- Engine Problem
- Replacement clutch
- Parking Lot Attendant = Clutch Death?
- serpentine belt
- Tjm bumper and body lift gap
- I hear a new “hum” coming from my rig – what could it be?
- Center Dash Panel Needed for '97 Runner???
- Tail Gate rattles
- Stupid 14 year old plastic!!!
- Selling my rig!
- Gas mileage in metro D.C.
- ? on draining rear diff fluid
- 4inch superlift IFS lift questions
- What muffler?
- New Pics...
- Trailer brake controller
- noisy lifters and knock sensor?
- OEM Shock Question
- What's binding after ball joint lift install?
- Pre runner bar on a 3rd gen?
- See our 3 new sections!!! Audio, GPS, and Computers
- trouble getting correct distributor cap
- Valve Body Mods
- Salvation in a bottle
- 86 4runner
- Clutch problems on a 1st gen
- Removing sliding glass windows in 4runner
- does this look dumb
- Another big 4runner
- 89 pickup starts up and shuts off
- Exhaust leak....weld or get new gaskets?
- what rear diff to get
- Running Lights
- How much is this 1979 truck worth?
- Exhaust Tips
- 3.0 to 3.4? can i do it
- Grease Fittings/Fuel Filter Questions
- 4wd noises
- discount tire center trans flush
- Got custom sliders for $150!!! (pics)
- Knock sensor wire, 3VZ-E
- 22 RET or RE horrible miss problem please respond!
- Gearing????
- Can waterpump failure screw with the 3,0s timing?
- 2nd Gen taillights
- Anyone using Optima Yellow Top w/ reverse post?
- 60k mile tune up
- Time to waste some money on the taco, part suggestions
- Pads, Rotors, Alignment??? Which is it??
- How do I choose which Amsoil product to use
- How Much Should It Cost?
- Summer driving = only water in the cooling system?
- Need core 22RE (or R) for parts
- Anyone have the ROCKCRAWLER 152 STREETLOCK wheels? PICS PLLLLLEASE!
- Can anyone recommend an exhaust sys for my 3rd gen?
- Leaking Transfer on 3rd Gen?
- Urgent help needed!!!
- Contact info for King coilovers?
- Any one know of a reputable yota repair shop in my area?
- Clear Bumper Lights from Toyota
- Cali or Fed Spec?
- does the rear hatch off of a 2001 4runner fit on a 96 4runner?
- Survey -- the best autoparts store?
- I think my Downey's are starting to sag (pic)
- What Makes a 3.0 Tick
- Check this beast out
- Oxygen Sensor
- Different Brake Caliper Design
- Grill update on 91 2nd gen?
- Good price for ARB bullbar?
- What does "Running Lean" mean for OBD II code?
- Lubrication point question please...
- 3VZE owners-Where does this wire go? (pic)
- Radiator question...
- Lift is done!
- Finally allowed to post - need some help
- Update on overheating 94 4Runner...
- One more muffler soundbyte/video for Corey.
- ADD going into 4WD on its own
- side mirror replacement
- More info on 94 4Runner 3.0 with knock
- I was thinking of doing this....
- Mr. Yoda w/4" Pro-comp finished!
- Limited slip in my Tacoma?
- How can I increase power/performance on 94 4Runner?
- tundra or tacoma?
- am i crazy?
- Someone please help with overheating...
- Help with temperature increase...
- Cramped in a Gen II?
- Ok, I'm getting closer . . .
- Leaking oil, Rear main seal? $850!!!
- Got a problem. Please help!!!!!
- Hi lift owner's, quick question
- Headlight wiring harness upgrade, need help!
- Replacement Rear Coils
- anyone with a 4th Gen in Cali that got new tires?
- using 4wd for the first time(dont laugh)
- engine problems! please help
- Using Electric Polisher for 1st Time - HELP!!
- scanner
- Locked glove compartment
- 1988 skid plate help! Where can I buy one??????
- 2nd Gen Cruise Control Q
- 94 4Runner 3.0 with loud engine knock
- HELP... Hubs won't come off
- will the trd supercahrger fit on my 04 tacoma?
- What shocks to purchase
- Replacing 5-speed w/ auto in 89 4Runner
- No Spark
- Any driveshaft experts here?
- Header and exhaust Q's
- Overheated 22re!!!!!!
- Satoshi Grill mod parts in hand....
- Landcruiser question
- alcohol as fuel?
- Yet Another Scam
- Exhaust Dump Location
- ok, 4th gen v8 2004 4runner questions here...
- Line x My Bumpers??
- 33's on a Gen II?
- Biggest 4runner pics
- Squeaking...
- help me pass CA smog test please
- Power rear window problem...
- Fitting on Intake 3.4L
- VAF Info for 3VZE
- Performance Products Oil Filter Relocation Kit for sale.
- Amsoil Air Filter for sale.
- What are the signs of cam shaft or waterpump failure?
- Steering Wheel Wear
- 2005 4Runner & Sam's club
- getting a starter problem
- 4th Gen rims
- Rack in my brain
- Wiring relay for electric fan
- ARB Snorkel Installed in 90min!
- Noisy drive belts anyone?
- Do all new rotors come with some kind of coating?
- couple quick questions
- yakima loadwarrior...
- How much did you spend?.....
- Got my ARB Snorkel today!!
- Leaking Diff?
- coolant leak
- Muffler Suggestion
- Is anyone interested in shackle hangers for 2nd gens?
- question
- need help bad!!
- Battery drainage problem while sitting
- 1996 4runner Sr5 Suggestions
- Help: exhaust leak
- guess who got some new shoes
- Picked these bad boys up today
- Voltage question
- 1st Gen Wobbly Dealer Option Mirrors...
- OME 891 or 906 springs?
- Getting ready to conver my toy including front swap
- Power antennae problems...
- Has anyone ran 235/85 x 16" ?
- 03 4runner w/sequoia wheels
- Help! Rust on Seat-belt bottom point (steel ring????)
- Flowmaster Series 50 SUV price?
- Can't decide what to do??
- Trip
- rear spring replacement on 1st gen quetions!
- Engine Knocking...
- coolant leaking into cabin... 3rd gen
- VSC vs Rear Locker?
- Double check me on this
- Fog lights don't work anymore...
- Who has Hella FF1000
- Bulletproof Windshield
- Engine Ticking....
- Hesitation due to injectors?
- Cleaning truck after offroading?
- Tire experts
- 4th Gen. fixes yet?
- 3500 or 5000?
- How to adjust brake bias on 1st gen
- big ball joints
- Your next 3 mods: Share them here
- Rotten egg fix
- Is $30 too much for R. Diff Fluid change?
- A/C Question
- Power Loss problem
- some days You win
- What do you think of this modded 2nd gen 4Runner?
- Drop in 22R - Changes?
- Secret CB Antenna?
- Va mambers
- Is it ok to....
- Transfer case won't disengage? What the?
- Voltmeter issues
- 4th gen amsoil air filter - weird fit
- went "offroading" this weekend
- Tranny problems
- How often do you use BG44K or other fuel system cleaner?
- Broke my truck, need help
- V6 or 22RE? Gen I or Gen II?
- 2nd Gen Exhaust and rear window problem
- Carb???--Brakes???
- pics of larger tires
- ok guys, help me finish my suspension
- Got Franks? (Frankestrut mini write-up with pics)
- Week Long 4x4 Trek Done... Next plz.
- Need a new Mass Airflow Sensor
- variance in cylinder PSI
- Southern California Toyota Dealers
- 2 Problems that I need assistance with!!!
- OBDII, CA and Replacement Cats
- Where to get TRD flares for 2000 Taco
- Lower Control Arm Squeak?
- Rear ARB Question
- Need New TPS
- 77k and little or no wear on the brake pads?
- Help! -- Check Engine Light On
- Would a 3 5/16 backspaced wheel stickout to the point of looking goofy?How bout 3.75?
- After Bils my ride still seems not right
- Check out rust in the hatch?
- Glasspack
- Turbo Kit.
- www.sdori.com
- Gerald's
- a/c fuse?
- rav4
- 3rd Gen Front Bumper
- Which filter?
- 2nd Gen A/C Re-Charge question
- Hella Rallye 4000
- oil filters no longer made in japan - now thailand
- Hood scoop or not?
- 2nd Gen Articulation
- Ordering parts
- How many miles do you get per tank?
- Suspension problem
- keyless entry questions
- 87 4Runner - wheel specs?
- Cool site, engines swaps, custom suspension stuff and more
- Engine Problems, need help!
- potentially good ep of pimp my ride
- STOLEN TOYOTA PRERUNNER!!! Bakersfield
- ISR mod
- Rough starting
- need help! - manual tranny problem
- screeching/squeeling while driving
- Which Porter Cable Model
- Whistling when engine is cold
- Tacoma and 4Runner... Quick Q...
- TX4Roc.com Launched!
