Rear Shock Bushings
Old Jun 10, 2004 | 07:28 PM
cubuff4runner's Avatar
Rear Shock Bushings
On Memorial Weekend we were 4wheeling and I began to hear a horrible noise from the back. I looked underneath and noticed that the bottom shock bolt fell out and the shock was stripping the inside of my rim. I took the shock off for the weekend and I figured the rubber bushings would be easy to find. I went to every autoparts store within 30 miles and nothing. I finally went to the hardware store and bought some rubber stoppers drilled holes in the and that is what I am using. I am concerned how long they will last, does anybody know where I can get some new ones. Everybody has told me that they are only sold with the shock, this can't be true, can it? They are Bistiens.
Old Jun 10, 2004 | 07:36 PM
Yoter's Avatar
Guest
Anyone out there have any used shocks? Hopefully so, then they can send you a bushing. I would imagine the hardware store rubber part you got is a good temp fix but I would not continue to travel on them. I could see the rubber shredding and you ending up replacing a shock mount.
Old Jun 10, 2004 | 07:41 PM
Those were my thoughts. I was thinking about going to some local suspension shops or Toyota to see if I can find some used ones.
BeaterToyota's Avatar
Every auto parts store I've ever been to has some type of generic rubber bushings. I've even bought them once or twice and made them work. You should be able to find something.
Here is a webpage of nothing but urethane shock bushings. Search google for Energy Suspension, Daystar, or "shock bushings" and you should find some.
Old Jun 10, 2004 | 07:51 PM
That's what I'm looking for. All of the autoparts stores had one set that was the same and it was way to small.
glowz825
Jan 25, 2022 09:28 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
andrewtexas123
Jul 23, 2015 11:22 AM
Massmayhem247
Jul 18, 2015 05:46 AM
