Wiring relay for electric fan
Old Jun 4, 2004 | 06:50 AM
4what's Avatar
I installed the imperial 16" fan just as shown in Churnds instructions, the only problem is I cant seem to get the relay wired correctly.
The labels on the relay I have are:
-30
-87
-87a
-85
-86
Now what I need to find out is where the switched power, constant 12V power, ground and the two connections to the thermostat go. That should be all I need correct?
Any help is greatly apreciated!
Old Jun 4, 2004 | 07:11 AM
eric-the-red's Avatar
This should answer your questions
http://www.the12volt.com/relays/relays.asp
Old Jun 4, 2004 | 08:54 AM
4what's Avatar
Beautiful, thats what I've been looking for!
Old Jun 4, 2004 | 11:35 AM
4what's Avatar
Ok so I tried this again at lunch today & its still not working properly. Maybe I fried the relay in my random wire tests yesterday... :pat:
Old Jun 4, 2004 | 12:09 PM
If you put voltage at terminal 85 or 86 and ground the other of those 2 you should hear the relay clicking, if not it may be fried.
Old Jun 4, 2004 | 01:59 PM
Marc's Avatar
This is how I wired my Bosch 87 Relay and fan
30 = battery positive
86 = switched positive
85 = ground through thermostat (when grounded activates relay)
87 = Fan positive
hope that helps
coryc85
Sep 9, 2015 06:24 AM
v_man
Jul 23, 2015 04:01 PM
jackiebrownia
Jul 20, 2015 09:02 AM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
