exhaust problems???? need help!
Old Jun 10, 2004 | 05:24 AM
dcarnes's Avatar
Question exhaust problems???? need help!
I started noticing an increasing lack of power in my 95 4runner limited. Associated with this is a noise coming from under the hood near the exhaust manifold. I cannot find any hole, but the sound and lack of power persist. Does anyone have any ideas?
I have read the forums before for other problems and always found the answers so I am hoping that someone can point me in the right direction.
Old Jun 10, 2004 | 07:25 AM
Fahrenheit 451's Avatar
Is this a 22re? They do have a history of developing a crack in the exhaust pipe just below the exhaust manifold.
Depending on the location of the 02 sensor(s), the ECU will read a lean condition and start dumping more fuel into the engine and it will run rich. This in turn starts to gob up the 02 sensor making it hard for it to read the exhaust which in my experience tends to result in it cranking up the fuel mixture yet again.
I have a '93, but I only recently got it and haven't been using it very much so my knowledge of location of the o2 sensor(s) in the '95s is pretty much nada.
If it is the 22re, pulling the manifold is generally pretty easy and it will give you a chance to check to see if there is a leak at the manifold or where it hooks onto the exhaust pipe.
V6? I don't have a clue
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
kyletbert
Jul 17, 2015 11:39 AM
the1998sr5
Jul 16, 2015 06:20 AM
hexrain
Jul 12, 2015 01:13 PM
