interior trim question
Old Jun 10, 2004 | 09:16 AM
calrockx's Avatar
before i go start breaking clips and fumbling around, what's the easiest way to remove this piece?
Old Jun 10, 2004 | 09:21 AM
waskillywabbit's Avatar
Talking Piece
Unsrewd 4 wheel drive knob.
Pop out the black plastic piece behind it that runs up to the middle console. I think you have to open the middle console lid to get it to pop off.
Then just pop it out as it has 4 clips I think. Nothing hard at all.
Good luck!
Old Jun 10, 2004 | 09:26 AM
Bob_98SR5's Avatar
chuck,
like brian said, but adding:
see my write up here: http://www.4runners.org/articles/cupholder/
look at the first pic under step one. See where it says "S"? there are two screws on either side. remove them. then, between the two S's, lift up on that part and it should pop right out.
bob
Old Jun 10, 2004 | 09:37 AM
Talking Screws
Originally Posted by Bob_98SR5
chuck,
bob
Not to doubt you Bob, but I've pulled out that piece at least a dozen times and never unscrewed anything... but I don't guess it could hurt!
Old Jun 10, 2004 | 09:44 AM
Bob_98SR5's Avatar
hey brian,
yeah, i've pulled it out a few times w/o unscrewing the screws, but it is much easier putting that piece back in because the rear (closest to armrest) snaps are so close to the cupholder part. it *can* be done, but i find it much easier to snap it in w/o having to force it in.
same objective, same result, but different method
bob
Old Jun 10, 2004 | 10:29 AM
Talking Holding your mouth right
hey brian,
bob
Bob!
[tongue and cheek mode on]
You have to grit your teeth just right and open your lips in the shape of a small egg and humm like a copy machine and it pops loose and goes back in nice and easy!
[tongue and cheek mode off]
I learn something new every day!
Old Jun 10, 2004 | 01:13 PM
bradym239's Avatar
Not to disagree with anything you other guys are saying, but I've got a 2002 SE and you don't have to unscrew anything. Just push the back end of the piece towards the front of the truck and lift up. It should pop out. Then the 4wd lever's boot unclips from the piece. Hope this helps.
Regards,
Brady
Old Jun 10, 2004 | 02:11 PM
Talking Boot
Regards,
Brady
No need to undo the boot clips, and possibly break them, just unscrew the shifter knob and the boot slides over the shifter and off.
I hope you are thoroughly confused now!
Old Jun 10, 2004 | 02:17 PM
Bob_98SR5's Avatar
guys,
all i am saying is that by removing the screws on the side, it is much easier to take the piece on and off. thats it and thats all (in the voice of bubb rubb)!
bob
Old Jun 10, 2004 | 06:18 PM
Talking No No No
guys,
bob
No, don't do it that way! Bob has lost his everlovin mind! You'll ruin your 4Runner forever if you listen to him!
Old Jun 10, 2004 | 06:22 PM
calrockx's Avatar
well i tried it bob's way, and my runner won't start. thanks a lot bob.
haha i actually did loosen the screws. but yeah i was able to get it off just fine. i knew it wouldn't be hard, just wanted to know the proper way. got a trick up my sleeve, so thanks for the advice guys.
Old Jun 10, 2004 | 06:34 PM
Bob_98SR5's Avatar
...wanna sell your rig to me cheap, charles?
bob
coleypull15
Nov 3, 2015 07:41 AM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
skebe22RTE
Jul 31, 2015 02:03 PM
defrag4
Jul 31, 2015 10:50 AM
GeoRoss
Jul 24, 2015 03:03 PM
