement Writeup
- 97 4runner w/03 wheels
- Oil in my airbox!!!!
- 7th injector kit or urd kit???
- 92 p/u fender for 91 4 fender?
- 87 4Run Temp Gauge Wooes
- In-cab air filter??
- Cruise Control Help
- boost gauge question???
- Can an aftermarket coil be used on an 83 22r motor?
- What is your GPH?
- Happy Birthday (to my Truck)
- retrofit AC
- Tech 1 Rock Crawlers
- more starter problems?
- Has anyone tried to mix oil?
- Quick Question
- Rearview Mirror with Compass and Temp?
- Group buy on racing type seats
- Took the Runner on her first offroad trip...
- 02 Type aluminum skid question
- Turbo for an 86 Pickup?
- body mount bracket mod to get tires to fit
- I Am Back!
- 95 Automatic Transmission is Overheating
- $220 for seats - what do you guys think?
- 1991 v6 a340 Overdrive Question
- Lets play another game of name that part!
- The 3.0L Tick?????
- Aftermarket steering wheel
- How much will new coil help?
- flashing seatbelt indicator
- ok, am i overreacting?
- Air filter question...
- Would this fit my 1997 4wd 4Runner?
- Flatbed Laws
- cv boot write-up?
- Help - Need S/C belt P/N ASAP
- 83 truck, idles rough, stalls
- Speedometer Cable Removal
- 1st Gen Bikini Top Fab
- 88 4Runner Exhaust.......COMPLETED
- Strut question's.
- Check engine light came on.. argh
- Factory rack snowboard attachment??
- Toyota Pickup History page
- What is this wire?
- Wheel Bearing Question - 3rd Gen
- Best Deal on 3rd Gen Lift Components
- gauges
- higher wattage 80/100 plasma bulbs any issues running them?
- Good Material To Cove Intake Pipe With
- Ordering rebuilt 3.0L to start the great project
- New lift pics added...
- Ixnay on the Throttle Body Spacer
- code 52 ??? knock sensor signal
- seats????
- which lights to get?
- HELP! My baby's sick!
- 4 inch lift
- Underdog 4Runner Underware Sale!!
- urgent: please help!
- 1983 4x4 Pickup clutch replacement ???
- URD Fuel Upgrade Installation
- My life sucks!!!!!!
- OME and Cornfed Spacer question
- Lift Installation Cost...
- ARB Air Lockers
- 1994 front wheel hub 4x4
- Swapping the 3.0 Toy w/305 TPI Chevy
- Body paint: 3rd vs 4th gen
- 3.0 Throttle Body Spacers
- Looking for Replacement Heim Joint for SAWs
- JBA headers on a 3.4 Taco....
- Offorad Xtreme 4Runner 3rd gen susp kit B: install and results
- 15K service
- Rear Wiper Removal...
- Adjustible Control Arms for 2nd Gen Runner (Rear) NEEDED
- AutoShop 101
- Good Buy? - 85 w/Carb Problem
- Folks with '95s...
- Extreme off-road...shipping time?
- Blacked out lights, legal?
- Midnight Brainstorming about ADD 4WD What do you think?
- Reverse lamps not working, help?
- Had a 3.0 die on you? Tell us about it.
- Oil leak @ the base of the dist. shaft
- Cruiser coils = how much lift???
- Flowmaster Delta 40
- useful site
- Rear Shock Bushings
- Alteritive Freon
- 2.4L 2wd Taco -- suggestions needed!
- So I drove a 2001 Limited with the 3.4 and I have to ask...
- 91 v6 4r wheres the dipstick?
- Owners Manual and Repair Manual?
- will 03 z71 wheels fit 91 4runner?
- GM 2.8 In 88 Toyota 4x4???
- Torsion bar problems...
- Rs3200
- Help...3vze runners,where does this wire go
- Strange Clicking from Rear???
- gott'er runnin
- Where can I order parts online?
- 1.5 HD Coils
- Fuel Injector
- starting after head gasket change
- Timing Belt / Water pump $$ how much?
- 2001-2002 Rear Chrome License Surround. Where to get?
- Paint question
- IFS front end rebuild parts, anyone know>
- interior trim question
- Weird Electrical Problem...Help!(Searched)
- ATTN: Valve gurus
- Rust Repair
- Keyless Entry Parking Light Flash Issue
- exhaust problems???? need help!
- synthetic 10w40? or is Mobile 1 10w30 OK?????
- Installing a Locker on a 3 gen. 2wd
- 5w-30 vs 10w-30 question
- ATTN: UK Myers ISR mod Question
- What Size Tire Could I fit??
- cruzin performance opinions
- Got Low Profile Upper Bumpstops!
- Crank Shaft on 94 4runner v-6
- Help my A/C is pissing me off!
- HID in 03-04 headlight!!!!!!!
- How much oil do I need for my >>>
- Lift Laws in your state
- Braking Issue
- HELP my truck won't start!
- Update
- straight axle???
- 2nd Gen Power Steering Issues
- bushings
- Axle swap???
- Just Finished my CV Boot Change
- 1997 CD Stereo Intall
- Toying with this no-chrome look. Comments welcome.
- My 4Runner Pix
- photoshoot....
- Gonna do an injector rebuild soon...what do I need?
- Where in San Diego?
- Shocks question
- couple of questions
- 1988 clinometer installation? help!
- 1988 IFS Downey 2" rear and ball joint spacers installed TODAY! QUESTIONS!
- clackity-clackity-clackity
- SFWDA Convention 06-10/06-13
- Tanny/t-case combos
- Wheel bearings
- 20/22r timing chain/cover precaution
- Wheelers rear brake line 3rd gen
- Has anyone ever tried one of these coil boosters
- engine won't start - help!
- Frame differences 2wd and 4wd
- When should a timing belt be replaced?
- TRD brake rotors for 3rd gen Pickup? Need them ASAP!
- Need some horn help.
- Portable Air Compressors
- A/C Question
- So I ordered my Supercharger...
- Rear Diff Fluid Came Out Lookin Like Mud
- Pinch weld trimming?
- Leaking coolant
- Gearing with 33's?
- Lowering Springs/ coilovers???
- 2000 4Runner Sport/Highlander stock height
- Cornfed Spacer Question
- New 4Runner Owner
- Weird Vibration
- help with rear flex...
