Is $30 too much for R. Diff Fluid change?
Old Jun 3, 2004 | 06:40 AM
DrummerDaveB's Avatar
Is $30 too much for Rear Diff Fluid change?
Im going on a 6 hour trip, towing a trailer tomorrow.
My Runner has about 83,000 miles, and I dont know if it's ever been changed.
A local shop said they'd charge $30 to change it.
Is that too much?
Old Jun 3, 2004 | 06:44 AM
bamachem's Avatar
That's not too bad, but you could do it yourself for the cost of the gear lube and about 15 minutes. Gear lube would probally run you anywhere from $5-$15 depending on brand and dino/synthetic.
Old Jun 3, 2004 | 06:58 AM
ROMAD's Avatar
Not bad I guess....I just changed my 2nd Gen rear diff fluids out with synthetic and my cost was 27 bucks for 3qts plus my time.
I'd say do it yourself - its too easy. I dunno about your gen but I needed a 24mm socket to get the drain/fill plugs open. Took 5 mins to drain and 5-10 mins to fill, just be sure you are on level ground when you do it.
Old Jun 3, 2004 | 07:12 AM
Highland Runner's Avatar
A 13/16" socket also works.
Citykid's Avatar
I did it myself after Jiffy Screw said $90. Yeah, that would be $90 for the front diff, $90 for the rear diff, and another $90 for the transfer case. $30 is a deal if you don't feel like doing it yourself.
Old Jun 3, 2004 | 08:39 AM
toy283's Avatar
15/16" works in place of 24mm.
13/16" works in place of 21mm (lugnuts)
Old Jun 3, 2004 | 08:54 AM
bamachem's Avatar
Originally Posted by Citykid
...$90 for the front diff, $90 for the rear diff, and another $90 for the transfer case...
Screw my engineering degree, I'm gonna go open a jiffy screw.
Old Jun 3, 2004 | 09:09 AM
15/16. Gotcha. I have a full 1/2" socket set and that must be the only one I use to check/change the diff fluid.
Old Jun 3, 2004 | 09:26 AM
X-AWDriver's Avatar
:wtf:
Most oil change places do them all for under $100.
Eggslinger
Jun 8, 2019 03:32 PM
Up&Down
Aug 11, 2015 10:04 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
the1998sr5
Jul 16, 2015 06:20 AM
